Customer Results
After the optimization has been completed you can analyze the results using various tables, bar charts and maps. On this page you can find reports of the results related to the Customer category, such as:
You can read about the period selector in Period Selector.
Fulfillment or Lead Time Violations Bar Chart
This bar chart shows the fulfillment or the lead time violations for all customers. The periods are shown on the x-axis and the number of customers for which the fulfillment or the lead time constraints are violated or met are shown on the y-axis.
The bar chart is color-coded based on the status of the customer, which can be one of the following:
Red (Violated): when some constraints are not met
Green (Within bounds): when all the constraints for lead time and fulfillment are met
When hovering over one the columns in the bar chart a tooltip with more information appears for that column:
You can display the legend by clicking on the icon on the upper right corner of the widget.
Demand Fulfillment Chart
This chart shows the total demand and fulfillment by period. The periods are shown on the x-axis and the total fulfillment and demand values are shown on the y-axis.
The demand is drawn with a red line and the fulfillment is drawn with a green line.
When hovering over one of the points in the chart a tooltip with more information appears for that point:
You can display the legend by clicking on the icon on the upper right side of the widget.
Drive Time Distribution Bar Chart
This bar chart shows the number of customers reached in a given time range for a selected period. By default, the table shows the data for the first period. The time intervals are shown on the x-axis and the number of customers are shown on the y-axis.
Orange (Near bounds): when the lead time is close (above 95%) to its limit
If you select another period, the data in the bar chart will change accordingly.
When hovering over one the columns in the bar chart, a tooltip with more information appears for that column:
Fulfillment or Lead Time Violations Map
This map presents all customers in the model for the selected period. By default, the table shows the data for the first period.
The nodes are color-coded based on the status of the customer, namely:
When clicking on one of the customer on the map, the data for the selected customer is highlighted in the table Customer Results. You can also select a customer by clicking on the column the customer belongs to in the Drive Time Distribution bar chart. The node of the selected customer gets a black outline on the map.
You can resize the dots on the map as follows:
When hovering over one of the customer nodes on the map, a tooltip with more information appears for that customer:
Customer Results Table
The table Customer Results shows the customer related results.
When a customer is selected on the map its rows are highlighted in this table.
