Results
After the optimization has been completed you are able to analyze the results using various reports and breakdowns from the supplier to the customer.
Next we discuss these options in turn.
Main Map
The map presents the optimal flows through the network for the selected period. By default, the table shows the data for the first period. The nodes are color-coded based on the their type.
The arcs show the different types of transportation lanes, so, the color and the curve are based on their types:
Primary (curved, blue): Flows go from Suppliers and represent "the first mile" flows.
Secondary (straight, olive): Flows go to Customers and represent "the last mile" flows.
InterResource (curved, black): Flows go between Resources (Production facilities, Warehouses, etc.).
Direct (straight, olive): Flows go directly from a Supplier to a Customer.
When hovering over one the lanes or over one of the nodes on the map a tooltip appears for that lane or that node:
Customization Settings
You can customize the map by clicking on the menu icon at the upper right side of the map widget. You can perform the following actions:
Reset map to default scale: After zoom in or zoom out on the map, you can reset the map to the default zooming state by clicking on the Reset map to default scale option.
Save zooming scale for main map: After zoom in or zoom out on the map, you can save the actual zooming scale so when you open the application the map will be set to this zooming scale.
Customize nodes: You can customize the icons and the colors of the nodes by clicking on this option. After customization, when you open the application the nodes will be displayed accordingly.
You can select icons or colors by clicking twice on the appropriate cell in the table and select the icon or the color from the list.
You can select color, thickness, line form by clicking twice on the appropriate cell in the table and select from the list.
Customize node size : You can set here the size of the supplier, production, warehouse and customer nodes. After customization, when you open the application the nodes' size will be displayed accordingly. By default it is 100%. You can change the size by moving the slider to the right (increase) or left (decrease). The size can be changed between -100% and 400%.
Reset map to default: You can set the map by the default setting by clicking on this option, but when you reopen the application the customized setting will be applied.
Show labels : The volume of the lanes will be visible by turning on that option.
Node Filters
Nodes are the geographic locations represented on the map. On the Node Filters side panel you can set filtering options for nodes. Node Types are usually divided into Customer, Supplier, Production, and Warehouse. For Production and Warehouse several groups are shown. Please note that only the nodes of the selected types will be displayed on the map.
There are also several other kinds of coloring for the nodes, which you can set in this side panel:
Status Coloring The supplier, production and warehouse nodes will be colored based on their status. The meaning of the colors:
Red (Violated): when the capacity utilization is higher than its limit
Orange (Near bounds): when the capacity utilization is close (above 95%) to its limit
Green (Within bounds): when the capacity utilization is within its limits
Gray (Inactive): when the supplier/production/warehouse is not active
Black (Closed): when the supplier/production/warehouse is closed by the model
Load Coloring The customer nodes will be colored based on their demand. The customers are sorted in three groups based on their volume: big, medium and small.
Heat Map Heat Map can be used to visualize demand distribution, but for a good overview, more than 1000 nodes are needed.
Service Range: The customer nodes will be colored based on the supplier/warehouse that shipped to the customer.
Map Filters
On the Map Filters side panel you can turn on the Lanes by Volume option and you can apply filtering conditions, such as:
Number of largest customers You can define the value of how many how many of the customers queuing according to demand should appear on the map. For example, if the value is 3, the three largest customer will be shown on the map.
Demand % You can define the value of what percentage should be displayed on the map. For example if the value is 10%, the customers whose total demand is the 10% of the all defined demand will be displayed on the map.
Primary threshold You can define a value at which primary lanes with greater volume will be displayed on the map. For example, if the value is 2000, then the map will show only those primary lanes which volume is greater than 2000.
Secondary threshold You can define a value at which secondary lanes with greater volume will be displayed on the map. For example, if the value is 2000, then the map will show only those secondary lanes which volume is greater than 2000.
Inter Resource threshold You can define a value at which inter resource lanes with greater volume will be displayed on the map. For example, if the value is 2000, then the map will show only those inter resource lanes which volume is greater than 2000.
Direct threshold You can define a value at which direct lanes with greater volume will be displayed on the map. For example, if the value is 2000, then the map will show only those direct lanes which volume is greater than 2000.
Supplier threshold You can define a value at which supplier with greater supply will be displayed on the map. For example, if the value is 2000, then the map will show only those suppliers whose supply is greater than 2000.
Warehouse threshold You can define a value at which warehouse with greater volume will be displayed on the map. For example, if the value is 2000, then the map will show only those warehouses whose volume is greater than 2000.
Production threshold You can define a value at which production facilities with greater production will be displayed on the map. For example, if the value is 2000, then the map will show only those production facilities whose production is greater than 2000.
