Transport Results
After the optimization has been completed you can analyze the results using various tables, bar charts and maps. On this page you can find reports of the results related to the Transport category, such as:
You can read about the period selector in Period Selector.
Transport Capacity Violation Bar Chart transport top left sign
This bar chart shows the capacity violation for all periods and for all transport modes. The name of the transport mode is shown on the x-axis and the number of periods is shown on the y-axis.
../../../_images/transport_capacity_violation_barchart_1.png
The bar chart is color-coded based on the status of the transport mode, which can be one of the following:
  • Red (Violated): when the capacity utilization is higher than its limit
  • Orange (Near bounds): when the capacity utilization is close (above 95%) to its limit
  • Green (Within bounds): when the capacity utilization is within its limits
  • Gray (Inactive): when the transport mode is not active
When hovering over one the columns in the bar chart a tooltip with more information appears for that column:
../../../_images/transport_capacity_violation_barchart_2.png
When clicking on one of the transport modes on the bar chart, the data for the selected transport mode appears in the Volume bar chart.
You can display the legend by clicking on the legend sign icon on the upper right corner of the widget.
../../../_images/transport_capacity_violation_barchart_3.png
Volume Bar Chart transport top right sign
This bar chart shows the volume by period for a selected transport mode. You can select a transport mode by clicking on one of the transport modes in the bar charts Capacity Violation or Volume by Transport Mode. You can also select a transport mode by clicking on a lane which belongs to that transport mode on the Capacity Violations map.
../../../_images/volume_barchart_1.png
../../../_images/volume_barchart_2.png
Volume by Mode of Transport Bar Chart transport bottom left sign
This bar chart shows the total volume for the selected period for all transport modes. By default, the table shows the data for the first period.
../../../_images/volume_modeoftransport_barchart_1.png
If you select another period, the data in the bar chart will change accordingly.
../../../_images/volume_modeoftransport_barchart_2.png
Transport Capacity Violations Map transport bottom right sign
This map presents the optimal flows through the network for the selected period. By default, the table shows data for the first period. The nodes are color-coded based on the their type, similarly to the coloring on the Results page.
../../../_images/transport_capacity_violation_map_1_1.png
The arcs show the different types of transportation lanes, their color and curve are based on their types, as follows:
  • Primary (curved,blue): flows go from Suppliers and represent "the first mile" flows
  • Secondary (straight, olive): flows go to Customers and represent "the last mile" flows
  • InterResource (curved, black): flows go between Resources (Production facilities, Warehouses, etc.)
  • Direct (straight, olive): flows go directly from a Supplier to a Customer
The size of the arcs depends on the volume.
When clicking on one of the lanes on the map, the data for the transport mode of the selected lane appears in the Volume bar chart.
You can turn on the coloring by service range on the map as follows:
  1. Click on the settings sign icon at the upper right side of the map widget
  2. Click on the Color customer nodes by service range option
  3. The color of the node depends on its category.
../../../_images/transport_capacity_violation_map_2_1.png
When hovering over one of the lanes on the map, a tooltip with more information appears for that lane:
../../../_images/transport_capacity_violation_map_3.png
Primary Transportation Table transport first table sign
The table Primary Transportation shows the results of the primary lanes which go from a supplier location.
../../../_images/primary_transportation_table.png
Secondary Transportation Table transport second table sign
The table Secondary Transportation shows the results of the secondary lanes which go to a customer location.
../../../_images/secondary_transportation_table.png
Direct Transportation Table tranport third table sign
The table Direct Transportation shows the results of the lanes which go from supplier to a customer
../../../_images/direct_transportation_table.png
InterResource Transportation Table tranport fourth table sign
The table InterResource Transportation shows the results of the lanes which go between resources.
../../../_images/interresource_transportation_table.png
Take or Pay Table tranport fifth table sign
The table Take or Pay Transportation shows take or pay cost related results. You can read more about take or pay costing in Template-Attributes.
../../../_images/takeorpay_transportation_table.png
Stepwise Costing Table tranport sixth table sign
The table Stepwise Costing Table shows the stepwise costing related results. You can read more about take or pay costing in Template-Attributes.
../../../_images/stepwisecosting_transportation_table.png
