Third Phase - Compare Scenarios
Here two solutions can be compared based on their overview information which is presented on the Run Scenario page and Result Overview dialog.
Active is the scenario which comes from the previous phases or loaded as active. Its nodes and bars have a green border, marking that they are related to the current solution. Reference is the scenario that is compared to the Active scenario. The nodes and bars have a purple border, marking that that data comes from the reference solution.
The page has two different views:
Separate View: By default this view is initialized, and here the Active and Reference scenarios are near each other. They both have their own map, drive time distribution barchart, and cost overview barchart with both views, as they are on the Run Scenario page page.
Combined View: There’s only one map, one drive time distribution barchart, and one cost overview barchart with both views, as they are on the Run Scenario page page. In the widgets the data of both scenarios is presented at the same time, on the same scale but with the two different colors (active green, reference purple).
Separate View:
Combined View:
Map View Side Panel
On this side panel the view options can be handled for comparison page.
View Settings
Combined View: Using this option the user can switch between Separate View and Combined View.
Load Coloring: This option is visible only when at least one of the two scenarios uses supply and/or demand as input, and applies the load heat map, with the coloring rule from the Run Scenario page.
Show Arcs
This option turns on/off arcs separately for both scenarios in each view.
Show Nodes
This options turns on/off different node types separately for both scenarios in each view.
Legend Side Panel
This side panel summarizes the colors presented on maps for each scenario.
