Attribute Name Change
The attributes play a very important role in the SC Navigator platform, as this is how you provide the data to the various applications and also how the applications share data among them. However, as the applications change over time, and we gather new insight based on feedback from the users we will change them from time to time.
The impact of this change is limited. You can still use all the old configurations, datasets and scenarios, that you have created before, without any problem. You can still use your old Excel templates, but Data Navigator will give a warning if you upload a file that contains attributes that have been renamed. It will just be a warning, and you are still able to save the data, of course, the model will store the data in the database under a new name.
Network Design 2.24.01
In this version (released September 2020) the following attribute have been renamed.
Excel Sheet
Old Attribute
New Attribute
Supplier Data
Minimum Supply
Minimum Capacity
Supplier Data
Capacity
Maximum Capacity
Supplier Data
Minimum Supply
Minimum Capacity
Supplier Data
Supply Cost
Variable Cost
Resource/DC/Production Data
Available
Available (DC)
Throughput Capacity
Maximum Capacity (DC)
Minimum Throughput
Minimum Capacity (DC)
Throughput Potential Capacity Uplift
Capacity Uplift (DC)
Throughput Potential Capacity Uplift Fixed Cost
Capacity Uplift Fixed Cost (DC)
Production Available
Available (Production)
Minimum Production
Minimum Capacity (Production)
Production Capacity
Maximum Capacity (Production)
Variable Cost
Variable Cost (Production)
Allow Uplift
Allow Uplift (Production)
Capacity Uplift
Capacity Uplift (Production)
Capacity Uplift Fixed Cost (Production)
Capacity Uplift Variable Cost
Capacity Uplift Variable Cost (Production)
Resource/DC/Production Product Data
Variable Throughput Cost
Variable Cost (DC)
Variable Throughput Cost Premium
Variable Cost Premium (DC)
Throughput Potential Capacity Uplift Handling Cost
Capacity Uplift Variable Cost (DC)
Variable Cost
Minimum Production
Production Capacity
Allow Uplift
Capacity Uplift
Transport Product Data or Transportation Cost Data
Cost Per Mile
Cost Per Distance
Cost Per Mile Premium
Cost Per Distance Premium
Transport Cost/Constraint Product Data
Capacity
Maximum Capacity
Minimum Transport
Minimum Capacity
Product Location Data
Transportation Conversion Factor
Average Drop Size
Bill Of Material Data
ProductCreated
Product Created
ProductNeeded
Product Needed
Bill Of Resource Data
ResourceNeeded
Resource Needed
Trans Type Product Data or Transport Cost Data
Transportation Mode Available
Available
Transportation Mode Cost Per Distance Unit
Cost Per Distance
Transportation Mode Cost Per Distance Unit Premium
Trans Type Product Data or Transport Constraint Data
Transportation Mode Capacity
Maximum Capacity
Transportation Mode Minimum Transportation
Minimum Capacity
Transportation Mode Distance
Distance
Transportation Mode Duration
Duration
Transportation Mode Cost Per THU
Cost Per THU
Transportation Mode Cost Per THU Premium
Transportation Fixed Cost
Fixed Cost Per Trip
Transportation Minimum Charge
Minimum Cost Per Trip
Average Drop Size
