How to Transfer SC Navigator Output to the Inventory Planning App
In this article, we explain how to use the output of SC Navigator as input for the Inventory Planning app.
Workflow
Starting in Data Navigator, create a configuration with the Data Wizard, but select Use Network Design Data:
Generate the Excel template:
The generated Excel template is simpler than the full Inventory Planning app template: it does not have the Resource Location Product Customer tab and the Transport Product Data tab, because these will be brought in from the SC Navigator results. Location data and Resource data do have to be defined in both places, but they will be consistent across scenarios.
Save it as a dataset:
Run scenarios in SC Navigator to confirm network flows. When saving results, ensure Export to Data Lake and Results visible to everyone are both ticked:
Now switch to the Inventory Planning app and load the configuration you just created. When loading a dataset, choose both an inventory dataset and an SC Navigator Output dataset:
Now that you have loaded your dataset, you can refer to the Inventory Planning documentation for guidance on working with this data in the app. You can also read about the benefits of using Inventory Planning together with SC Navigator in How to Approach Inventory Strategy Decisions.
