Importing data from Snowflake into SC Navigator
This article describes how you can get output data from your Snowflake environment into your AIMMS SC Navigator cloud account.
You can download the example Jupyter notebook here and use the template directly in your Snowflake Worksheets or Notebooks, or use it locally if you have Python installed.
Parquet File Definition SC Navigator
This how to article assumes you have already created datasets according to the Parquet File Definition of SC Navigator. You can find more information about the Parquet File Definition here: Parquet File Structure.
What to do in SC Navigator
Each AIMMS SC Navigator cloud account is by default equipped with an Azure Data Lake Storage Gen2 (ADLS). For this route we will be utilizing the external access to this storage account to import new data.
The results will be saved in the parquet file format in the import folder of the ADLS.
You will also need to create a SAS-token to get external access to the ADLS. You can find instructions on how to do this on the page SAS Tokens.
Configuration in Snowflake
You can download the full Jupyter notebook example from the link in the first paragraph and replace the ‘TODO’-items in the notebook with your own variables. Below we will describe the code fragments and how they can be used.
You will be using Python packages for the connection to the ADLS. Also for this example we use the Snowpark library for Python to connect to Snowflake. First these need to be installed:
1%pip install azure-storage-file-datalake azure-identity
First you load the data in Snowflake you would like to upload to SC Navigator. For this example we have all our input data in tables in the sc_navigator_input schema. We explicitly define which datasets of this schema we want to upload by using the datasets list.
1datasets = ['_dataset_info',
2 'bill_of_material',
3 'custom_objective',
4 'customer_definition',
5 'customer_groups',
6 'customer_product',
7 'inventory_product_step',
8 'inventory_step',
9 'location_definition',
10 'location_groups',
11 'location_period',
12 'location',
13 'mode_of_transport_definition',
14 'mode_of_transport_product',
15 'period_definition',
16 'product_definition',
17 'product_groups',
18 'production_bom',
19 'production_definition',
20 'production_groups',
21 'production_routing',
22 'production_step',
23 'settings',
24 'supplier_definition',
25 'supplier_product_step',
26 'supplier_step',
27 'transport_trip_data',
28 'uom_product',
29 'warehouse_definition',
30 'warehouse_groups',
31 'warehouse_product_step',
32 'warehouse_step']
With the following code we load the data from our schema and create Pandas Dataframes for every table. We also do some transformations to conform to the Parquet File Definition.
1# get the prepared data from Snowflake and do some transformations
2from snowflake.snowpark import Session
3import numpy as np
4dataframes_for_input = dict()
5new_session = Session.builder.configs(connection_parameters).create()
6for dataset in datasets:
7 # load the data
8 snowpark_df = new_session.table("sc_navigator_input." + dataset).collect()
9 df = snowpark_df.to_pandas()
10 # transform to the Parquet File Definition SC Navigator definition
11 df = df.replace({np.nan: None})
12 if dataset != "_dataset_info":
13 dataset = dataset.replace("_", "-")
14 # store result
15 dataframes_for_input[dataset] = df
16# close session
17new_session.close()
Then you’ll need to provide the SAS-token and the URL, both of which are exposed/generated in the previous step when creating the SAS-token:
1# TODO: provide the sas token and the URL of your storage
2 account_url_full = "<put here your URL>"
3 # remove the folder from the url
4 account_url = account_url_full[:-20]
5 sas_token = "<put here your sas token>"
6 # the file system is fixed, this is the container SC Navigator will write its results
7 file_system="sc-navigator-import"
An example of the value expected at account_url_full is https://CloudName.dfs.core.windows.net/sc-navigator-export.
For the sas_token parameter you should only paste the SAS-token itself.
You’ll need to import more required packages:
1import os
2from azure.storage.filedatalake import (
3 DataLakeServiceClient,
4 DataLakeDirectoryClient,
5 FileSystemClient
6)
7from azure.identity import DefaultAzureCredential
And create a DataLakeServiceClient to access the storage:
1# create a DataLakeServiceClient to access the storage
2dsc = DataLakeServiceClient(account_url=account_url, credential=sas_token)
You can now list all available scenarios on the storage:
1# list all available scenario's on the storage
2# Note that you need to save the scenario from SCN with datalake storage enables before they will be visible!
3file_system_client = dsc.get_file_system_client(file_system=file_system)
4paths = file_system_client.get_paths()
5list_of_scenarios = list()
6for path in paths:
7 if "/" not in path.name and path.name != "info.txt":
8 print(path.name + '\n')
9 list_of_scenarios.append(path.name)
10 else:
11 continue
If this code block gives an error, please check the provided URL and the SAS token (this token needs to be valid and cannot be expired). For further reference we refer to the Microsoft documentation.
Now we create a directory on ADLS to upload the data to:
1# create a new directory to store the datasets
2 directory_name = "<directory name>"
3 dld_client = file_system_client.create_directory(directory_name)
If you made a mistake our would like to delete data you can do the following:
1client = dsc.get_directory_client(file_system=file_system,directory="<directory name>")
2client.delete_directory()
Before we upload any data we would like to inspect the _dataset_info table. The Dataset field will be used to identify the uploaded data in SC Navigator
1dataframes_for_input["_dataset_info"]
Now we are ready to upload the prepared datasets:
1# upload the files for the selected scenario's
2 client = dld_client
3 for k,v in dataframes_for_input.items():
4 file_name = k + ".parquet"
5 file_client = client.create_file(file_name)
6 bytes_data = v.to_parquet()
7 file_client.append_data(data=bytes_data, offset=0, length=len(bytes_data))
8 file_client.flush_data(len(bytes_data))
To show all data:
1# show all data
2[k for k,v in dataframes_for_visualization.items()]
You could use the following code to see if the upload is successful and inspect the data on ADLS.
1 import io
2 import pandas as pd
3 file_client = client.get_file_client("_dataset_info.parquet")
4 data_file = file_client.download_file()
5 data_binary = data_file.readall()
6 parquet_file = io.BytesIO(data_binary)
7 df = pd.read_parquet(parquet_file)
8 display(df)
Congratulations! You just uploaded data from Snowflake to SC Navigator. Now open the System Configuration app (or ask your admin to do this) and push the rebuild overview button on the File System Management tab. If you now open SC Navigator you should see that your dataset is added to the overview.
