Data
The Data page in Transport Navigator can be used to review and create scenarios from the input data for Transport Navigator. The page contains six tabs: Settings, Warehouses, Vehicles, Customers, Fixed Routes, and Trip Data. The data tables in each tab will be discussed below.
Settings
The Transport Navigator data attributes that can be reviewed and adjusted on the Settings Data table are given below.
Field |
Description |
TN Solve Time |
Time in seconds for the Transport Navigator to find the best solution. |
Reference Date and Time |
Starting date and time for the Transport Navigator optimization. |
Include Week Number in Time Stamps |
Indicates if week numbers should be included in timestamps. |
Reset Duty Time at Warehouse |
Resets the duty time and drive time when the vehicle returns to the warehouse. |
Volume UOM |
Unit of measurement for volume. |
Weight UOM |
Unit of measurement for weight. |
Time Window Start Offset |
Adjusts the Time Window Start for longer or shorter time windows. |
Time Window End Offset |
Adjusts the Time Window End for longer or shorter time windows. |
Time Window Start Overwrite |
Sets a new Time Window Start, overwriting the previous value. |
Time Window End Overwrite |
Sets a new Time Window End, overwriting the previous value. |
On the Period Data table, the Period Start and Period End values can be adjusted.
Warehouses
The Warehouses tab contains the Warehouse Data table and the Warehouse TN Period Data table. Data on the following attributes can be reviewed and adjusted there:
Field |
Description |
Mode of Transport |
The Mode of Transport that is used for routes from the warehouse location. |
Maximum Duty Time |
The maximum duty time (in minutes) before a layover is required. |
Maximum Drive Time |
The maximum drive time (in minutes) before a layover is required. |
Minimum Layover Duration |
The minimum duration of a layover (in minutes). |
Maximum Layover Duration |
The maximum duration of a layover (in minutes). |
Cost Per Stop |
The cost per stop made during the route. |
Cost Per Dispatch |
The cost for dispatching a vehicle from the warehouse. |
Cost Per Layover |
The cost per layover. |
Cost Per Hour Late |
The cost per hour of being late after the customer time window, calculated per minute. |
Maximum Distance between Stops |
The maximum distance between two (customer) stops. |
Reloading Time Warehouse |
The reloading time (in minutes) at a warehouse before a vehicle can depart again. |
Maximum Number of Stops per Route |
The maximum number of stops on a route before the truck needs to return to the warehouse. |
Field |
Description |
Opening Time |
The warehouse’s opening time at the specified location during the TN period (in hours from the start of the TN period). |
Closing Time |
The warehouse’s closing time at the specified location during the TN period (in hours from the start of the TN period). |
Minimum Relative Capacity |
The minimum percentage of the total effort that must be fulfilled in this period. |
Maximum Relative Capacity |
The maximum percentage of the total effort that can be fulfilled in this period. |
Vehicles
The Vehicles tab contains the Vehicles Data table. Data on the following attributes can be reviewed and adjusted there:
Field |
Description |
Reduced Capacity Per Stop |
The amount by which the vehicle’s volume capacity decreases per stop on a multi-stop route. |
Vehicle Capacity Weight |
The weight capacity of the vehicle type, as specified in the weight unit of measurement. |
Vehicle Capacity Volume |
The volume capacity of the vehicle type, as specified in the volume unit of measurement. |
Has Sleep Cabin |
Indicates the availability of a sleep cabin in the vehicle type for layovers. |
Route Ends at Last Stop |
Indicates whether the vehicle never returns to the depot after its last delivery (binary). |
Pre-Trip Drive Time |
Driving time (in minutes) already spent before reaching the depot. |
Pre-Trip Duty Time |
Duty time (in minutes) already spent before reaching the depot. |
Post-Trip Drive Time |
Driving time (in minutes) needed after the last stop to return home. |
Post-Trip Duty Time |
Duty time (in minutes) needed after the last stop to return home. |
Cost Per Distance |
The cost per unit of distance (kilometer or mile) for transportation. |
Cost Per TN Period |
The cost per TN Period associated with operating the vehicle. |
Cost Per Vehicle |
The fixed cost associated with owning or operating the vehicle in the planning horizon. |
Cost Per Hour Driving |
The cost per hour of duty time for driving the vehicle. |
Cost Per Hour Waiting |
The cost per hour of duty time that the vehicle spends waiting. |
Grouping Code |
A code used to group customers and assign them to a vehicle with a matching grouping code. |
Customers
The Customers tab contains the Customers Data table. Data on the following attributes can be reviewed and adjusted there:
Field |
Description |
Demand |
The demand for each product per customer in the base unit of measurement. |
Demand Volume |
The volume of product demand for each customer, specified in the volume unit of measurement. |
Demand Weight |
The weight of product demand for each customer, specified in the weight unit of measurement. |
Pattern Group |
The pattern group according to which this customer must be served. |
Effort |
The effort required in the warehouse to pick, load, or process the order. |
Service Time |
The time in minutes required for service at the customer’s location, e.g. offloading. |
Time Window Start |
The earliest possible arrival time at the customer’s location, in hours from the period start. |
Time Window End |
The latest possible arrival time at the customer’s location, in hours from the period start. |
Is First Stop |
Indicates if the location must be the first stop on a route (1 for yes, 0 for no). |
Is Last Stop |
Indicates if the location must be the last stop on a route (1 for yes, 0 for no). |
Grouping Code |
A code to group customers for assigning to a vehicle with a matching grouping code. |
Serviced by Warehouse Location |
The warehouse location name that services the demand. |
Fixed Routes
The Fixed Routes tab contains the Fixed Routes Data table. Data on the following attributes can be reviewed and adjusted there:
Field |
Description |
Customer Name |
The name of the customer where a vehicle needs to stop on the fixed route. |
Location Name |
The name of the location where a vehicle needs to stop on the fixed route. |
TN Period Name |
The name of the Transport Navigator period during which a stop is made on the fixed route. |
Trip Data
The Trip Data tab contains the Trip Data table, sourced from the Transport Trip Data sheet. Data on the following attributes can be reviewed and adjusted there:
Field |
Description |
From Location |
The warehouse the route departs from. |
To Location |
The customer that ends the route. |
Last Customer Base Cost |
An additional cost per load, charged once per route when the To Location is the last customer visited, on top of all other transport costs. |
