Transport Sheets
These sheets cover information related to transportation modes, costs, and trip data.
Mode of Transport
Speed (Transport Attributes)
Wiggle Factor (Transport Attributes)
Roundtrip: this attribute should be set to 1 if the transport mode is used for roundtrip (Transport Attributes)
Maximum Road Distance To Retrieve: when a lane is using a mode of transport for which maximum road distance to retrieve has been specified and the straight-line distance between two points for the lane is greater than the maximum road distance to retrieve, then the ‘Retrieve Distance’ flag will automatically be set to 0 for those lanes, and straight-line distances will be used instead. (Transport Attributes)
Mode of Transport Groups
Transport Cost
Availability (Available)
Retrieve Distance (Transport Attributes)
Average Load Size (Transport Attributes)
Capacity data (Capacity Attributes)
Cost data (Cost Attributes)
Base Case data (Transport Attributes)
Opening/Closing data (Open/Close Attributes)
Load Consolidation data: Minimum/Maximum Load Size and Minimum/Maximum # of Trips (Load Consolidation Attributes)
Custom Objectives data (How to use Custom Objectives?)
Retrieve High-level Cost Data and Request Detailed Cost Data (Transport Attributes)
Take Or Pay Volume and Take Or Pay Fixed Cost (Transport Attributes)
Maximum Drive Time (Transport Attributes)
Lead Time Offset
Lead Time Offset and Cost To Serve
Because activities need to happen during lead time periods, there may be no demand fulfilled during those periods. The following costs are calculated in the periods when the activities occur and are included in the System Cost category:
Supplier: Fixed/Variable Cost
Supplier Product: Fixed/Variable Cost
Production: Fixed/Variable Cost
Production Routing: BOM Fixed/Variable Cost
Transport Cost: Cost-related attributes
Below is the Cost To Serve solution in a dataset with demand from February to December. The Period Offset is 1 for Supply, Production, and Transport from warehouse to customer.
In January, there is no demand. The cost accumulated from Supply/Production/Warehouse/Transport activities falls in the System Cost category.
In December, there is no cost, because no activities occur to meet demand in that period: the transport cost is incurred 1 period earlier.
Rate Cards
Drop Size Lower/Upper (Rate Card Attributes)
Distance Lower/Upper (Rate Card Attributes)
Rate Card From/To (Rate Card Attributes)
To configure rate card data, you must first define Drop Size values for each band. In addition to Drop Size, you can define rate cards using the following methods:
Zone-based rate cards: Specify the locations using the fields Rate Card From and Rate Card To.
Distance-based rate cards: Specify the distance range using Distance Lower and Distance Upper bounds.
For increased flexibility, you may also combine zone-based and distance-based rate cards within the same configuration.
Stepwise Transport Cost
Minimum/Maximum Capacity data: you can specify steps with different capacity bounds and different cost for lanes. The capacity bounds will determine which step’s costing will be applied for the lane. (Capacity Attributes)
Transport Trip Data
Distance: The travel distance (miles or km depending on the input) for this lane (Transport Attributes)
Duration: The travel duration (in hours) for this lane (Transport Attributes)
Max Difference: The maximum transported volume difference from the other roundtrip lanes of the transport type (Transport Attributes)
Transportation Lead Time (End-to-End (E2E) Lead Time Attributes)
Last Customer Base Cost: An additional cost per load, charged once when the lane’s To Location is the last customer of a route. Used by Transport Navigator only (Transport Attributes)
You can read more about the different types of attributes in Transport Attributes.
