Periods Sheets
On this sheet you can specify the periods the model should consider.
Periods
Purpose: Specify the time periods for the analysis.
Instructions: List all relevant time periods you want to use in the model. To define a period you should specify the name of the period (first column), the start/end date of the period (second and third column). The other columns are optional to fill but you can add description for the period and add Minimum number of Suppliers/Productions/Warehouses/Locations and Maximum number of Suppliers/Productions/Warehouses/Locations data.
