Notes, Settings and String Settings Sheets
These sheets contain general instructions and configuration settings essential for setting up the template.
Notes
Settings
Use description instead of name in displays. It can be set for Product/Customer/Warehouse and Production/Supplier/Location/Period separately
Optimization settings: Time Limit and Optimality Gap (Optimization Parameters and Constraints)
CoG related setting like capacities, costs and maximum number of Source/Destination Locations (Optimization Parameters and Constraints)
Enforce E2E Lead Time Constraints (End-to-End (E2E) Lead Time Attributes)
String Settings
Selected Objective: The initial selected optimization objective. It should be one of the following: Minimize Cost, Maximize Revenue, Maximize Profit. If nothing is specified, the default will be Minimize Cost.
Unit of Distance: The unit of calculating distance using longitude/latitude. The unit of distance is either km or mile. If left empty, mile will be used by default.
Default/Base UOM: The default/base unit that will be used throughout the model.
Default Currency UOM: The default unit symbol for currency that will be used throughout the model. The default is $, so that symbol will be used if nothing is specified.
Rate Cards UOM: The unit of measurement that will be used for rate cards. You can specify only one.
CoG Location/Warehouse Group : The Location/Warehouse group that CoGs belong to in SC Navigator dataset.
CoG Product Group: Product Group for extended single sourcing functionality. The CoG’s Product Group to be included in extended single sourcing functionality in SC Navigator dataset.
CoG Algorithm for Number of CoGs: Number of CoGs algorithm preference: Speed, Balance, or Accuracy, prioritizing performance, balance between speed and precision, or precision, respectively.
