Data Editing
Block Editing in Tables
On Data pages you can modify the input data in tables. You can edit one or more cells in a table.
More specifically, you can select regions (blocks) of the table by using your mouse, then type a value and press CTRL+ENTER to change all selected cells to the value you typed. In the case of a binary cell with a checkbox, you can use CTRL+SPACE to toggle all selected values to the toggled value of the first cell. Similarly, in the case of a DateTime cell, you can use the keyboard combination CTRL+LEFT MOUSE.
A special case of block editing is “deleting a block”. When selecting a block, as described above, and then pressing CTRL+DELETE, the whole block of cells will be set to their default values.
You can read more about block editing in tables in the AIMMS Optimization Tooling documentation.
Download and Upload Table Data
The Table Widget offers the possibility to download its contents to an Excel workbook on your local machine, which you can then use to further process your data in Excel. Also, the data from an Excel workbook can be uploaded directly to the Table Widget.
More specifically, after using Excel to make edits to the data, the same sheet can be uploaded to the table and its changes will be automatically applied to the WebUI data (as if you made them through manual changes). On the Table Widget header, you can access both actions when opening the kebab menu:
You can read more about downloading and uploading table data in the AIMMS table upload and download documentation.
Edit Input Data in Empty Columns
By default, only columns that contain data are visible and editable on each data page and in each table. To modify data in an empty column, click on the widget action Show All Attributes, which is available for most input data tables.
This will display all columns, making it possible to view and edit every attribute, including those without data.
The default view, where only columns with data are visible, can be restored by selecting the Only Show Attributes With Data option.
