Group Elements in the Data
There are two ways to specify group data in the Excel file with input data, which are handled differently in the model. Assume that we have a product group Cold Storage Products, then you can use this in the Excel file as follows:
{Cold Storage Products}
If you specify the group element in the first way, then the model will apply the data to all the elements in that group. For instance, if you specify $15 for the attribute Variable Cost and Cold Storage Products, then the model interprets this as the Variable cost is $15 for each product in the group Cold Storage Products.
If you specify the group element in the second way, the model will interpret this in the same way unless that group and attribute are mentioned in the table below.
If a group is specified as {Group} and the group type and attribute are mentioned in the table below, then this value is interpreted as the total for all products in that group. For instance, if you specify the value 150,000 for the attribute Maximum Capacity and {Cold Storage Products}, then the model interprets this as the Maximum Capacity is 150,000 for all products combined in that group.
The following combinations allow for {group} elements. If you specify the brackets {}, but that attribute is not in this table, then SC Navigator will handle this in the same way as without the brackets {}.
Curly bracket grouping for Cost Per Distance and Cost Per Trip is only supported when used together with the Load Consolidation Attributes.
Input Template Sheet |
Attribute |
Period |
Product |
Resource |
Customer |
Location |
Supplier |
Transportation Mode |
Bill Of Material |
Location Product |
Maximum # of Source Locations |
x |
x |
x |
Location Product |
Maximum # of Destination Locations |
x |
x |
x |
Location Product |
Minimum # of Open Locations |
x |
x |
x |
Location Product |
Maximum # of Open Locations |
x |
x |
x |
Customer Product Data |
Minimum Fulfillment Rate |
x |
x |
x |
x |
x |
x |
x |
x |
Minimum Lead Time Adherence |
x |
x |
x |
x |
Production Routing |
Minimum Capacity |
x |
x |
x |
x |
Maximum Capacity |
x |
x |
x |
x |
Force Open |
x |
x |
x |
x |
BOM Variable Cost |
x |
x |
x |
x |
Open as Group |
x |
Minimum Open |
x |
x |
x |
x |
Maximum Open |
x |
x |
x |
x |
Production BOM |
Minimum Capacity |
x |
x |
x |
x |
Production BOM |
Maximum Capacity |
x |
x |
x |
x |
Production BOM |
Force Open |
x |
x |
x |
x |
Production BOM |
BOM Variable Cost |
x |
x |
x |
x |
Production BOM |
Open as Group |
x |
Production BOM |
Minimum Open |
x |
x |
x |
x |
Production BOM |
Maximum Open |
x |
x |
x |
x |
Transport Cost |
Cost Per Distance |
x |
x |
Transport Cost |
Cost Per Trip |
x |
x |
Transport Cost |
Minimum Load Size |
x |
x |
Transport Cost |
Maximum Load Size |
x |
x |
Transport Cost |
Minimum # of Trips |
x |
x |
Transport Cost |
Maximum # of Trips |
x |
x |
Transport Cost |
Minimum Capacity |
x |
x |
x |
x |
Transport Cost |
Maximum Capacity |
x |
x |
x |
x |
Transport Cost |
Base Case Volume |
x |
x |
x |
x |
Transport Cost |
Base Case Minimum Capacity |
x |
x |
x |
x |
Transport Cost |
Base Case Maximum Capacity |
x |
x |
x |
x |
Transport Cost |
Force Open |
x |
x |
x |
x |
Transport Cost |
Take Or Pay Volume |
x |
x |
x |
x |
Transport Cost |
Take Or Pay Fixed Cost |
x |
Supplier Product |
Variable Cost |
x |
x |
x |
x |
Supplier Product |
Minimum Capacity |
x |
x |
x |
x |
Supplier Product |
Maximum Capacity |
x |
x |
x |
x |
Supplier Product |
Force Open |
x |
x |
x |
x |
Supplier Product |
Variable Cost is for all steps |
x |
x |
x |
x |
Supplier Product |
Open as Group |
x |
Warehouse Product |
Variable Cost |
x |
x |
x |
x |
Warehouse Product |
Minimum Capacity |
x |
x |
x |
x |
Warehouse Product |
Maximum Capacity |
x |
x |
x |
x |
Warehouse Product |
Force Open |
x |
x |
x |
x |
Warehouse Product |
x |
x |
x |
x |
Warehouse Product |
Open as Group |
x |
Warehouse Product |
Maximum Inventory Cover |
x |
x |
x |
Warehouse Product |
Minimum Inventory Cover |
x |
x |
x |
Inventory Product |
Minimum Capacity (Inventory) |
x |
x |
x |
x |
Inventory Product |
Maximum Capacity (Inventory) |
x |
x |
x |
x |
Inventory Product |
Target (Inventory) |
x |
x |
x |
x |
Inventory Product |
Target Violation Cost (Inventory) |
x |
x |
x |
x |
Inventory Product |
Variable Cost (Inventory) |
x |
Stepwise Transport Cost |
Cost Per UOM |
x |
x |
x |
x |
Minimum Capacity |
x |
x |
x |
x |
Maximum Capacity |
x |
x |
x |
x |
Force Open |
x |
x |
x |
x |
x |
x |
x |
x |
Supplier |
Variable Cost |
x |
x |
x |
Supplier |
Minimum Capacity |
x |
x |
x |
Supplier |
Maximum Capacity |
x |
x |
x |
Supplier |
x |
x |
x |
Supplier |
Open as Group |
x |
Supplier |
Minimum # of Open Suppliers |
x |
x |
x |
Supplier |
Maximum # of Open Suppliers |
x |
x |
x |
Supplier |
Limit Openings |
x |
Supplier |
Maximum Openings |
x |
Supplier |
Limit Closings |
x |
Supplier |
Maximum Closings |
x |
Production |
Variable Cost |
x |
x |
x |
Production |
Minimum Capacity |
x |
x |
x |
Production |
Maximum Capacity |
x |
x |
x |
Production |
x |
x |
x |
Production |
Open as Group |
x |
Production |
Limit Openings |
x |
x |
Production |
Maximum Openings |
x |
x |
Production |
Limit Closings |
x |
x |
Production |
Maximum Closings |
x |
x |
Production |
Minimum # of Open Productions |
x |
x |
x |
Production |
Maximum # of Open Productions |
x |
x |
x |
Warehouse |
Variable Cost |
x |
x |
x |
Warehouse |
Minimum Capacity |
x |
x |
x |
Warehouse |
Maximum Capacity |
x |
x |
x |
Warehouse |
x |
x |
x |
Warehouse |
Open as Group |
x |
Warehouse |
Limit Openings |
x |
x |
Warehouse |
Maximum Openings |
x |
x |
Warehouse |
Limit Closings |
x |
x |
Warehouse |
Maximum Closings |
x |
x |
Warehouse |
Minimum # of Open Warehouses |
x |
x |
x |
Warehouse |
Maximum # of Open Warehouses |
x |
x |
x |
Supplier Ratio |
Minimum Ratio |
x |
x |
x |
x |
Supplier Ratio |
Maximum Ratio |
x |
x |
x |
x |
Warehouse Ratio |
Minimum Ratio |
x |
x |
x |
x |
Warehouse Ratio |
Maximum Ratio |
x |
x |
x |
x |
Production Routing Ratio |
Minimum Ratio |
x |
x |
x |
x |
Maximum Ratio |
x |
x |
x |
x |
Transport Ratio |
Minimum Ratio |
x |
x |
x |
x |
Transport Ratio |
Maximum Ratio |
x |
x |
x |
x |
Custom Objective Period |
Minimum Required |
x |
Maximum Allowed |
x |
Custom Objective Location |
Minimum Required |
x |
x |
Maximum Allowed |
x |
x |
Custom Objective Transport |
Minimum Required |
x |
x |
Maximum Allowed |
x |
x |
