SC NAVIGATOR DOCUMENTATION
  • Getting Started
    • Introduction to SC Navigator
    • Data Separation
  • SC Navigator
    • Input Template
      • Template Sheets
        • Notes, Settings and String Settings Sheets
        • Periods Sheets
        • Product Related Sheets
        • Location Related Sheets
        • Supplier Sheets
        • Production Sheets
        • Warehouse Sheets
        • Inventory Sheets
        • Transport Sheets
        • Customer Sheets
        • Custom Objectives Sheet
        • Transport Navigator Sheets
      • Template Attributes
        • Optimization Parameters and Constraints
        • Product Attributes
        • Location Attributes
        • Available
        • Capacity Attributes
        • Cost Attributes
        • Open/Close Attributes
        • Count Constraint Attributes
        • Ratio Constraint Attributes
        • BOM and Production Routing Attributes
        • Inventory Attributes
        • Transport Attributes
        • Rate Card Attributes
        • Load Consolidation Attributes
        • Lead Time Offset Attributes
        • Customer Attributes
        • End-to-End (E2E) Lead Time Attributes
        • Custom Objectives Attributes
        • Transport Navigator Attributes
      • Group Elements in the Data
      • Count and Ratio Constraints
    • How to Use the Application
      • User Roles and Modules
      • Common Screen Areas
        • Workflow
        • Status Bar
        • Period Selector
        • Filtering in SC Navigator
        • Page Actions and Widget Actions
      • Data Editing
      • Scenario Navigator Overview
        • Structure Overview
        • Scenario Pages Layout
      • Transport Navigator Module
        • Getting Started with Transport Navigator
        • Transport Navigator Technical Details
      • Transport Cost
      • SENSAI Pro: AI Assistant
        • Work with Your Data
        • Optimize and Analyze
        • Tips and Limitations
      • SENSAI Data Ready
        • SAP-IBP Connector
        • Raw Data
      • AIMMS AI Systems - Terms of Use
    • SC Navigator Application
      • Whiteboard
      • Data
        • Load Data Dialog
        • Supplier Data
        • Production Data
        • Warehouse Data
        • Transport Data
        • Customer Data
        • Other Data
        • Geocodes Data
        • Distance Data
        • Manage Data
      • Data Issues
      • Infeasibility Analysis
      • Circular Flow
      • Control Panel
      • Results
        • Supplier Results
        • Production Results
        • Warehouse Results
        • Transport Results
        • Customer Results
        • KPI Overview
        • Cost To Serve Results
        • End To End Results
        • E2E Lead Time
        • Save and Compare Results
        • Compare Results
        • SC Navigator Specific Icons
      • Center of Gravity
        • Determine Centers of Gravity
        • CoG Settings
        • CoG Run Details
        • Add CoGs to set of Warehouses
        • CoG Trade-Off
      • Risk Analysis
      • Trade-Off Analysis
        • Supplier Scenario
        • Production Scenario
        • Warehouse Scenario
        • Transport Scenario
        • Customer Scenario
        • Control Panel Scenario
        • Network Scenario
        • Data
        • Control Panel
        • Results
      • SENSAI Data Ready
        • SAP-IBP Setup
        • Sheet Type
        • Attribute Visual
        • Attribute Table
        • Group Visual
        • Group Table
        • Filter Element
  • System Configuration
    • Data User Group
    • SAS Tokens
    • File System Management
    • Case Management
  • Data Navigator
    • Configuration Summary
    • Generate Template
    • Import Dataset
    • GIS Location Data
    • GIS Distance Data
    • Data Issues
    • Data Review
    • Data Management
    • Business Unit Management
    • Data Wizard
    • Common Data
    • Settings
    • Glossary of Terms
  • Inventory Planning
    • Phase 1 - Start
      • Start
      • Data Validation
      • Review Master Data
    • Phase 2 - Create Scenario
      • Create Scenario
      • Resource Product Data
      • Scenario Results
      • Re-balancing
    • Phase 3 - Compare Scenarios
      • Compare Scenarios
  • Best Practices
    • How to customize your Login page?
    • Roundtrip Functionality
    • How to Approach Inventory Strategy Decisions
    • How to Use Locations
    • How to Use and Define Groups
    • Which Sheets are Essential
    • What is the Simplest Model
    • How to Transfer SC Navigator Output to the Inventory Planning App
    • How to Get the Most Out of SENSAI Pro
  • Data Integration
    • Accessing Azure Data Lake Storage
    • Exchange Data with SC Navigator
    • Exporting data from SC Navigator into Databricks
    • Importing data from Databricks into SC Navigator
    • Exporting data from SC Navigator into Snowflake
    • Importing data from Snowflake into SC Navigator
    • Exporting data from SC Navigator into Google BigQuery
    • Importing data from BigQuery into SC Navigator
    • Importing data from Alteryx into SC Navigator
    • Power BI
    • SC Navigator ETL Module
  • Release Notes
AIMMS SC Navigator Docs
AIMMS Logo
  • SC Navigator documentation »
  • SC Navigator »
  • Input Template »
  • Template Sheets »
Table Of Contents
    • Products
    • Product Groups
    • UOM Conversions
Product Related Sheets
These sheets are dedicated to detailing all products involved in the analysis, including categorizing them into groups.
Products
Purpose: Define all products involved in the analysis.
Instructions: Enter the details of each product, including product groups. You can read more about attributes on that sheet in Product Attributes.
Product Groups
Purpose: For each product, you can determine which group it belongs to.
Instructions: Assign products to their respective groups by filling in the Product column with the appropriate group and entering the product that belongs to that group in the Subproduct column. Each subproduct must be in a different row and the Active column must be set to 1.
UOM Conversions
UOM Conversions is only available in the Network Design Advanced Module.
Purpose: Define units of measurement (UOM) and the conversion factor to the base UOM for each product.
Instructions: Enter the UOM (if it differs from the base UOM) and conversion factors to the base UOM. You can read more about it in Product Attributes.
Last updated: Aug 08, 2026
Next Previous
AIMMS Logo
Disclaimer Privacy Policy © 1989 - 2026 AIMMS B.V.
