SC NAVIGATOR DOCUMENTATION
  • Getting Started
    • Introduction to SC Navigator
    • Data Separation
  • SC Navigator
    • Input Template
      • Template Sheets
        • Notes, Settings and String Settings Sheets
        • Periods Sheets
        • Product Related Sheets
        • Location Related Sheets
        • Supplier Sheets
        • Production Sheets
        • Warehouse Sheets
        • Inventory Sheets
        • Transport Sheets
        • Customer Sheets
        • Custom Objectives Sheet
        • Transport Navigator Sheets
      • Template Attributes
        • Optimization Parameters and Constraints
        • Product Attributes
        • Location Attributes
        • Available
        • Capacity Attributes
        • Cost Attributes
        • Open/Close Attributes
        • Count Constraint Attributes
        • Ratio Constraint Attributes
        • BOM and Production Routing Attributes
        • Inventory Attributes
        • Transport Attributes
        • Rate Card Attributes
        • Load Consolidation Attributes
        • Lead Time Offset Attributes
        • Customer Attributes
        • End-to-End (E2E) Lead Time Attributes
        • Custom Objectives Attributes
        • Transport Navigator Attributes
      • Group Elements in the Data
      • Count and Ratio Constraints
    • How to Use the Application
      • User Roles and Modules
      • Common Screen Areas
        • Workflow
        • Status Bar
        • Period Selector
        • Filtering in SC Navigator
        • Page Actions and Widget Actions
      • Data Editing
      • Scenario Navigator Overview
        • Structure Overview
        • Scenario Pages Layout
      • Transport Navigator Module
        • Getting Started with Transport Navigator
        • Transport Navigator Technical Details
      • Transport Cost
      • SENSAI Pro: AI Assistant
        • Work with Your Data
        • Optimize and Analyze
        • Tips and Limitations
      • SENSAI Data Ready
        • SAP-IBP Connector
        • Raw Data
      • AIMMS AI Systems - Terms of Use
    • SC Navigator Application
      • Whiteboard
      • Data
        • Load Data Dialog
        • Supplier Data
        • Production Data
        • Warehouse Data
        • Transport Data
        • Customer Data
        • Other Data
        • Geocodes Data
        • Distance Data
        • Manage Data
      • Data Issues
      • Infeasibility Analysis
      • Circular Flow
      • Control Panel
      • Results
        • Supplier Results
        • Production Results
        • Warehouse Results
        • Transport Results
        • Customer Results
        • KPI Overview
        • Cost To Serve Results
        • End To End Results
        • E2E Lead Time
        • Save and Compare Results
        • Compare Results
        • SC Navigator Specific Icons
      • Center of Gravity
        • Determine Centers of Gravity
        • CoG Settings
        • CoG Run Details
        • Add CoGs to set of Warehouses
        • CoG Trade-Off
      • Risk Analysis
      • Trade-Off Analysis
        • Supplier Scenario
        • Production Scenario
        • Warehouse Scenario
        • Transport Scenario
        • Customer Scenario
        • Control Panel Scenario
        • Network Scenario
        • Data
        • Control Panel
        • Results
      • SENSAI Data Ready
        • SAP-IBP Setup
        • Sheet Type
        • Attribute Visual
        • Attribute Table
        • Group Visual
        • Group Table
        • Filter Element
  • System Configuration
    • Data User Group
    • SAS Tokens
    • File System Management
    • Case Management
  • Data Navigator
    • Configuration Summary
    • Generate Template
    • Import Dataset
    • GIS Location Data
    • GIS Distance Data
    • Data Issues
    • Data Review
    • Data Management
    • Business Unit Management
    • Data Wizard
    • Common Data
    • Settings
    • Glossary of Terms
  • Inventory Planning
    • Phase 1 - Start
      • Start
      • Data Validation
      • Review Master Data
    • Phase 2 - Create Scenario
      • Create Scenario
      • Resource Product Data
      • Scenario Results
      • Re-balancing
    • Phase 3 - Compare Scenarios
      • Compare Scenarios
  • Best Practices
    • How to customize your Login page?
    • Roundtrip Functionality
    • How to Approach Inventory Strategy Decisions
    • How to Use Locations
    • How to Use and Define Groups
    • Which Sheets are Essential
    • What is the Simplest Model
    • How to Transfer SC Navigator Output to the Inventory Planning App
    • How to Get the Most Out of SENSAI Pro
  • Data Integration
    • Accessing Azure Data Lake Storage
    • Exchange Data with SC Navigator
    • Exporting data from SC Navigator into Databricks
    • Importing data from Databricks into SC Navigator
    • Exporting data from SC Navigator into Snowflake
    • Importing data from Snowflake into SC Navigator
    • Exporting data from SC Navigator into Google BigQuery
    • Importing data from BigQuery into SC Navigator
    • Importing data from Alteryx into SC Navigator
    • Power BI
    • SC Navigator ETL Module
  • Release Notes
AIMMS SC Navigator Docs
AIMMS Logo
  • SC Navigator documentation »
  • SC Navigator »
  • Input Template »
  • Template Sheets »
Table Of Contents
    • Locations
    • Location Groups
    • Location Period
    • Location Product
Location Related Sheets
This section contains information on locations involved in the optimization, including how these locations are grouped and their period-specific and product-specific data.
Locations
Purpose: List all locations relevant to the optimization.
Instructions: Enter details for each location you want to use in the model, you should define at least one of the following two options to be able to visualize locations on map:
  1. Longitude and Latitude
  2. Street/City/Postal Code/State/Country/Country Code if you want to use geocoding
Location Groups
Purpose: For each location, you can determine which group it belongs to.
Instructions: Assign locations to their respective groups by filling in the Location column with the appropriate group and entering the location that belongs to that group in the Sublocation column. Each sublocation must be in a different row and the Active column must be set to 1.
Location Period
Purpose: Define period-specific settings for locations.
Instructions: Enter data that varies by location and period, like:
  1. Force Open/Close (Open/Close Attributes)
  2. Fixed Cost (Cost Attributes)
  3. Dispatch from Warehouse (Location Attributes)
  4. Receive into Warehouse (Location Attributes)
  5. Custom Objectives data (How to use Custom Objectives?)
Location Product
Purpose: Specify product and period-specific settings for locations.
Instructions: Enter data that varies by location period and product, like:
  1. Rate Card Drop Size (Rate Card Attributes)
  2. Maximum number of Source Locations (Optimization Parameters and Constraints)
  3. Maximum number of Destination Locations (Optimization Parameters and Constraints)
  4. Minimum number of Open Locations (Count Constraint Attributes)
  5. Maximum number of Open Locations (Count Constraint Attributes)
You can read more about attributes on that sheets in Template Attributes.
Last updated: Aug 26, 2026
Next Previous
AIMMS Logo
Disclaimer Privacy Policy © 1989 - 2026 AIMMS B.V.
