Release Notes
SC Navigator 26.12.1
Date November 10, 2026
- New Features
Result overview tables (Single Runs and Batch Runs on the Overview of Solutions dialog, the Select Results Data dialog, and Results Data on the Manage Data page) now show key optimization metrics, including objective values, costs, demand KPIs, open facilities, and custom objectives - allowing runs to be compared at a glance. The Batch Optimization page also shows a detailed result summary in the View Results tooltip.
- Improvements
Several memory improvements have been made, making it less likely that sessions with large datasets run out of memory:
The implementation of constrained CoG optimizations has been improved. They should start solving sooner and use less memory, especially on larger datasets. Results are unchanged.
Loading a dataset now uses less memory when the Transport Ratio sheet is empty: the checks for transport ratios are skipped when there are no ratios to check.
Reading large datasets with many transport lanes now uses less memory, especially when no transport capacities are given.
Center of Gravity drive-time runs with a small maximum drive time now need much less memory and time to prepare the drive-time grid.
With the new attribute ‘Remove Lanes longer than Maximum Drive Time’ on the Settings sheet, these lanes are left out during data processing, so large datasets use less memory. Relax Maximum Drive Time and the infeasibility analysis cannot add these lanes back.
Large models optimize faster and use less memory when nothing restricts how products travel to customers, such as transport or warehouse capacities, minimum volumes or fixed costs. The optimal total cost is unchanged.
Importing an Excel dataset now uses less memory: the data validation keeps less in memory, and memory left over from earlier work in the same session is released before a new import starts.
For some larger models, the performance has been improved when running ‘Solve Constrained CoG’ where the objective is to ‘Minimize Number of CoGs’.
SENSAI Pro now answers capacity questions faster and more reliably. It reads the capacity of a warehouse, production facility or transport lane in one step, without first looking up which capacity step applies.
SENSAI Pro can now answer questions about the KPI Overview page. Ask about cost, revenue, profit, demand fulfillment, lead time, cost per unit or open facilities, for each period or for the whole horizon.
- Bug Fixes
Enabling Load Coloring on the Center of Gravity map caused warehouse locations to disappear.
On the KPI Overview, the custom objective revenue for Transport (Direct) was shown under Transport (InterResource), and the other way around. Each transport type now shows its own revenue.
On the Warehouse Results page, inventory capacity could be shown incorrectly, including being marked as “unlimited” by mistake. This happened when a warehouse’s throughput capacity and inventory capacity used different steps. The inventory capacity bar and its “unlimited” label now match the inventory utilization figure.
The infeasibility analysis can now exceed the maximum capacity of a transport lane by more than 2,500 units when Transportation Capacity is allowed. Before, lanes with a Minimum Capacity, Fixed Cost or Force Open could only go 2,500 units over their maximum, so the analysis could fail to find a solution.
When trying to save results using an invalid name (e.g. an already existing name), the invalid name dialog returned users to the input dataset dialog instead of the save results dialog.
Loading a dataset or saved results while a Trade-Off Analysis or Center of Gravity Trade-Off Analysis was running, and confirming that its results would be lost, did not stop all of its runs. Queued runs still started, and running Center of Gravity runs kept going. Now all runs of the analysis stop.
When the infeasibility analysis stopped at its time limit before finding a solution, it showed “The model is still infeasible, please allow more violations”, which does not help when all violation types are already allowed. It now asks to increase the Time Limit for Optimization on the Control Panel page.
Clicking View Results on the Overview of Solutions dialog for a run that finished with errors did nothing. It now shows a message that the run has no results to load and suggests running the optimization again.
The Relax Minimum Production Capacity and Relax Maximum Production Capacity options also relaxed the minimum and maximum ratios on the ‘Warehouse Ratio’ sheet, while the Relax Minimum Warehouse Capacity and Relax Maximum Warehouse Capacity options did not. Warehouse ratios are now relaxed by the warehouse capacity options. Results may change for scenarios that use warehouse ratios and relax production or warehouse capacity.
SENSAI Pro sometimes indicated that saved results were not available for comparison, especially results saved in an earlier session. It now compares against any saved results you name.
SC Navigator 26.11.1
Date October 27, 2026
- New Features
SENSAI Pro (beta) can now read the detailed results of your model, per warehouse, production facility, supplier, customer and transport lane. This means it can answer questions such as “What is the utilization of warehouse X in period Y?” and “How many units of product X are produced at plant Y?”
- Improvements
Capacity indicators on the Results pages no longer incorrectly show warnings or errors when volumes are effectively within capacity. Negligible rounding differences are now ignored for Supplier, Production, Warehouse, and Transport results.
Memory use and speed has been improved when optimizing with Allow Base Case Volume Mismatch switched on, making it less likely that large datasets run out of memory with this option.
You can now widen the SENSAI chat panel by dragging its left edge, up to half of the browser window width. This makes tables easier to read.
- Bug Fixes
The saving of Results now checks scenario and dataset names before processing and correctly reports failing exports.
Canceling the Save Input Dataset dialog now closes it immediately without running data processing or validation.
The Full Solution Export now ensures that also the Warehouse Definition and Production Definition sheets only contain resources of the corresponding type. Resources classified as both warehouse and production now correctly appear on both sheets.
Geocoding a distance/duration longer than 10,000 km, returned an empty status. Now, it returns “Maximum distance (10,000 km) exceeded”.
SC Navigator now skips unnecessary calculations for customers without a variable cost, which makes the optimization model smaller. Your results and total costs are unaffected.
SC Navigator 26.10.1
Date October 8, 2026
- New Features
A major upgrade to SENSAI Pro (beta). SENSAI Pro has been rebuilt to take on more of your network design work. Describe what you need in plain language, and SENSAI Pro sets up and runs your scenarios, then tells you exactly what it did.
What’s new:
Build scenarios with a single instruction. Add warehouses, suppliers and production facilities, change input data, run the model and compare: “Add a 25% surcharge on all products from our largest supplier, run the model and tell me how total cost changes compared to before.”
Stress-test your network. See how your results respond as demand, capacity or transport cost changes: “Run a demand sensitivity analysis from +10% to +40% in steps of 10%. At which level does demand fulfillment start to drop?”
Explore trade-offs. Change the objective, cap custom objectives or relax constraints: “Limit total carbon emissions to 50000 tons, run the model and tell me how much the total cost goes up compared to before.”
You can also explore your input data, compare saved results and undo data edits, in any language.
Ready to try it? Contact your Customer Success Manager to book an onboarding session. Your free trial starts right after it. See the SENSAI Pro documentation for details.
SENSAI Pro is in beta, so expect it to keep evolving with your feedback.
- Improvements
The ‘Allow Base Case Volume Mismatch’ setting only applied to warehouse locations. Now it applies to demand locations as well.
- Bug Fixes
On page Results - Transport, the Transport Results table now shows the Number of Trips for lanes that use customer rate cards, matching the Secondary and Direct Transportation tables. This also applies to the Transport Results sheet of the Full Solution Export.
Data validation now warns when a ratio on the ‘Transport Ratio’ sheet uses a transport lane that is not available on the ‘Transport Cost’ sheet, because such a ratio can make the model infeasible; previously this was only found by the infeasibility analysis.
SC Navigator 26.9.1
Date October 1, 2026
- New Features
The Maps on the Results and on the Center of Gravity pages now offer the possibility to show labels for the nodes. Through the Node filter on the side panel you can switch them on or off separately for each node type. By default, the labels are not displayed, because they can be a bit overwhelming depending on the zoom level on your maps.
You can now define your own map colors, by name and hex code. To add a new color: go to the Results page, in the map widget action, select Customize Nodes or Customize Arcs. Then in the Color Reference List widget action, select Manage User Colors. Once added, user colors are available for everyone in the same environment. They can be used for node types, flow types and transport modes.
On the sheet TN Vehicles, a new attribute, Vehicle Properties, allows a semicolon-separated list of properties (for example vehicle types or certifications) to be assigned to each vehicle. On the TN Customer Product sheet, two new attributes, Required Vehicle Properties and Forbidden Vehicle Properties, let you restrict which vehicles can serve a customer stop: an eligible vehicle must have all Required properties and none of the Forbidden ones.
On the sheet Transport Trip Data, a new attribute Last Customer Base Cost allows an additional cost per load to be set for a lane. It is charged once per route, for the lane running from the warehouse the route departs from (From Location) to the last customer it visits (To Location). It comes on top of all other transport costs including that stop’s own cost per stop. It supports carriers that price a route by its final stop, which typically applies when vehicles do not return to the depot (Route Ends at Last Stop on the TN Vehicles sheet). The attribute is used by Transport Navigator only; it can be reviewed and adjusted on the new Trip Data tab of the Transport Navigator Data page, and the resulting cost appears in the Route Summary and in the Transport Navigator KPIs.
We added new Warehouse filters to the Center of Gravity page, and introduced a Fixed Locations node filter. The Fixed Locations node filter behaves consistently with warehouse groups node filters. They are shown only when at least one Fixed Location is selected on the CoG Settings page.
You can now freeze part of the Transport Navigator solution, so the solver can focus on the remaining part. This can be done in the Select Route table on the main Transport Navigator page, but this is not available for all runs.
- Improvements
On page Results - Transport, and page Data - Transport, the Source of Distance column now names the method that produced the distance for each lane: Transport Trip Data, Retrieved, Wiggle Factor or Straight Line, instead of only Template or Calculated.
Previously, on the Customize Node Sizes dialog, you could influence node sizes with a slider. However, that slider was limited. Now you can enter a free value to set the node sizes.
We have made some changes such that Initializing GIS Data has improved on subsequent calls.
SC Navigator now warns, both as a data issue and on the Geocodes page, when locations with different addresses are geocoded onto the same point, which makes the distance between them zero and hides them from the optimization.
- Bug Fixes
Service range colors on the map now remain unchanged when customer arcs are hidden with the Transport filter or when suppliers are hidden with the Supplier filter. When the service range is active, customers remain visible on the map even when all their products are filtered out with the Product filter.
On page Results - Customer, the Drive Time Distribution chart has been updated to exclude customers in periods where they have zero demand.
On the Data - Transport page, the spelling of Transportation in the second table header has been corrected.
Custom map settings and zoom level values are no longer reapplied after the map is reset to the default view and the user navigates to another page. Custom settings are now shown correctly after results are loaded.
When saving the data as Input Data and using an already existing filename for it, SC Navigator first did some potentially time consuming data validation before checking whether the name already existed. That name check is now done immediately, saving the user time.
It could happen that after an infeasible solve, the workflow panel on the left side of SC Navigator would disappear.
Previously, changing node sizes did not affect nodes that have an icon which name starts with “scn-“.
Warehouses no longer appear on the Production sheet and Productions no longer appear on the Warehouse sheet of the Full Solution export.
In Transport Navigator, in rare cases, routes that were fixed could be planned with too much lateness.
SC Navigator 26.8.4
Date August 25, 2026
- Improvements
The Gantt Chart on the Transport Navigator - Results page was updated to a faster version.
- Bug Fixes
On page Results - Transport, the option to display non-rounded trip counts has been added to the Transport Results table, consistent with the other transport tables.
In the Full Solution Export, the Transport Results sheet now shows lanes with minimum or maximum transport capacity, even if the model allocates 0 volume to them.
In the Full Solution Export, the sheet name for inter-resource transport results is now consistent across all export flows. When exporting scenarios or multiple cases, the outdated “Transport Cost” sheet name is no longer used; “Inter Resource Transport” is used instead.
SC Navigator 26.8.3
Date August 10, 2026
- Improvements
If an Excel sheet name has a leading, trailing or double space, a data validation error is now raised. The data from such a sheet is not read; remove the space from the sheet name and read the file again.
The documentation for High-level Transport Cost Data has been clarified to better describe the required conversions and Average Load Size.
SENSAI Pro now uses geocoding for real road distances only when a lane needs a distance and the Retrieve Distance attribute is set for that transportation type; otherwise it uses straight-line distances. This keeps distances consistent with the configured data and avoids unnecessary geocoding calls.
- Bug Fixes
SENSAI Pro now applies capacity changes correctly to warehouses that use stepwise (multi-step) data.
Retrieving SAP credentials at startup is now only performed for users with the SAP-IBP Connector module enabled. Retrieving SAP credentials during startup could occasionally fail or time out, which could in turn cause a subsequent session to fail to start correctly.
If there was no Demand Volume (just Demand Weight), Transport Navigator could return a message stating that there was a mismatch in the expected stop count.
For Transport Navigator, the attribute Route Ends at Last Stop was missing from the template.
Documentation was added for the Relax Maximum Drive Time option on the Control Panel page.
When doing scenario comparison using the reference map on the Results page, the “Show Arcs for Arrival/Departure Period” option only affected the active results map. Now it also affects the reference map.
Sometimes the transport costs were incorrectly multiplied by 2 in the End to End report.
The data validation sometimes incorrectly reported missing distance lookups instead of only the lanes that still required distance data.
Several SENSAI chat response formatting issues were addressed: tables now display their grid lines, excess spacing between paragraphs and list items has been removed, and button labels are no longer missing their text.
SENSAI could fail to compare scenarios it had just created, reporting them as “not resolvable”, or show identical values for scenarios that were actually different. SENSAI now refreshes scenario data before listing or comparing, so new scenarios are recognized and compared correctly.
On the Geocodes page, a filter icon has been added to the country filter to indicate whether all countries are currently visible.
On the Geocodes page, changing a country in the Location Data table no longer causes the location to be filtered out immediately. The relevant country remains selected in the filter.
On the Geocodes page, the country filter no longer displays duplicate country entries after a country value is changed in the Location Data table.
On the Geocodes page, Country, City, and State columns have been added to the Output section of the Location Data table.
On the Geocodes page, Geocoding result data is now displayed in the standard output columns, eliminating the separate result columns that previously appeared only after geocoding and only for geocoded locations.
On the Geocodes page, when a new dataset contains countries that were not present in the previously loaded dataset, those countries now appear correctly in the Location Data table when it is opened directly from the Data Errors/Warnings dialog page.
SC Navigator 26.8.2
Date July 14, 2026
- Improvements
The page “Template Attributes” has been split into multiple pages. At the same time, the “Template Sheets” pages and the “Template Attributes” pages now contain cross-links.
The appearance of the workflow panel has been improved.
- Bug Fixes
On the Results - Compare Results page, the delta arrows accompanying cost and revenue objectives now correctly indicate whether a change is positive or negative.
SC Navigator 26.8.1
Date July 9, 2026
- New Features
A new Compare Results page has been added to the Results workflow. This page allows users to compare loaded results more easily and provides a clearer overview of differences between Results Datasets. For more information, see Compare Results.
On the Center of Gravity page, we added five new filters in the side panel for filtering on Customers, Suppliers, Products, Periods and Fixed Locations.
- Improvements
The performance of retrieving geocodes and distances based on addresses has been improved significantly.
Transport Navigator now validates whether a leg duration exceeds 120 hours (5 days). Such legs cannot be planned by Transport Navigator and are typically caused by incorrect or swapped longitude/latitude values in the Locations sheet.
- Bug Fixes
Some pages could have a gray background behind the tab area. This background is now white, consistent with the rest of the pages.
SC Navigator 26.7.4
Date July 2, 2026
- Improvements
The Terms of Use for AIMMS AI Systems have been updated to clarify how telemetry data is processed. Telemetry is now processed on the basis of performance of the contract (Article 6(1)(b) GDPR) rather than consent or legitimate interests. The terms also clarify that telemetry is recorded at the organization level only — no individual user identifier is captured or stored. (See AIMMS AI Systems - Terms of Use for details.)
We made some changes in the startup logic to reduce the time it takes to start the application.
In Transport Navigator, the post-process logic has been adjusted to reduce the number of vehicles used, by combining more trips.
You can ask SENSAI Pro to change multiple data and create multiple scenarios in a single request.
- Bug Fixes
Responses in the SENSAI chat panel are now less likely to be cut off unexpectedly.
Lane creation performance in SENSAI Pro has been improved, especially for large datasets.
SENSAI PRO now correctly receives the results dataset name after saving. This resolves an issue where it could not verify whether the save was successful.
In SENSAI Pro, the “Command” option could appear as being selected, even without accepting the Terms of Use - while the mode was actually running as “Explain”. The selected mode now correctly reflects what is active.
When saving a scenario after data changes, SENSAI Pro now automatically runs the model first to ensure the saved results reflect the optimized outputs, not just raw inputs.
Several Base Case capacity, flow, demand, and lead-time validations are now reported as warnings instead of errors. Related validation messages have also been improved and aligned with Base Case mismatch handling.
In Scenario Navigator, some widgets didn’t have a title and when viewing them using the maximized view, it was not clear what the widget was about. Now, all widgets show their titles in the maximized view.
SC Navigator 26.7.1 introduced a performance issue in the post processing step of the optimization.
Solutions with excess supply and inventory caused solely by zero-cost products are no longer rejected; a warning is shown instead.
A new error has been created to handle the situation where the model does not produce correct results for unknown reasons, and we request that you contact us for further investigations.
In Transport Navigator, the solver sometimes failed to find optimal solutions for datasets containing many Fixed Routes and datasets that require a lot of single-stop routes.
CoG results now show supplier details, including distance, drive time, and inbound volume, consistent with the existing customer results.
Sometimes it happened that after downloading a table’s contents into Excel and making some changes there, uploading the changes back into the table did not incorporate those.
SC Navigator 26.7.3
Date June 15, 2026
- Improvements
Product group definitions no longer require the product name to be listed on the Products tab. Previously, defining a product group required the product to exist on the Products sheet first, unlike other group types (warehouse, supplier, production, customer) which did not have this requirement. This inconsistency has been resolved — product groups now behave the same as all other group types. The related validation warning has been updated accordingly.
- Bug Fixes
Adding a new warehouse using SENSAI Pro could be significantly slower than expected. This was caused by unnecessary geocoding lookups running on every request.
SENSAI Pro did not recognize that a transport data change had already been applied when the new value was zero. This caused SENSAI Pro to incorrectly report that no update was needed, even after successfully applying the change.
SC Navigator 26.7.2
Date June 11, 2026
- Bug Fixes
Map tooltips now correctly show the transported volume for each lane.
In SENSAI Pro, performing an undo on transport data no longer resets custom objectives to 0.
Manual data changes are now preserved when SENSAI Pro performs updates. Previously, SENSAI Pro actions could accidentally undo edits made by users in other parts of the application.
SC Navigator 26.7.1
Date June 8, 2026
- New Features
There are two new attributes on the Production Routing sheet: Minimum Open and Maximum Open. This allows for adding a new type of count constraint to the model. You can now enforce how many production routing combinations must be active within a group.
These new Minimum Open and Maximum Open attributes are also included in the Full Solution Export on sheet Production BOM.
- Improvements
On the Transport Navigator map, the displayed routes are now colored differently to make it easier to distinguish them. Furthermore, when clicking on one of those routes, it gets highlighted such that it stands out clearly from the other routes.
SENSAI switched to a more powerful model; it understands you better and it responds faster.
The multilingual support is improved such that SENSAI always answers in the language of the question asked.
SENSAI Pro now supports copying data between warehouses.
The SENSAI History Filter button has been improved with a consistent icon, stable button size, and a clearer filtered state indicator.
- Bug Fixes
In Transport Navigator, if Maximum Layover Duration was not specified, the Maximum Layover Duration would be set to 0 instead of being unlimited.
In SENSAI Pro, a warehouse created from scratch was missing internal flags, which could cause incorrect behavior.
In SENSAI Pro, copying a warehouse now correctly transfers all related data to the new warehouse.
Undo in SENSAI Pro now correctly reverts all affected attributes (e.g. Force Open, Force Close) when making changes.
In the maximized view, a widget without header could cause the navigation to get stuck in the maximized view.
In the Full Solution Export, when using the same resource ID for both Production and Warehouse entries, the Production sheet could get missing. Production data is now correctly preserved in the generated Excel file.
The Full Solution Export now includes Take or Pay Unit and Take or Pay Cost in the Transport Results sheet.
SC Navigator 26.6.2
Date May 22, 2026
New Feature (26.6.1)
SENSAI Pro is now available for SC Navigator users. Stop clicking through menus — just ask. SENSAI Pro brings an AI-powered chat window to SC Navigator, so you can make data changes, run optimizations, and compare scenarios through conversation. Try questions like:
“Add a warehouse in Berlin, similar to our Munich hub” — new location, attributes, and transport lanes configured automatically.
“Increase LTL transport costs by 5% across all lanes in Germany” — update dozens of lanes in one command, with a one-click Undo if you change your mind.
“Run the optimization with demand at -5%, +5%, and +10%” — generate and save multiple demand scenarios in a single request.
“Which warehouses open or close, and how does volume shift across the network between scenarios?” — instant network comparison, no spreadsheet exports needed.
“What changes have I made so far?” — full session transparency, always.
Try SENSAI Pro for free until July 1st, 2026 — request a demo to get started. Read all the details in the SENSAI Pro documentation.
Bug Fixes (26.6.2)
In Transport Navigator, a fixed route was not handled correctly when it started and ended at the depot. The model would double count the distance to and from the depot.
In Transport Navigator, the following error message could appear: “The url ‘…/tn_task_input.data’ is not an existing file.” After this, the results of the TN optimization run would not be loaded.
In Transport Navigator, the model validates the results of the optimization run. There was an issue with this validation logic, resulting in incorrect validation messages after running the model.
In the Terms of Use dialog for SENSAI Pro, selecting “Cancel” after having checked the “I have read and agree to the Terms of Use” checkbox, would accept the terms of use, even though the user canceled the dialog.
SC Navigator 26.6.1
Date May 21, 2026
New Features
SC Navigator 26.5.2
Date May 12, 2026
- Improvements
The data used to calculate High-level Transport Costs has been updated.
On page CoG Run Details, the “Distances and Drive Times to CoG (Primary Transport)” table has been added for Constrained CoG runs that include suppliers. It shows supplier-to-CoG volumes, distances, and drive times.
Switching from, to and between Center of Gravity pages could in some cases be very slow.
In Transport Navigator, if the input data contains a fixed route that would violate the maximum duty time or maximum drive time of all available vehicles for that route, a data validation error will now be thrown.
- Bug Fixes
In Transport Navigator, Route Distribution charts could incorrectly show “No Data”. These charts now load reliably when route results are available.
Transport lanes with Base Case Volume are no longer filtered out during input processing.
SC Navigator 26.5.1
Date April 20, 2026
- New Features
Transport Navigator now allows many attributes, previously only available on the TN Locations sheet, to be defined at the vehicle level. This enables more flexible, heterogeneous fleet configurations where individual vehicles can have their own attribute values.
- Improvements
Users can now see their SENSAI feedback with highlighted thumb icons that persist after clicking, and can cancel their rating by clicking the same thumb again to send neutral feedback.
When uploading an Excel Template, only .xlsx files are now accepted. When trying to upload unsupported file formats, an error dialog will show up and no processing will take place.
We have extended Transport Navigator with the ability to handle multiple Grouping Codes at one customer location. For instance, if a customer has demand for frozen products and demand for ambient products, the model will now route two trucks to this location, one for each type.
- Bug Fixes
The documentation of the attribute ‘IsIntersection’ incorrectly stated that it was no longer in use. We updated its description and removed the statement indicating that it should not be used anymore.
SC Navigator 26.4.2
Date April 13, 2026
- Improvements
The implementation of almost all tooltips across the app has been improved. This should lead to some minor performance increases on pages where tooltips are present.
The time needed for deleting input datasets, results datasets or scenarios (especially when deleting more than one at the same time) has been reduced significantly.
The time to save results data has been reduced as well.
The geocoding of locations has been improved by mapping unsupported country codes to their administering power countries. E.g. GU (Guam) will now use US in the geocoding request.
- Bug Fixes
Customer lanes were not always displayed on the map after reloading results.
In SC Navigator version 26.4.1, it could happen that the Transport Navigator map did not display all nodes if the map on the Results page was zoomed to an area outside the area where the Transport Navigator nodes were located.
As a result of the changes related to the performance of rate card-related data, a specific case was identified that did not benefit from those, but actually became a lot slower.
In rare occasions, trying to open the Select Results Data dialog could result in the error ‘The fourth argument of intrinsic function “StringToMoment” is empty’. After that, the dialog wouldn’t open.
In Transport Navigator, when the ‘Period Start’ was missing for a TN period, the data validation message would tell you that the ‘Period End’ was missing.
In some rare situations, the TN periods could not be ordered correctly, leading to strange results.
SC Navigator 26.4.1
Date March 30, 2026
- New Features
The SAP-IBP Connector has been introduced, enabling the creation of SC Navigator templates or datasets directly from SAP IBP data. This simplifies the data onboarding process by reducing manual data preparation and ensuring consistency with the SC Navigator data model. For detailed steps on how to configure and use the connector, please refer to the documentation SAP-IBP Connector.
- Improvements
The performance of the various maps in the application has been improved by limiting the internal calculations to the nodes/arcs that are currently visible on a map. That means that when viewing maps on a world scale, the performance will be more or less the same as before. However, when zoomed in to regions with a more limited number of nodes/arcs visible, rendering, zooming and dragging should be faster.
We have removed the following warnings from the model:
WARNING: Product is available/created at a location, but outbound lane is missing
WARNING: Product is available/needed at a location, but inbound lane is missing.
We noticed that a reasonable amount of users received these warnings, while there was no problem in their model. Therefore, we decided that it was better if the model would not generate these warnings.
The performance of calculating rate card-related data has been improved significantly.
A color description has been added to the Cost to Serve Map documentation.
- Bug Fixes
On page Scenario Navigator - Customer, a table width overflow prevented proper display and user input.
SC Navigator 26.3.1
Date March 19, 2026
- New Features
For Transport Navigator, the vehicle attribute ‘Route Ends at Last Stop’ has been added. Vehicles with this attribute enabled will not return to the depot after their last customer stop.
- Improvements
On the Transport Results page, single and group volumes are now displayed in separate columns in the Primary, Secondary, Direct, Inter Resource, and Transport Results tables. Similarly, in the full solution export, the “Volume” column now contains only single values, and a new column has been added for group volumes. The following new columns have been introduced in the respective sheets:
Primary Transport: Primary Group Volume
Secondary Transport: Secondary Group Volume
Direct Transport: Direct Group Volume
Inter Resource Transport: Inter Resource Group Volume
Transport Results: Group Volume
SC Navigator 26.2.5
Date March 13, 2026
- Bug Fixes
In SC Navigator 26.2.4, a number of files were included in the installation package that should not have been included. To avoid any issues related to this, we have removed these files now.
SC Navigator 26.2.4
Date March 12, 2026
- Improvements
The time it takes to open the Results Data dialog has been reduced significantly.
To improve the user experience, all widgets now feature rounded corners.
- Bug Fixes
In cases with separated data environments, it could happen that the model would start with a message like “The datasource is not setup correctly for ‘power bi embedded’.”. This was due to a misconfiguration of the system and has been resolved.
Transport Navigator now correctly enforces the Maximum Number of Stops per Route during post-processing.
There was a rendering glitch that caused some Chart widgets to jump or shift during their initial setup.
In some rare cases, the E2E Lead Time model incorrectly reported an infeasible solution, and the infeasibility analysis did not return results.
SC Navigator 26.2.3
Date February 19, 2026
- Improvements
In Transport Navigator, vehicle group filtering is now available on the vehicle filter.
The initial processing time when entering the Warehouse Results page has been reduced.
When cases are compared on the Cost to Serve page, both Total columns are now hidden. This change was introduced because these columns did not take the current filters into account for the compared cases.
The Transport Costing documentation has been improved.
- Bug Fixes
The Node Type list in the Customize Nodes dialog no longer shows Vehicles.
Transportation Lead Time was not saved when input data was saved as a dataset.
The number of completed runs is no longer displayed in the status bar on the Whiteboard page.
In the Number of CoGs solve, selecting Move to Closest Cities could result in empty longitude and latitude values for the Center of Gravity locations.
The minimum and maximum number of open locations now work correctly when the period is defined using curly brackets. Similarly for the minimum and maximum number of open suppliers, productions, and warehouses.
When the input data for Transport Navigator contained TN Periods with a duration that was not equal to 24 hours, the TN results could be incorrect (or the solve would fail). TN Periods of arbitrary size will now be handled correctly.
Power BI was not working anymore; when opening the page a “Cannot load model” dialog appeared.
Custom costs and revenues are now correctly displayed on the Customer Results page. Production-related custom revenues are now visible in the UI.
All custom revenues are properly included in the Full Solution Export Excel file across all relevant sheets, ensuring consistency between the UI and the exported results.
SC Navigator 26.2.2
Date February 5, 2026
- Improvements
The Service Time (Departure Time minus Arrival Time) has been added to the Route Details table.
When only Transport Navigator data has been loaded, you can no longer run the main SC Navigator model, Center of Gravity, or a Trade-Off Analysis. Additionally the Trade-Off Analysis dialog pages won’t open when the respective workflow step has been entered.
Some transportation results are calculated when needed, and in some rare situations this could be really slow. As a result, the model could be slow when opening the Transport Results page, exporting an Excel file with the results or saving the results. This will now take much less time.
Additionally, the full solution export generation improved in performance by optimizing warehouse output data processing.
The Transport Navigator Results documentation now better explains multiple vehicle dispatches and its counting.
The Transport Cost Data documentation has been improved.
- Bug Fixes
The progress messages during the preparation of an optimization at Transport Navigator have been corrected to reflect the actual actions.
Some transportation results are calculated when needed, and in some rare situations this could be really slow. As a result, the model could be slow when opening a page, export an Excel file with the results or save the results. This will now take much less time.
SC Navigator 26.2.1
Date January 26, 2026
- New Features
A new feature is now available to retrieve transport cost information. High-level transport cost data is available via the Retrieve High-level Cost Data attribute, and detailed cost data can be requested through the Request Detailed Cost Data attribute. For more details on how to use these features, please refer to Transport Cost.
- Improvements
In some situations when working with a big dataset, we have improved the performance of the preprocessing of the optimization model.
Selecting routes on the Transport Navigator main page could take rather long. We improved the performance drastically.
The performance in processing the results in the E2E lead time model has been improved.
In Transport Navigator, the demand data validation message is improved. It now shows a clear list of allowed demand attribute combinations, preventing ambiguous interpretation.
In Transport Navigator you will get an error when starting a TN Solve without having a warehouse selected. In case there are no warehouses to select, this error message is now more informative.
The table headers on the Results - End To End and Cost To Serve pages have been updated to indicate whether they display values for all demand or per unit.
In Transport Navigator, data validation has been added. The model now requires that each TN period has the same length.
Various small performance improvements have been applied.
- Bug Fixes
The data validation could incorrectly report missing Transportation Lead Time data when the data was actually present in the Transport Trip column.
On page Results, the reference map displayed extra nodes when the reference dataset did not match the active dataset.
SC Navigator 26.1.1
Date January 8, 2026
- New Features
Transport Navigator has been extended with the ability to allow flexibility in the delivery day for each customer, through the attribute Pattern Group. This flexibility can be used to balance the warehouse effort through the attributes Minimum Relative Capacity and Maximum Relative Capacity. See Getting Started with Transport Navigator for details.
- Improvements
A new Source Location Weight attribute has been added to the Locations sheet to extend the Maximum # of Source Locations constraint by allowing weighted source contributions. For more details, see the documentation Optimization Parameters and Constraints.
On the COG Settings page, a counter has been added to the Fixed Location selector.
In Transport Navigator, the readability of the main text on the Solve in Background dialog page is improved by adjusting the font color, which was previously too light and hard to read.
In Transport Navigator, the titles on the KPI Summary page are now more consistent.
In Transport Navigator, on page Results, tab Route Summary, some columns have been resized for better visibility.
Additional data validation has been added for Transport Navigator. We now check whether a location serves both as a customer and a warehouse, and this is no longer allowed.
The documentation now includes details on the Allow Base Case Volume Mismatch feature.
- Bug Fixes
When deleting a scenario on the Manage Data page, the Conflicts message referred to Input Datasets instead of Scenarios.
Running Constrained CoG optimization with only Suppliers, could previously produce incorrect results including zero costs and sub optimal CoG locations.
Previously, load consolidation did not work correctly when used together with the Base Case, as minimum shipment requirements were not enforced. Now, minimum shipment constraints are properly respected in the Base Case as well.
Routes displayed on the Transport Navigator map now respond correctly to Customer and Vehicle filters. All calculated routes remain visible at all times; only their selection state changes based on the applied filters.
In Transport Navigator, routes are shown on a map. Each arc on the map represents a leg of a route. The label of the arc shows the number of the leg as part of a route. If an arc represents multiple legs of different routes, the numbers were previously summed in the label. Now they get listed, such that you can easily see that a leg is part of multiple routes.
SC Navigator 25.18.1
Date December 15, 2025
- Improvements
The reading from Excel has been adjusted so that it will continue to read the file when empty rows were encountered. In the past, reading would stop (often with a warning), but now SC Navigator will continue to read the file.
The solver performance has been improved for some rare cases where performance was unexpectedly slow.
Data validation is added for transportation types for which a lead time was specified, but the Mode of Transport sheet didn’t contain a Speed value.
In the Full Solution Export, the deprecated Transport Cost sheet has now been removed after its replacement by the Inter Resource Transport sheet.
Several improvements in Transport Navigator: units are added to table headers and chart tooltips for better data clarity; better readability of some tooltips; preventing SC Navigator solves when using Transport Navigator-only templates; better streamlining of completed optimization notifications.
In Transport Navigator, the “Show Routes” button is now only active, when there is route data loaded.
SENSAI has been moved out of Beta release. The underlying architecture for communication between SENSAI and AIMMS Cloud sessions has been improved to facilitate future AI features.
The product filter on the Results pages, has an new widget action that allows you to toggle whether or not the product selection should impact the location selection. This is useful if you have selected the locations (Supplier, Warehouse, Production) and you want to look at the results for different products. Previously it would change the selected location. This is no longer the case if the switch is set.
The ‘Force Open (Inventory)’ attribute on the Inventory Product sheet now supports curly bracket grouping.
- Bug Fixes
The Balance and Accuracy algorithms for Number of CoG solves, now support cases where all locations have the same demand.
Data validations for the E2E Lead Time model are added to prevent unsupported configurations. The documentation section E2E Lead Time has been updated accordingly.
The Maximum Capacity column has been restored in the Excel template on the Inventory Product sheet.
SC Navigator 25.17.1
Date November 7, 2025
- New Features
SC Navigator now includes End-to-End Lead Time Constraints. This feature enforces a limit on the total lead time across all supply chain stages (supplier, production, warehouse, transportation). For efficiency, constraints are applied iteratively only where violations occur, until all are resolved or the solution converges. This functionality is resource-intensive and disabled by default. See section E2E Lead Time for details.
- Improvements
Calculating whether a lane links to a zone based rate card is made more efficient. This can result in a performance improvement when you use zone based rate cards.
- Bug Fixes
The custom objective cost was not displayed on the Transport Results page when using customer rate cards.
When opening Power BI from SC Navigator, a blank screen was displayed. The connection has been updated to ensure that Power BI loads correctly when launched from SC Navigator.
SC Navigator 25.16.1
Date October 28, 2025
- New Features
We added Transport Navigator sheets to the Full Solution Export functionality. We added the following sheets to the export: ‘Vehicle Groups’, ‘TN Periods’, ‘TN Route Summary’, ‘TN Route Details’ and ‘TN Vehicle Summary’.
- Improvements
The model now supports closing warehouses containing opening inventory. Previously, if your input data included both ‘Opening Inventory’ and ‘Force Close (Inventory)’, the model ignored the Opening Inventory. Now, the model includes the ‘Opening Inventory’. This means all ‘Opening Inventory’ will move out of the warehouse to the appropriate destination instead of being ignored.
The documentation contained a description of attribute ‘Cost per Hour’. However, before the release this was replaced by ‘Cost per Hour Driving’ and ‘Cost per Hour Waiting’ in the application and template. Now, the documentation reflects this as well.
The documentation contained different descriptions of ‘Duty Time’. We now have a unified description throughout the documentations, including descriptions in the template.
We have made another improvement in the performance of SC Navigator.
- Bug Fixes
If you tried to open a Transport Navigator run from a previous session, by clicking on the “All 0 runs completed” in the status bar, without having run a TN optimization run in this session, the results would not be loaded.
SC Navigator 25.15.4
Date October 20, 2025
- Improvements
Several inventory related attributes now support curly bracket groups:
Inventory Product table: ‘Minimum Capacity (Inventory)’, ‘Maximum Capacity (Inventory)’ and ‘Target (Inventory)’ support curly bracket group elements of Warehouse, Location, Period, in addition to the currently supported Product curly bracket group.
Warehouse Product table: ‘Minimum Inventory Cover’ and ‘Maximum Inventory Cover’ support curly bracket group elements of Warehouse, Product, Location, Period.
We have made several improvements in the performance of SC Navigator.
- Bug Fixes
The model option Relax Minimum Inventory Capacity incorrectly relaxed the Maximum Inventory Cover constraint. The Maximum Inventory Cover constraint will now be relaxed when using the Relax Maximum Inventory Capacity option, as intended.
The post processing step in Transport Navigator was sometimes unable to combine routes, resulting in a solution where not all customer stops were visited.
In some cases, the model incorrectly reported an infeasibility, while the infeasibility analysis was still able to find a valid solution without violating any constraints. The affected datasets now run successfully without requiring an infeasibility analysis.
SC Navigator 25.15.3
Date October 14, 2025
- Improvements
We have applied a number of internal code changes to increase the performance in various parts of SC Navigator, including the initialization of the app.
The post-processing functionality in Transport Navigator has been extended, allowing more trips with a single stop to be combined into another trip.
- Bug Fixes
In Inventory Planning, using the network output of SC Navigator for products that represent product groups did not result in the correct network for their sub-products.
In Inventory Planning, on the Compare Scenarios page, the Scenario Stock Values chart now includes elements from scenarios not in the loaded dataset, and base unit conversions for these elements are now correctly applied in the Scenario Stock Units chart.
In Transport Navigator, customer stops with zero demand volume were handled incorrectly, resulting in an unnecessarily large number of vehicles.
Performance has been improved in case Transport Navigator is solved for multiple warehouses simultaneously.
A parameter introduced in 25.14.1 lacked a domain condition to limit its size, leading to excessive memory usage and crashes on large datasets.
In the Balance and Accuracy Number of CoG algorithms, presented results could, in some cases, differ from those selected by the CoG algorithm. Results are now consistent for each Number of CoG algorithm.
Since 25.13.1 the Inventory Planning app, no longer validated for available resource product data for products for which there is no demand at the warehouse. As a result, it also didn’t validate in case of spare parts. For spare parts, the data validation is back now.
SC Navigator 25.15.2
Date October 1, 2025
- Improvements
We optimized some code that is executed after loading result datasets. Depending on your data, this can potentially lead to an improvement in performance.
- Bug Fixes
When attributes were defined using curly-bracket groups, they appeared in the user interface but were missing from the Full Solution Export.
“Cost per Distance” and “Cost per Trip” were not processed correctly at the curly bracket group level when no load consolidation attributes were used. Costs are now applied correctly in these cases.
The new transportation cost calculation introduced in SC Navigator 25.15.1 could have a negative impact on the time it takes to open the Transport result page.
The Warehouse Service Window in Transport Navigator, introduced in SC Navigator 25.12.1, was not handled correctly, leading to slow and non-optimal solutions.
Date September 25, 2025
- New Features
The transportation cost calculation has been enhanced with new attributes on the Transport Cost sheet: Minimum/Maximum Load Size and Minimum/Maximum # of Trips. These parameters determine how the Number of Trips is derived. When at least one of the four new attributes is defined, the total cost is calculated as: (Number of Trips × Cost per Trip) + (Cost per Distance × Distance). As a result, 6 new attributes are added to the Full Solution Export:
Transport Minimum Load Size
Transport Maximum Load Size
Transport Actual Average Load Size
Transport Minimum Number of Trips
Transport Maximum Number of Trips
Transport Actual Number of Trips
- Improvements
Data validation is added for cases where a product is marked available for inventory in only some periods. To model inventory closure in specific periods, keep the product available in all periods and use the Force Close attribute instead.
- Bug Fixes
In rare cases, when quickly zooming in and/or out on a map, the map could get ‘stuck’ between two zoom levels and jump back and forth infinitely.
Mouse wheel zooming on maps did not take the current position of the mouse into account anymore. Instead of zooming in on that point, the map was zoomed in on the exact center of the displayed map.
When moving between 2 pages which contained maps (e.g. between the Results and the CoG pages), the zoom level was not retained anymore. Instead, the map was reset to ‘World level’ again.
Mouse wheel zooming on maps now takes the speed of the wheel into account. So, if you roll quickly, you zoom in/out more coarsely. When rolling slowly, the zoom in/out becomes very precise. Note that the step size can be influenced by your mouse scrolling settings specified for your machine.
SC Navigator 25.14.1
Date September 18, 2025
- New Features
On page Transport Navigator Results, a new tab is added: Route Distribution. It provides interactive histograms and a detailed data table for analyzing route performance. Users can filter by interval, view tooltips with route details, and compare attributes side by side.
- Improvements
Transport Navigator can now handle demand data that exceeds vehicle capacities, enabling multiple shipments to fulfill customer demand.
Page loading speed is improved among CoG pages. The improvement is noticeable when working with certain larger datasets, while smaller datasets may see less impact.
The performance of the algorithm to solve Center of Gravity using “Max Drive Time” and “Constrained CoG” (when the objective is to minimize the number of CoGs) has been improved for some cases, along with the performance of the “Speed” option for the Number of CoGs algorithm.
On page Center of Gravity, on the Node side panel, nodes of type CoG can now be (un)selected in Filter by Node Type.
On both page Center of Gravity and page CoG Run Details, the CoG side panel is added. This allows you to filter on individual CoG nodes.
On page CoG Run Details, the Customer Location side panel is also added.
On page Results - Cost To Serve, Customer, Period and Product Groups have been added to the side panel.
The Clear All Filters widget action has been added to multiple side panels.
A warning is given before deleting all customizations when selecting Reset Map to Default.
Labels and texts are updated in the UI for consistency.
The documentation was updated to be more consistent with the app.
On pages Results - Cost To Serve, and Results - End To End, the Period filter now works independently from the other Results pages.
- Bug Fixes
The Number of Trips was not calculated when a Rate Card Drop Size was defined on either the Customer sheet or the Location Product sheet.
In Transport Navigator, the solver ignored the Grouping Codes specified by the user. Now, the solver does take into account the Grouping Codes and they have been added to the Route Details, Route Summary and Vehicle Summary tabs.
In Scenario Navigator, for Custom Objectives, the attributes Maximum Allowed and Minimum Required were not correctly used when solving the model.
SC Navigator 25.13.1
Date September 11, 2025
- New Features
A new feature “Customer Reallocation” is added to the main map. You can interactively adjust [customer - source] assignments with greater control and flexibility. More information can be found in the section Customer Reallocation.
The ability to provide feedback on SENSAI’s answers has been added. You can now give quick feedback using thumbs up/down buttons, available when hovering over a response in the SENSAI chat widget. Your feedback will help us further improve SENSAI’s ability to provide support.
- Improvements
The Transport Navigator architecture has been improved, making it faster and more resource efficient. Because of this change the Overview of Solutions dialog has an extra tab Transport Navigator Runs Overview (NEW). Here you can load results created with this version. Results from previous versions can be retrieved from tab Transport Navigator Runs Overview.
- Bug Fixes
On page Results - Transport, the transport costs in the Transport Results table were calculated wrong for customer rate card costing in case there were multiple customers on the same location.
In the Inventory Planning app, the data validation no longer validates for available resource product data for products for which there is no demand at the warehouse.
Loading multiple CoG Trade-Off results consecutively from the chart resulted in an error message.
The Time Window End in Transport Navigator was sometimes set to the value of Period Start instead of the value provided in the Customer Product Data.
Date August 25, 2025
- New Features
The Number of CoGs algorithm can now be run from multiple starting points, increasing the likelihood of higher-quality solutions and supporting more efficient network designs. The new CoG setting “Algorithm for # CoGs” allows selection between Speed, Balance, or Accuracy, depending on whether faster results or greater solution precision are required. By default, the algorithm uses the Balance option, the previous algorithm behavior can be reproduced by selecting Speed. Learn more about the new CoG algorithms here.
The Transport Navigator Results page has been extended with a Routes Schedule tab. This tab shows the optimized schedule as a Gantt Chart, making it straightforward to get a clear overview of the schedule at a glance.
Transport Navigator now supports warehouse service windows using two new attributes: Opening Time and Closing Time. See section Transport Navigator Sheets for details.
A new attribute is added: Allow Base Case Volume Mismatch. This allows a mismatch between Base Case Volume inflow and outflow at warehouse locations. It can be set up in the SC Navigator template on sheet ‘Settings’, or in SC Navigator on page ‘Control Panel’.
- Improvements
Next to the already extensive standard list of AIMMS icons, we have added 19 new icons specific for SC Navigator that you can configure for the nodes used on the map on the Results page. Their names start with ‘scn-’ instead of ‘aimms-‘.
The Number of Trips calculation now uses the Rate Card Drop Size for rate card lanes, ensuring it is calculated for rate card lanes as well.
On the Ratio related sheets in the Excel input template, links are added to the E-learning tutorials about ratios.
The step size of a single zoom action in all maps in the app has been made about 3 times more granular. This allows you to more precisely zoom into the exact area on the map that you are interested in. If you want to use a step size comparable to the old situation, please press the SHIFT key when using either the + or the - zoom buttons on the map.
Some improvements to the Full Solution Export have been made: Transport Results now includes Number of Trips, Distance and Duration. Furthermore, the Transport Cost sheet has been renamed to Inter Resource Transport. Both these sheets are kept temporarily, but the usage of Transport Cost is deprecated and it will be removed in 2 months time. This will allow you to adapt anything that depends on the old sheet name.
On page Control Panel, Include in Objective checkboxes are now read only when the objective is not compatible with the model objective (e.g. Total Physical Revenue while minimizing cost).
Combining trips by Transport Navigator has been slightly improved, resulting in a lower total cost.
A new attribute Maximum Drive Time (in hours), has been added to the Transport Cost sheet. This allows limiting drive time in any lane, not just on the customer side. Lanes with drive times exceeding the defined Maximum Drive Time will be excluded from the model.
The new blue color is now applied to the Period Slider and switches.
In the CoG Trade-Off, similar to the regular Trade-Off, the Set Input Data dialog now hides the Run button instead of just making it inactive when invalid input is detected. Cells containing invalid values are now highlighted with a red border instead of a red background.
- Bug Fixes
In rare cases Transport Navigator did not display all generated trips and served customers.
Data validation is added for cases where Include in Model Objective is set to 1 while Scaling Factor is 0, as this configuration excludes the custom objective from the Model Objective.
The table on the Custom Objective Settings dialog page no longer becomes empty after downloading an Excel input template without any custom objectives specified.
The error “There is a base case lane with a source/destination location that does not support the necessary product(s).” was incorrectly generated for curly elements.
SC Navigator 25.11.1
Date July 28, 2025
- New Features
A new attribute is added to the Custom Objective sheet: Percentage Based. It enables modeling tariffs, duties, and taxes. Furthermore, two new attributes were introduced on the Transport Cost and Transport Step Cost sheets for Percentage Based Custom Objectives: Value and Rate. The cost calculation for the Percentage Based Custom Objectives will be as follows: Volume * Value * Rate + Volume * Cost per UOM.
The Charts tab on the Transport Navigator - Results page has been improved. Now the two top charts can also show the vehicles data (which was previously displayed in the two bottom charts). Furthermore, clicking on a location/period bar in either of the top charts will result in the bottom charts displaying the data for that location/period on a more detailed per hour basis.
A new ‘Add Delay’ option in the Period Selector’s right-click menu lets users slow down playback by configuring a custom delay.
Transport Navigator now supports mandatory driver breaks after extended continuous driving. ‘Maximum Drive Time Before Break’ sets the driving time limit, while ‘Break Time’ defines the required rest duration.
- Improvements
On page Results - Transport, a widget action to control whether the number of trips is rounded up, was added to the relevant tables.
A new result attribute ‘# of Customers Served’ is added to the Warehouse Results. This counts how many customers are served by the warehouse. It is visible in the Warehouse Throughput Usage table on the Warehouse Results page and in the Warehouse sheet of the Solution Report Excel.
Data Validation now marks negative values in the Rate Card Drop Size column on the Transport Cost sheet as a FATAL error.
The Bill of Routing table on the Production Results page now includes an Arrival Period column, when applicable.
Upon startup, SC Navigator will perform a complete refresh of the available datasets in the “import” file system. This means that it will remove all existing import datasets from its memory, and rescan the contents of the import file system. Additionally, the widget action Refresh Import File Systems has been added to the table with datasets, on the “Load Data” dialog, as well as the “Manage Data” page. This allow you to do a refresh on demand.
Unnecessary transport lane data is now removed during processing. In some cases, this can lead to significant improvements in memory consumption and performance when reading data.
The performance of the data validation procedures has been improved.
Transport Navigator previously reset duty and drive time automatically upon warehouse arrival, without a layover. It is now possible to require a layover at the warehouse before resetting, by turning off the ‘Reset Duty Time at Warehouse’ option.
- Bug Fixes
If there was no data in the Location Period sheet, the Force Open and Close columns did not show, and the Show All Attributes widget action did not function for the Location Open/Close Data table on the Control Panel page.
On page Results, Arc Customization is now also applied to the Reference Map.
Data validation has been added in case a base case lane has a lead time shorter than the duration for that lane, or if it routes products to a destination that does not support those products.
The solution provided by the Transport Navigator module would sometimes not visit all customers.
In some cases, some data that should have been on the input Data pages, was not displayed there (although it was used in the model). This was data for which the Available flag was not set at that level. Now, the Data pages should show all input data that is in the model.
In the Whiteboard and Manage Data Input Excel download there were faulty Transport Navigator attributes exported which caused reading errors.
The “Select Reference Map” column was occasionally missing from the Results dialog.
On some pages, the secondary page action button covered the primary page action button.
The Production and Warehouse Group sheets were missing when the model was not authorized to use Transport Navigator, while the TN Vehicles sheet was included.
Transport Navigator would fail if you ran the model twice, but after the first run you excluded a vehicle used in the solution.
When comparing results data, the E2E table only displayed data for the active results.
When creating Production Routing scenarios, binary attributes like Force Close were treated as non-binary in the interface, preventing them from being set to ‘off’.
The lead time offset did not work correctly when the model contained period groups in between regular periods.
In some cases, the Cost To Serve and End To End cost report were not correct when using Period Offset.
The Production Routing Data table no longer omits the Period Offset after saving a dataset or loading a saved dataset (rather than Excel).
SC Navigator 25.10.2
Date July 10, 2025
- Improvements
The performance of the E2E report filtering has been improved, and the behavior changed slightly. Previously, if you filtered for a facility, the Cost To Serve data was shown in the End-to-End table for each customer that the facility supplied. Even for demanded products that the facility did not supply. Now, we only show the Cost To Serve data for those demanded products that the facility helped supply.
The main color palette has been revisited to contain more consistent, less harsh but also less warm shades of blue and grey. This means that many elements in the user interface show up slightly different. A few elements, like secondary buttons (seen in dialog pages), the items in some popup menus and the secondary page actions, have received a more prominent palette change.
The Center of Gravity documentation includes a short explanation that load is defined as demand for customers and as the maximum supplier-product capacity for suppliers.
- Bug Fixes
Force Open and Force Close now work as mutually exclusive attributes on the UI. Activating one in the UI (e.g., Force Open) will automatically deactivate the other (e.g., Force Close).
On page Infeasibility Analysis, the Transportation name ‘Allow Missing Lanes’ now includes spaces in the Allow Missing Lanes Details table, and the ‘Missing Inbound Lane’ attribute is now binary in the Locations Without Inbound Lanes table.
On page Data - Transport, an internal error message (”…is not an index”) occurred when opening the page. This resulted in the Transportation Data table to be empty.
Search results in the SC Navigator documentation no longer include outdated content.
In the System Configuration app, the page File System Management did not show any available datasets for the import and export folder. Now, it will show the correct number of datasets.
If the Infeasibility Analysis result contained ‘Allow Missing Lanes’, the two detailed tables on the bottom of the page would still display the default ‘Infeasibility Explorer’ messages instead of directly showing the details.
The Transport Navigator model could drive between locations that were further away from each other than ‘Maximum Distance between Stops’, and the reported distances were strange.
There were two Warehouse Inventory Data Validations that, in some situations, when the data was compared from one period to the next, showed ERRORs falsely.
In some cases, an infeasibility was shown for constraints that were not included in the model. This could happen because the violations were numerically insignificant to the infeasibility optimization. We ensured that such numerical rounding errors no longer show up.
During Scenario runs when ‘Solve in background’ was enabled, there were cases where the ‘Prepare for run in background’ message did not appear, and the status bar did not correctly show the number of remaining runs.
There were additional Production Routing column names written to the Notes sheet starting at column AA when downloading a generated input template.
The SENSAI button is now correctly visible in the interface.
SC Navigator 25.10.1
Date June 30, 2025
- New Features
A new feature “Lead Time Offsets” is added to SC Navigator. You can now define a “Period Offset” at key supply chain steps — Supply, Production, and Transport — to model lead time offsets. More information can be found in the section Lead Time Offsets.
- Improvements
The algorithm to solve CoG using “Max Drive Time” and “Constrained CoG” (when the objective is to minimize the number of CoGs) has been improved. The algorithm should now get a faster solution or get a solution with a smaller gap.
- Bug Fixes
The violation related to Type Count was not shown in the infeasibility analysis.
A data validation error is raised if a base case lane routes a product from a source location that does not support it.
The Windows notification that informs that all optimization runs have finished, always appeared after running a Scenarios Batch Run, even though ‘Allow notifications’ was not checked in the Control Panel.
The Cost To Serve calculation has been corrected for certain cases when both a warehouse and a production were in use at the same location. For example, previously in certain situations, there were products for which the production volume reported by the Cost To Serve was negative if there was inventory for them at the same warehouse location.
The community link on the SC Navigator page in the documentation now correctly refers to the AIMMS Community again.
SC Navigator 25.9.1
Date June 6, 2025
- New Features
A new optimization module, Transport Navigator, is now available in SC Navigator. It enables users to generate multi-stop vehicle routing plans by optimizing fleet sizing and route design, based on real-world constraints. By adding transport-level decision support to SC Navigator’s end-to-end supply chain modeling, Transport Navigator helps bridge the gap between strategic network design and transportation planning. Read all the details in the Transport Navigator documentation. To get more information on modules, or to get access, please contact your account manager or email us at support@aimms.com.
- Improvements
Data validation checks for Transport Ratios have been removed to prevent unnecessary alerts. For Supplier, Production, and Warehouse Ratios, validations are now issued as warnings instead of errors.
- Bug Fixes
The KPI Overview considered only the variable cost from the custom objective costs. It now also includes the fixed, opening, and closing custom objective costs.
Enabling the ‘Only Show Attributes With Data’ option on the Transportation Data page now displays all attributes with data in the Transportation Data table.
On graph axes and in filter side panels, period names are now ordered chronologically instead of alphabetically.
The Model Control panel now always displays all available options.
The KPI report in comparison mode did not display all cost components. Now, all costs are shown in the report.
The Infeasibility Analysis, including Base Case infeasibility, now functions as intended in applicable cases.
When the Overview of Solutions dialog page was opened immediately after a run was finished, the View Results button was not always visible.
SC Navigator 25.8.2
Date May 26, 2025
- Improvements
In the Infeasibility Analysis the penalty for many of the “count” violations were too low. This led to more violations than needed. The penalty violation has been increased to reduce that behavior.
- Bug Fixes
The data for violation of “Maximum # of Open Productions” in the Infeasibility Analysis was no longer visible in the latest version.
In Center of Gravity, after setting ‘move to closest city’ on the COG Settings page and navigating back to the Center of Gravity main page, arcs appeared starting from (0,0) coordinates heading to all customer locations.
We’ve corrected a small but spellbinding typo where “witch” was used in place of “which.”
On the Save As Results Data dialog, after clicking on Download Solution, an error could occur when in the same session the End-to-End Report had exceeded Excel’s row limit.
Custom Objective cost values are now shown as negative values in the Revenue and Cost Overview table.
On page Results - Transport, the Duration data is now shown in the tables.
Previously a malfunction in the data validation for overlapping ‘Open as Group’ curly bracket period groups obscured other data validation messages. This has been addressed and the data validation for ‘Open as Group’ overlapping periods have been corrected.
SC Navigator 25.8.1
Date May 8, 2025
- New Features
SC Navigator now allows you to create rate cards, that are both zonal based (using ‘Rate Card From’ & ‘Rate Card To’) and distance based (using ‘Distance Lower’ and ‘Distance Upper’). This allows for more flexible rate card modeling.
- Improvements
If an invalid or missing Distance Unit of Measurement (UOM) is provided, ‘mile’ will be used as the default. The data validation has been updated to show an error when reading from Excel and a warning when reading from a dataset if the unit is not “km” or “mile”.
Data validation has been added to detect when a Base Case location has no inflow for a product.
The Whiteboard page has been updated to use a new internal mechanism for showing the details of the currently selected Whiteboard node or arc.
The Infeasibility Analysis page has been updated to use a new internal mechanism for showing the details of the infeasibilities. Previously you could determine which infeasibility details to show by selecting them in the top table of the page. In the new situation, this can be done in the two central widgets of the page by activating the relevant tabs on them.
- Bug Fixes
When starting to solve a Center of Gravity model in the background, now a progress message is displayed, telling that the app is preparing for running it in the background.
When solving a Constrained Center of Gravity model, the capacities for fixed CoG locations were not calculated correctly when not all periods were included.
Timestamps in the SENSAI chat now accurately reflect your local time zone.
In some cases, the model was incorrectly identified as infeasible when the dataset contained data for attribute Base Case Minimum Capacity (sheet Transportation Type Product).
The Play function in the Period Selector could occasionally skip periods.
Previously, downloaded solutions and exported results incorrectly included both warehouse and production elements in both the Warehouse Definition and Production Definition tables. Now, each resource element is correctly placed in its respective table.
Spaces at the end of Custom Objective names are now removed from these names when generating the Excel template, to avoid related issues.
Previously, when two users were simultaneously using SC Navigator and one of them saved a result data visible for all users, then that result data would not show up for the other user before restarting the application session. This has been addressed, and the list of result datasets synchronizes correctly with the shared datasets when entering the Result Data dialog.
SC Navigator 25.7.1
Date April 7, 2025
- New Features
We have introduced SENSAI to SC Navigator. SENSAI is an AI assistant designed to help users by answering SC Navigator related questions, including guidance through SC Navigator functionality and process support to enhance user experience. You can read more about How to Get the Most Out of SENSAI Pro in our documentation. Please note that this version of SENSAI is a Beta release. Any feedback is much appreciated and welcome via support@aimms.com.
- Bug Fixes
In SC Navigator 25.4.1, we stopped placing input data files in the Export folder. This feature has now been restored, and the files will be placed there again.
On page Results - End To End, the data in the tables and in the filters is now restricted to those products that matches the selected level elements. Previously, if a certain production facility was shown, it showed the data for all products for those customer locations that have at least one product connected to that production facility. Now, it is limited to the products that are connected to that production facility.
In previous versions, the application could generate a message like “ReadFromFile: Error: Reading parquet file production-routing.parquet failed: The file only has 0 row groups, requested metadata for row group: -1 in Parquet table file ‘production-routing.parquet’” when the application was trying to read an empty file. This has been fixed and the application will now read such files without any problem.
SC Navigator 25.6.1
Date March 24, 2025
- New Features
SC Navigator now offers SC Navigator ETL, a tool that automates data preparation via Microsoft Azure Data Factory by pushing transformed data into the application and eliminating the need for users to import Excel files or configure the REST API connection. This is available as an add-on module; please contact your account manager for more information.
The results of the data validation are now stored when saving an input dataset. The stored data validation results will be read in when loading that dataset, instead of re-executing the data validation logic. This improves the performance of loading a dataset, especially when data validation takes some time. A result of this change is that a new column “data_validation_version” is added to file “_dataset_info.parquet”. This value can be left 0 when you upload your dataset directly to the Azure Data Lake.
- Improvements
On page Power BI, the styling of the Edit/View Mode dropdown list has been improved, such that it no longer looks read-only.
As part of an improvement to the UI and UX of the AIMMS WebUI, the two main font families, Roboto and Montserrat, have been replaced with Inter Variable.
- Bug Fixes
When using the Customer filter, deselecting individual customers from different groups unintentionally removed all customer locations.
The Warehouse filter was missing two widget actions (Switch to Location View, Clear All).
The Supplier Group filter was displayed even when no supplier groups were present in the data.
The change that was made in the previous release (“Limiting the number of source locations could result in an unexpected infeasibility when small Capacity Consumed numbers were used, relative to the amount of products produced.”) could negatively impact the performance for some datasets.
In the release of February 10, 2025, the type of the column “sequence_order” was changed from string to int32. This was not in line with the documentation, and this new version will have the type changed back to “string”.
SC Navigator 25.5.1
Date February 25, 2025
- New Features
The Infeasibility Analysis functionality now has a new option in the Violations table: “Allow Missing Lanes”.
- Improvements
In case of an Infeasibility Analysis Demand Violation, a new reason type has been added: “Missing Lanes”.
Data validation has been added to detect locations that are (at least from one direction) disconnected from the network.
Any input dataset that is saved, now also contains a file (“parquet-input-definition.xlsx”) with an overview of all the attributes in that dataset.
- Bug Fixes
Opening the Filters side panel would display an error message about an unknown identifier.
On page Data - Transport, the Transportation Data table could be empty.
In some cases, the data validation was not able to point out when Inventory Cover was used without available inventory at a warehouse.
On page Infeasibility Analysis, the input data was not appearing in the tables.
SC Navigator 25.4.1
Date February 10, 2025
- Improvements
The exported results are also used in the new Power BI Embedded feature and therefore, the results have been extended with the sheet/files with the element description as well as the sheet/files with the group definitions. Also the following attributes have been added:
Start Date and End Date to Period Definition/period-definition,
Longitude and Latitude to Location Definition/location-definition,
IsSKU, IsUnion, and IsIntersection to Product Definition/product-definition.
The fields “adopted” and “active” in the _dataset_info.parquet file were written as int32. However, if the cell was empty, pandas would interpret this as NaN (Not a Number) and therefore as float. This lead to a situation, where the model was no longer consistent with the file specification. From now on, the model will actually write 0 to prevent this issue.
- Bug Fixes
When using Bill of Materials that create two or more products, the Cost To Serve and End to End reports were incorrect.
On page Control Panel for the table Min/Max Constraints, the Show All Attributes action was not working properly.
In some cases, the constraint “Max # of Sources for Customers” in combination with product groups could result in an infeasible model.
SC Navigator 25.3.1
Date January 28, 2025
- New Features
It is now possible to also run Center of Gravity in the background, allowing you to continue using SC Navigator without interruption, including starting additional solves. Once Center of Gravity runs are completed, a notification and/or dialog page will appear to inform you. If you prefer not to solve Center of Gravity in the background, you can turn off the ‘Solve in Background’ option on the Control Panel page in the Model Control table.
- Improvements
The Take or Pay Costing documentation has been updated. It now includes a more detailed description and also a comparison with Stepwise Transport Costing.
- Bug Fixes
On page Results - Production, the node colors on the map didn’t always reflect the production utilization status. When a location had both a warehouse and production, the node color reflected the utilization status of the warehouse instead.
In SC Navigator 25.2.2 we introduced an improvement, designed to enhance the optimization model for certain datasets with minimum production capacities. However, this change inadvertently caused infeasible solutions for datasets without minimum production capacity.
SC Navigator 25.2.2
Date January 22, 2025
- Improvements
It is now possible to retrieve geo-coordinates and distance/durations for input datasets. This is useful when the input dataset is created by uploading the parquet files directly to the Azure Data lake, outside SC Navigator.
The documentation now includes a User Roles and Modules section detailing user roles, modules, and corresponding access permissions to functionality within the application.
Scenario Navigator editing now features smoother navigation to other pages, enhancing usability and efficiency.
- Bug Fixes
The data validation that checks whether the Rate Card UOM for a product has a conversion to the base unit, should not be applied to curly bracket product groups. This led to incorrect errors.
On page KPI Overview in chart Total Revenue and Total Cost, the profit line was wrong when comparing scenarios. This has been fixed for Results Datasets created in this and future versions.
‘Rate Card From’ and ‘Rate Card To’ was missing from optimization, which could lead to incorrect or infeasible solutions.
Single-case E2E report downloads no longer require a result name entry to proceed without error.
Sum aggregators for Weighted Average Distance, Weighted Average Drive Time, Max Drive Time, Longitude, and Latitude columns are now hidden in the Output Warehouse Locations table.
When the browser language was changed to one with a different format for thousand/decimal separators, it affected how numbers were displayed in table cells. For instance, with the language set to Spanish, entering ‘1000’ would incorrectly show as ‘10000.00’ rather than ‘1,000’. This behavior has been updated to ensure numbers are displayed correctly according to the selected language’s formatting rules.
SC Navigator 25.2.1
Date January 16, 2025
- New Features
For (almost) all tables on all the Data pages, a new action is available in the three dots menu (top right corner of each table): Show All Attributes. This action allows you to view and edit all available columns/attributes, even if they currently contain no data. You can hide the columns without data, by using the action Only Show Attributes With Data.
- Improvements
The Release information dialog that shows up the first time you start a new version of SC Navigator, has an improved look and now shows all the release notes of all previous SC Navigator versions, just like the Release Notes page in our documentation.
The data validation for rate cards was inefficient. The code has been modified to speed up this process.
- Bug Fixes
The calculated rate card cost could be wrong if you used a Rate Cards UOM that was different from Default/Base UOM, in combination with rate card attributes Cost Per Distance, Cost Per Trip, or Minimum Cost Per Trip. If you use this combination in your model, please contact us at support@aimms.com.
SC Navigator 25.1.1
Date January 9, 2025
- New Features
Previously, every SC Navigator user had access to 1 solver. As of Monday January 6th 2025, we introduced Hyperscaling, which means that every user has access to 25 solvers at the same time. Instead of processing scenarios one-by-one (sequentially), multiple scenarios are now solved in parallel, significantly saving users time and boosting productivity when solving multiple scenarios at the same time. You can read more about Hyperscaling in this blog post.
- Improvements
In the previous version, a user was not allowed to load a Results dataset that was created when the user had access to more modules than currently are allowed. This is now allowed without any restrictions, unless it contains data for attributes that are no longer allowed. In those cases, you will still be able to load the data, but you are not able to run and/or save it again.
The documentation has been updated to include detailed instructions on How to customize your Login page?.
Data validation is added to make sure that a ‘Default/Base UOM’ is given when multiple units are used in the input data.
Data validation is added to make sure that Product and UOM combinations used in the Bill Of Material, have an unit conversion specified.
The ‘Save’ buttons are renamed to ‘Save As’, to better match their functionality.
The System Configuration app is by default only available for the Admin user. When other users were assigned access to it, these rights would be reset (removed) after a new release of the System Configuration app. Now, these rights are transferred to the new version of the app.
- Bug Fixes
Circular dependencies in the Bill of Material data previously caused a fatal data validation error saying that the Capacity data is too large. This is resolved and circular dependencies now only trigger the warning about circular dependencies.
In the Data Navigator application, selecting a dataset from the Dataset Overview table and pressing the ‘Load Selected Dataset’ button will no longer result in an error.
The Infeasibility Analysis was not working correctly in combination with the new Solve in Background option turned on. Now the Infeasibility Analysis page correctly becomes visible with the results when viewed using the Overview of Solutions dialog.
An input dataset that was saved, after a results dataset was saved, was not correct. It contained only very limited amount of data, and reading it in, would lead to data validation errors, that were not present before.
In some rare cases with multiple production facilities at one location and inventory build up, the production cost could not be correct, and too much cost was assigned to the System Cost.
SC Navigator 24.14.1
Date December 12, 2024
- New Features
It is now possible to run optimizations in the background, allowing you to continue using SC Navigator without interruptions, including starting additional solves. Once all active optimization runs are completed, a notification and/or dialog page will appear to inform you. If you prefer not to solve an optimization in the background, you can turn off the ‘Solve in Background’ option on the Control Panel page in the Model Control table.
Two new attributes are introduced on the ‘Transport Cost’ sheet: ‘Base Case Minimum Capacity’ and ‘Base Case Maximum Capacity’. These attributes allow for more flexibility in base case modeling.
Another two attribute are introduced on the ‘Location Period’ sheet: ‘Receive into Warehouse’ and ‘Dispatch from Warehouse’. They indicate, respectively, whether all inflow and all outflow should be received/dispatched via a warehouse at the location. See Location Attributes for details.
Several new attributes are introduced on the Production Routing sheet: ‘BOM Fixed Cost’, ‘Force Open’, ‘Force Close’, ‘Opening Cost’, ‘Closing Cost’, ‘Open as Group’, and ‘Initial Status Closed’. These attributes allow for more flexibility in Bill of Material modeling. When exporting results, the Production BOM results sheet will also have new attributes: ‘BOM Fixed Cost’, ‘BOM Variable Cost’, ‘Opening Cost’, ‘Closing Cost’, ‘Force Open’, ‘Force Close’, and ‘BOM In Use’. More information can be found in the section How the Bill of Material works in SC Navigator?.
- Bug Fixes
When trying to download results from older datasets, an error could occur: “Something went wrong when creating the file.” Now, all Results Datasets can be downloaded.
In previous versions, the ‘Grid Distance’ (in Center of Gravity) was not adjusted based on lead time and maximal driving time. This could lead to situations where the grid distance was too large for the given parameters. This version will adjust the ‘Grid Distance’ to make sure that this is always within the recommended upper and lower bound, by moving it to the nearest bound. Theses bounds will now also consider customer ‘Lead Time’.
The “Refundable with Limit” functionality was not working correctly.
A new version of the Inventory Planning app has been published. When starting the previous version (24.10.1), Inventory Planning raised an error. The error prevented you from loading a configuration and dataset.
SC Navigator 24.13.1
Date November 26, 2024
- New Features
The user experience for scenario planning in SC Navigator has undergone a significant overhaul. Key enhancements include a more intuitive layout for Scenario, Network Scenario, and Batch Optimization pages, a streamlined process for creating scenarios, improved visibility of scenario contents, and the ability to edit scenarios, among other upgrades. These improvements aim to simplify scenario planning, boosting user efficiency. Read more about the new Scenario, Network Scenario, and Batch Optimization functionality in our documentation.
- Bug Fixes
Transport ratios specified for a period group (a regular group, not a curly bracket group) in the ‘Period 2’ column of sheet Transport Ratio, were not disaggregated correctly to all periods in that group.
In the Load Data dialog page, you can click on Upload Excel File and then cancel the Excel file selection. If after that, you would load a dataset, a data issue was falsely raised about the file not having been read correctly.
On page Control Panel, several column headers in the tables have been updated to match with the corresponding attribute names.
On the KPI Results dialog page, the label Weight Factor has been renamed to Scaling Factor.
On the KPI Results dialog page, the tables only showed data for the active scenario, not for the compared one(s).
After loading a dataset, the warning “Attribute names have been replaced with newer names.” no longer occurs. This warning will only occur in combination with loading an Excel template.
On page Results - Transport, The highlighting in the Transport Ratio Results table didn’t work when the data was close to the minimum or maximum value.
If you unselected some warehouses on the Warehouse filter, that will also unselect the products that are only used by those warehouses on the Product filter. In that case the Product filter is now also marked as ‘filtered’.
Previously, when uploading files larger than 128 MB, SC Navigator would become unresponsive. Now you will get an error message indicating the maximum file size has been exceeded.
The contents of the file “parquet-results-definition.xlsx” is now consistent with the generated files.
SC Navigator 24.12.2
Date October 14, 2024
- Improvements
The solve time has been reduced. Depending on the size and specifics of the model, this improvement might be hardly noticeable, while in some cases this might have a significant impact.
- Bug Fixes
A change made in the previous version (In some cases with minimum production, the model could be incorrectly marked as infeasible or display the message “A problem occurred during the optimization.”) could in some extra cases, lead to an incorrect solution due to numerical issues.
SC Navigator 24.12.1
Date October 11, 2024
- New Features
A new attribute has been created on the Customer Product Data sheet: ‘Minimum Lead Time Adherence’. This attribute determines what percentage of demand for a given customer, location, product, period combination must be fulfilled within the lead time. When you want the model to take this into account, you have to Relax Lead Time on the Control Panel page.
- Improvements
The custom objectives of type “Risk” are no longer shown on the control panel page. There would never be data for those custom objectives, so keeping it there could lead to potential confusion.
The Risk Analysis page is now initialized after a Risk Analysis is loaded.
We received some feedback based on the changes implemented in SC Navigator 24.11.1, so we made some minor changes to the behavior of the “Filter by Node Type”:
If you (un)select one of the four standard elements (Customer, Supplier, Warehouse, Production), it will (un)select all the groups of the type. This will now also happen if you have elements that do not belong to a subgroup.
Elements that don’t belong to any group, can be shown by unchecking every subgroup, while keeping the related standard element checked.
Groups for which only part of the locations are shown, will now have a gray background in the checkbox and a tooltip to indicate that only some of the related locations are shown.
The full behavior is described in Filters.
- Bug Fixes
After loading an Excel template (without saving it as a dataset), the widgets on page Data - Customer did not all update correctly when making demand adjustments. Now, the Selected Demand widget refreshes after each Adjust Demand iteration and the table Demand Adjustment updates correctly as well.
For Risk Analysis, Profit Decrease is now the same as Cost Increase in case there is no revenue. Previously in this case the Profit Decrease was opposite to the Cost Increase.
The attribute ‘Open As Group’ was not included in the template.
Curly bracket support for ‘Mode of Transport’ was not working correctly for Custom Cost attributes.
Curly bracket support for ‘To Location’ in Stepwise Transport Cost was not working correctly.
When not applying variable cost for a warehouse that is at the same location as a production facility, users could get an error message after optimization: “A problem occurred during the optimization. (…)”
Previously, when reading input from an Excel file, an empty cell in the first column of a sheet was not properly handled. SC Navigator would not give an error message, while it stopped reading the sheet. In this new version, it will give an error message, indicating that an empty cell was found.
On page Data, in the Data Dashboard widget, Suppliers and Supplier groups were not counted correctly.
The geocoding did not work correctly if you specified a Postal Code and Country, but not a country-code. In that case, the model was using a special postal-code setup, while that required a country code. This resulted in inaccurate results; in some cases the returned locations were even outside the requested country.
The file “_dataset_info.parquet”, created as part of a results dataset, still contained capitals and spaces in the header names. In newly generated results, these headers will now only use lower case and underscores in the names.
Some exported parquet files contained columns starting with “unit_of_” that were not expected. These columns will no longer be generated in exported results.
SC Navigator 24.11.2
Date September 13, 2024
- Bug Fixes
When the arcs on your map have been customized at some point, opening the Control Panel page in version 24.11.1 could result in an incorrect error: “The file “modeloptions_settings.txt” cannot be opened: No such file or directory.”
- Improvements
Upon completion of the optimization run, SC Navigator will now popup a system notification, indicating that the solver is ready. This is useful when solving the model takes a lot of time and your are doing something else in the mean time. You can turn this off on the Control Panel page. Please note that the first time, you have to select in your browser that you allow this page to send notifications.
On page Results, on the View Options side panel, the behavior of the “Filter by Node Type” has been adjusted. The new behavior is as follows:
SC Navigator shows those locations for which all groups, to which this element belongs, are checked. (In the past, it was primarily based on checking/unchecking one group, but it was not clear to the user which group that was.)
If you (un)select one of the four standard elements (Customer, Supplier, Warehouse, Production), it will (un)select all the groups of the type. This will not happen if you have elements that do not belong to a subgroup.
If you unselect a subgroup, it will not impact the related standard element. (If you do that, item 1 will turn them all off).
The table no longer shows an icon for groups that have multiple node types.
We changed this behavior to better handle the situation where multiple node types are located in one place, as well as the situation where groups contain multiple node types.
For rate card input data, it is now possible to define negative values. This allows for defining a formula for your rate card cost with a negative component in it (e.g. ax - b). The resulting rate card lane unit cost do need to be non-negative. The data validation has been updated accordingly: instead of checking the input data itself, the rate card lane unit cost is calculated and only when that is negative, it will result in an error.
We removed some unnecessary blank columns from the Excel Template. Furthermore, on sheets with an ‘Attribute’ column, the ‘Description of the attribute’ column is now aligned with the ‘Attribute’ column.
During data validation, when an incorrect date format is used, the following error message will now be displayed: “The attributes ‘Start Date’ and ‘End Date’ need to be valid dates in a date format. That is not the case for date with name …”.
The documentation on the Infeasibility Analysis has been improved. You can now read in more detail what you can do to find the cause of an infeasibility.
The documentation on the End To End Results has been improved, such that it is more clear what the data in the table represents.
- Bug Fixes
On page Results - Production, in the top-right corner, the Bill of Material filter is now applied to the production volume chart. This allows for a more granular view of production data based on specific Bill of Materials produced in a production resource.
Previously, internal flows could occur at locations with two or more warehouses, even if those warehouses lacked inventory capabilities and the location did not have production facilities. This is no longer possible, as internal flows are now restricted under these conditions.
SC Navigator 24.10.1
Date August 20, 2024
- New Features
A new attribute has been added to the Supplier, Supplier Product, Warehouse, Warehouse Product and Production sheets: Open As Group. This attribute allows you, in multi-period models, to indicate that the entity needs to be open or closed for the complete period. There are two benefits compared to how it could be done previously: It it easier to specify and it leads to faster performance.
- Improvements
The documentation has been restructured for easier navigation.
Data Validation will raise an error when the input data includes demand for a product that has no available supply, production, or opening inventory.
For some of the rate card data validations, the maximum number of detailed data validation messages has been set to 10000 in order to limit time spent on data validation.
In the Node Type filters, all customer groups are now by default colored with color “Customer Default”. The color of the groups can still be changed on the ‘Customize Nodes’ dialog page that you can open from the Map widget action ‘Customize Nodes’.
- Bug Fixes
On page Results - End to End, the direct transport lanes (from supplier to customer) were not visible on the map.
When running the infeasibility analysis for a model with multi-step suppliers that do not have capacities specified, the warning message “A problem occurred during the optimization” could appear.
When running the infeasibility analysis for a model with customers that have attribute Maximum # of Source Locations set, the message “No solution found - The model is still infeasible” could appear. Now, this constraint is also handled properly in the Infeasibility Analysis.
For curly production group data, previously the app raised a data validation warning if any step in the individual productions had missing availability data. However, it should only need the availability data for the first step.
In some rare situations, a dataset saved with the previous version of SC Navigator, could no longer be loaded. This has been fixed in this new version of SC Navigator, but it requires you to save the dataset again, from the template.
With this release a new version of Inventory Planning is released as well. In the Inventory Planning app, when exporting a scenario, the Work in Progress data is now saved to the data lake as well.
SC Navigator 24.9.1
Date July 30, 2024
- New Features
If the model has Data Separation and the user is connected to multiple business units/groups, SC Navigator will now show a new item (Business Unit) on the status bar. Users can switch between their different groups using this item.
- Improvements
We have improved the loading of results, for results saved in this version.
The results of the selected CoG Trade-Off Analysis runs can now be exported.
In “System Configuration”, we have removed the “Conversion to Data Lake” page as it is no longer needed. Additionally, the ability to change the data source by clicking on the status bar “Data Source” item has been disabled.
A new option has been added to the Whiteboard Edit Node Info dialog, allowing users to disable the creation of groups for nodes that contain a single Supplier, Production, Warehouse, or Customer.
The exported parquet files have new attributes names going forward, to allow for better support by data platforms like BigQuery and Databricks. The new attributes are all lower case letters (a-z) and underscores, so no more spaces and parentheses. In the generated input definition file “Parquet File Definition SC Navigator.xlsx” (see Download Parquet File Structure) and the generated output definition file “parquet-results-definition.xlsx”, both the old and the new attribute names are present. SC Navigator input parquet files support both names right now, while output files will only use the new names.
- Bug Fixes
When running Trade-Off Analysis or CoG Trade-Off Analysis simultaneously with a Location Risk Analysis, the error message: “awf.data.aimms.session: There already exists a file or directory named…” will no longer appear.
SC Navigator 24.8.1
Date July 19, 2024
- Improvements
The option ‘Results visible for everyone’ is now available when saving CoG Trade-Off results.
On page Data - Production, 2 new tables were added with input attributes that were already in the template, but not yet visible in the app: Bill of Material Data and Production Routing Data.
On page Data - Other, 3 new tables were added with input attributes that were already in the template, but not yet visible in the app: Bill of Material Groups, Mode of Transport Groups, and Use Description.
On the Whiteboard, transport lanes that are not permitted, can no longer be drawn. E.g. lanes from warehouses to suppliers.
- Bug Fixes
In version 24.7.1, attribute Inter Resource Number of Trips was added to sheet “Inter Resource Transport”, while it should have been added to sheet “Transport Cost”. It is now in that sheet, and the sheet “Inter Resource Transport” is not longer in the results file.
SC Navigator 24.7.4
Date July 12, 2024
- Bug Fixes
In some specific cases, Zone Rate Card data was not processed correctly, resulting in fatal errors during the Data Validation. When you didn’t get fatal errors, your Zone Rate Card data was already processed correctly.
On pages Data - Warehouse and Data - Supplier, the filter now works well for both Warehouse and Supplier groups.
Product Needed volume in case of multi-level BOMs was not taken into consideration correctly when calculating virtual maximum capacities. (The model allows unlimited capacity however in the actual model a maximum value is required.) This could have generated an error message: “A problem occurred during the optimization. Please contact user support (support@aimms.com) to solve the problem before using the results of the optimization.”
SC Navigator did not allow for flows between a production facility and warehouses at the same location, and this could lead to infeasible models.
In some cases, the model could return an infeasible solution, without notifying the user of this. That resulted in negative values for some results that should be positive. We have made some changes that should prevent this kind of behavior.
When a dataset has a very large number of customers, the customer nodes should not be visible on the map by default. However, for customer groups, the nodes were shown.
On page Results, the Reference Map did not show locations that are part of a compared case but not part of the active case.
In some rare cases, the System Cost could not be calculated correctly. This could happen when the model contains other System Cost, next to System Cost related to Supply/Production/Warehouse/Transport.
SC Navigator 24.7.3
Date July 5, 2024
- Bug Fixes
On pages Trade-Off Analysis and Center of Gravity - CoG Trade-Off, dots in the charts now display the right colors that match the state of the run.
On pages Results - Transport, and Results - Full Solution Export, the values for ‘Number of Trips’ are now rounded up.
Product Group Minimum Capacities and Base Case Volumes were not taken into consideration correctly when calculating virtual maximum capacities. (The model allows unlimited capacity however in the actual model a maximum value is required.) This could have generated an error message: “A problem occurred during the optimization. Please contact user support (support@aimms.com) to solve the problem before using the results of the optimization.”
On page Center of Gravity - Details, the Fulfilled Demand column is now correctly displayed when solving for Number of CoGs or Max Drive Time. This column got hidden unintentionally.
SC Navigator 24.7.2
Date June 27, 2024
- Improvements
On pages Data - Production and Results - Production, a BOM filter is added.
- Bug Fixes
It was possible that certain datasets were not visible in the dataset overview, while they were there before. They will now be visible again.
On page Results, at the View Options side panel, it was not possible to unselect ‘Supplier’. Also, the visualization of customer groups was not correct, all customer nodes were colored the same.
After selecting a big Excel template file to upload on the Load Data dialog page, there was no visual indication that the file was being uploaded. This could result in confusion about whether the file was being processed or not. Now, after selecting the file, a transparent veil and a message are displayed, indicating that the file is being uploaded.
SC Navigator 24.7.1
Date June 24, 2024
- New Features
The ‘CoG’ and the ‘CoG Trade-Off’ functionalities have been extended with the ability to do a Constrained CoG. The Constrained CoG allows you to perform CoG calculations, but it can include capacity constraints on the number of CoGs, the new CoG throughput, the existing Warehouses, and the existing Suppliers. Please know that a constrained CoG model is a simplified model to determine potential warehouse locations, and you are advised to run the generated CoG solution through the full SC Navigator model. More information on Constrained CoG can be found in the documentation.
From now on, Scenario Batch runs can be run in parallel in the background, allowing the user to use other features of the software while waiting for the results of the Batch Run. The number of concurrent solver sessions in your license will determine how many solves can be run in parallel. Please contact your account manager if you would like to increase the number of concurrent solver sessions.
- Improvements
On page Data - Manage Data, a new column (# Results) has been added to the tables Input Datasets and Scenarios, so that you can see the number of Results datasets that are build on top of this dataset/scenario.
On page Data - Manage Data, the Results table did not show Results Dataset that somebody else created, but did not share. They are now all shown, so that they can be deleted if needed.
On page Results - Transport, the ‘Number of Trips’ column is added to the ‘Primary Transportation’, ‘Secondary Transportation’, ‘Direct Transportation’, and ‘InterResource Transportation’ tables. The number of trips is calculated based on the volume and the average load size.
On page Control Panel, in the Model Control table, the ‘Optimality Gap for Optimization’ value is now shown with all digits in the tooltip.
- Bug Fixes
On pages Results - ‘Cost to Serve’ and ‘End To End’, the ‘Customer Revenue’ was the average revenue (by period) instead of the actual revenue.
An “-” in the name of a custom objective could lead to a situation where the custom objective was not calculated at all.
The Product Filter on production-related pages did not include all the production-related products. This issue also had an effect on the maps showing Production locations. Production locations with all products unselected were still shown on the map, and the volume shown on the tooltip of the Production location was not correct.
It is now possible to download the template from the Whiteboard without location data (a warning will be given instead of a fatal error). This makes it possible to make use of Excel while providing the location data.
On page Results - Transport, the Volume by Mode of Transport chart showed all transport modes instead of only the available ones.
During the development of CoG Trade-Off some bugs appeared in the normal Trade-Off Analysis which are now fixed.
SC Navigator 24.6.2
Date June 13, 2024
- Bug Fixes
In the previous release, SC Navigator 24.6.1, you could run into an incorrect infeasibility caused by rate bands with no ‘Distance Lower’ and ‘Distance Upper’ data. These rate bands were not possible to be selected for any lanes. Therefore the app concluded that the model was infeasible, while actually it should be possible to select these rate bands.
Also in the previous release, the border of the customer nodes in the map was not as clear as before.
On page Results - KPI overview, clicking on the top middle chart could result in an error.
SC Navigator 24.6.1
Date June 10, 2024
- New Features
The rate card functionality has been extended with two new attributes: Rate Card From and Rate Card To. This allows the user to model zone rate cards that have different prices depending on the origin (e.g. country/state) and destination (country/state) combination. For more details please read about Rate Card Attributes in the documentation.
- Improvements
On the Load Data dialog page, we’ve improved the Upload Excel File experience. After selecting your Excel file, this file will directly be uploaded and you no longer have to explicitly click on the Upload widget again. This will prevent users from accidentally clicking the Load (dataset) button when trying to upload an Excel file.
We have added two new sections to the SC Navigator documentation: Best Practices and Data Integration. The Best Practices section contains articles on using SC Navigator to address various supply chain challenges. The Data Integration section provides guidance on setting up data integration between SC Navigator and external data sources. We will continue to add more articles to these sections in the future.
On pages Results - Cost to Serve and End to End, the System Cost is now split into four different categories: Supply System Cost, Production System Cost, Warehouse System Cost, and Transport System Cost.
We have improved how some data was stored in the Azure Data Lake. As a result, the first time you open the application will take a little bit longer.
In the Node Type filters, you can now filter for Customer and Supplier groups in addition to Production or Warehouse groups. This also means that if your Customer and Supplier nodes are part of a group, they will now use the new group coloring.
When “Move to closest cities” is enabled in the CoG settings, the name of the CoG includes the name of the city where the application places the CoG. Now, also the country where the city is located will be included, and if that city is in the United States, the name of the CoG will also include the state.
- Bug Fixes
In some rare situations, AIMMS SC Navigator could throw you out of the application (bringing you back to the login page) when loading a dataset, for no reason at all. Now you can continue to use the app after the dataset is loaded.
On the Edit Supplier Node Info dialog that can be accessed from within the Whiteboard page, the Supported Products selection was empty by default in case of a model without any Raw Material. Now, by default the Finished Product Group will be selected in this case.
After running the Infeasibility Analyzer, the KPI Summary dialog can show a very high or low objective value. This is caused by the violation penalty that the Infeasibility Analyzer uses to solve the model. However, this information was not visible on the KPI Summary dialog. An additional row is now added to the top left table there, containing the violation penalty. The cost values are now consistent with the objective value, also when an infeasibility analysis is run.
In some rare occasions, SC Navigator could generate a message like this “String length XYZ exceeds maximum of 1024 in Parquet table file …” (where XYZ was greater than 1024) and prevented you from reading the data. This message will not be shown anymore and you can read the data without any issues.
SC Navigator 24.5.1
Date May 21, 2024
- New Features
Ratio constraints have been added for Suppliers, Productions, Warehouses, and Transport Lanes, allowing the SC Navigator optimization model to capture business rules better. You can use this feature via the new sheets in the template: Supplier Ratio, Production Routing Ratio, Warehouse Ratio, and Transport Ratio. You can read more about Ratio Constraint Attributes in the SC Navigator documentation.
A new attribute ‘Maximum Road Distance To Retrieve’ can now be specified for any transport mode on the ‘Mode of Transport’ sheet in the template. As a result, when retrieving road distance data, if a lane is using a mode of transport for which Maximum Road Distance To Retrieve has been specified and the straight line distance for that lane is greater than the Maximum Road Distance To Retrieve, then the distance is not retrieved and the straight line distance will be used for that lane.
Next to the Trade-Off Analysis that we introduced earlier this year, you can now also do a Center of Gravity Trade-Off Analysis. You can do this on the new Center of Gravity sub page ‘CoG Trade-Off’. You can set up and run multiple Center of Gravity runs here. During the runs the user can continue the work at other parts of SC Navigator and can return to check the results when the runs are ready. For more information, please read CoG Trade-Off in the documentation.
- Improvements
A new data validation warning has been introduced to indicate whether the roundtrip attribute is used for lanes other than inter-resource lanes.
The behavior of Download Solution on the Save Results Data dialog has changed. Previously, it would only export the current data to an Excel file. However, in the new version you can export multiple results datasets to a single Excel file. You can read in the documentation how to use Download Solution for downloading multiple results datasets.
You can now also filter data in tables on dialog pages. For instance, this allows you to use filtering when trying to select an input or results dataset.
The performance of the whiteboard when working with a large number of locations has been improved.
- Bug Fixes
On page Trade-off Analysis, the selected secondary y-axis was not saved into the Trade-Off Analysis Results Datasets, so when the saved data was loaded, the secondary y-axis was not initialized properly.
On page Center of Gravity, for the Cost Breakdown widget, the bar colors are now consistent with the legend colors.
The validation logic for country codes (on the Location sheet) now checks both the “Country” and “Country Code” columns to ensure data integrity. Previously, it only checked the ‘Country’ column.
If one or more of the following attributes on the Location sheet contained only empty spaces: “Street”, “City”, “Postal Code”, “State”, or “Country”, the generated geo coordinates could not be saved to the database.
On page Results - End To End, the table contained a column called ‘Warehouse’. This column is now correctly named ‘Production’.
The playback action of the period slider could sometimes skip periods.
The element ‘cts_e2e_dummy’ was included in the “End to End Report”. This is an internally generated element that should not have been included in that report.
Uploading an Excel template with extensive data in the Supplier Product sheet could be extremely slow.
We have adjusted an internal solver setting to improve the performance. However, in the unlikely situation that this change negatively impacts the performance, please contact us for assistance.
Previously, exporting CoGs to the SC Navigator dataset would assign excessive transportation cost data. Now, when exporting CoGs, they will inherit the relevant transportation cost data from their associated location group.
SC Navigator 24.4.3
Date April 15, 2024
- Improvements
On page Control Panel, the elements in the “Min/Max Constraints” table has been ordered logically, min before max, and to: suppliers, production, warehouses and locations.
You can now see the Total Physical Cost and/or Total Physical Revenue in the Trade-Off Analysis, even when this is not included in the objective.
The attribute “Use Description Resource” was renamed to “Use Description Warehouse/Production”.
On page Whiteboard, the center and zoom level will now be included when saving a whiteboard dataset. Upon loading a whiteboard dataset, the whiteboard will retain its previously saved view, eliminating the need to manually adjust the center and zoom each time.
- Bug Fixes
On page Results - View options side panel, in the Filter by Node Type widget, curly bracket group names are no longer shown in the list. This change prevents the confusion caused by the duplication of group names with and without curly brackets.
On page Center of Gravity, the Transport Filter selection is now kept when refreshing the page.
On the Customize Nodes dialog and Customize Arcs dialog, the Color Names in the Color Reference List have been updated and made consistent with the corresponding colors.
On pages Results - Supplier / Production / Warehouse curly bracket groups are no longer appearing in the charts.
In the template on sheet “Products”, the description of the link to e-learning material is corrected.
The model previously allowed invalid flow scenarios where materials were routed through production facilities acting as intermediary warehouses, which in some cases resulted in a cheaper transportation cost. The model has been updated to prevent this unrealistic flow.
After exporting a scenario in Inventory Planning to Azure Data Lake Storage, an error could occur. The data was exported, but the scenario could not be marked as ‘adopted’.
Previously, when a product could be manufactured at multiple production resources, the End To End page would incorrectly display the total production volume duplicated for each production. This resulted in an inflated total volume being shown. The End To End page now accurately displays the shared volume allocation for each production resource involved in manufacturing the product.
In System Configuration 24.4.2 after changing the data source, the secondary page action ‘Set Data Lake (or Database) as Data Source’ remained inactive with the text ‘Data Lake (Database) already set as Data Source’, while that was not always the case.
In the System Configuration app, the status bar displays what data source is used. Previously, the app always displayed ‘Database’ as data source at startup of the app. Now the data source is properly initialized.
SC Navigator 24.4.2
Date April 4, 2024
- Improvements
The tooltip of the UOM item on the the status bar, now shows all Unit of Measurement information. So, it shows the UOM for currency and distances as well.
In Center of Gravity, when adding CoGs to the set of Warehouses, you had to specify both a location and a warehouse group to which the CoGs would be added. From now on, only Location Groups are mandatory. Warehouse Groups are optional.
On the Results sub pages, when comparing multiple results datasets, the layout of the top right chart is now consistent for the several pages with regard to the order of showing the period and results datasets.
This new version gives a warning when the “import” file system (where you can upload your own datasets, see Details for details) is not structured correctly.
The Transportation Load Size data validation functionality is updated. There used to be two validations for these issues, a warning and an error. From now on there will be only an error message to indicate when Average Load Size data is missing.
- Bug Fixes
If you asked the model to calculate the distance/duration between two very close locations, it could mark them as “unable to calculate”, while it should mark them as 0 distance instead.
After loading an SC Navigator results dataset and running Center of Gravity afterwards, sometimes the generated CoG locations did not display on the map.
The name of the sheet “Bill Of Material Groups” generated by the whiteboard was misspelled and therefore the sheet was not picked up correctly by the model.
A dataset with multiple periods could be infeasible after adding CoG results to the model.
The model would allow you to save scenarios that were longer than 64 characters, but would not read them in correctly. Now, the length of a scenario can be up to 160 characters. You will not be able to save scenarios with a name longer than that.
Customers without demand on the Customer Product Data sheet will no longer cause a data validation error.
After loading a results dataset, the model could give an error with respect to reading from database tables. This only happened if your system has been converted to Azure Data Lake Storage, and you loaded a results dataset that was created before your system was converted.
Inventory Planning gave an error when your data was transferred to Data Lake Storage. With this release a new version of Inventory Planning is released as well. This version can read/write data from/to Parquet files in Azure Data Lake Storage, just like SC Navigator can.
SC Navigator 24.4.1
Date March 19, 2024
- New Features
The System Configuration app has a new page “Case Management”. This allows you to move Results Datasets (that are not shared) from one user to another. This is needed, when one user leaves their role and another user is taking over this role and needs access to the saved results.
- Improvements
Data validation is added for the Whiteboard feature. Now, before the template is downloaded, the application will automatically validate the data and if any issues are found, it will show these in dialog.
Another new data validation was added to the model. It will now give an error when there is a location without any supplier, warehouse, production, or customer on it, but there is a lane defined for it.
The tooltip of the “Help” button in the bottom right corner (on the status bar) now indicates that it guides you to both the documentation and the release notes.
On the Save Results Data dialog for saving Trade-Off Analysis Results, the “Results visible to everyone” switch is added, such that you can now also share Trade-Off Analysis results with other users.
We improved the Trade-off Analysis code from a technical point of view, such that we can modify it more easily in the future.
The performance of models with a high number of locations has been improved.
- Bug Fixes
In rare instances, after running an optimization, it is possible to receive the warning message “A problem occurred during the optimization (…)”. This message occurs when the app concludes that for that specific situation, it used too strict constraints during the optimization. We have adapted the model such that the constraints are no longer too strict in this case.
The “Production Routing” Minimum and Maximum Capacity were incorrectly scaled when loaded from a dataset created in version 24.2.1 up to 24.3.3. Those datasets will continue to have this problem, however after this fix newly created datasets will not have this problem. When you use “Production Routing” Minimum and/or Maximum Capacities, we advise you to reload your data from your Excel template and save it as a new dataset with this new version of SC Navigator.
After the recent update of the map colors, some custom node and arc color settings were prompting a warning message stating that a color “is not an element of the checked set Map_ColorPalette”. Custom map color settings will no longer cause this warning.
After a dataset or results dataset was deleted, the name was not removed from all lists, so it could still be visible.
On page Center of Gravity, in rare cases, the algorithm behind the Solve Max Drive Time button could result in an Error: “The model was not solved, most likely due to an infeasibility”. This could happen when some locations were distant from real cities, such that the algorithm was not able to generate a viable CoG location within the specified Maximum Drive Time. These distant location are now considered themselves as possible CoG locations, such that the model that is part of the algorithm, is no longer infeasible.
On page Center of Gravity - CoG Settings, in widget General Settings, the transportation speed is now used correctly when calculating the drive times in Center of Gravity.
On page Center of Gravity, in the Demand/Supply Distribution map, the Center of Gravity locations were not visible when loading a CoG results dataset, although the location latitude and longitude data were visible on the CoG Run Details page.
When downloading the model output, the ‘Force Close’ attribute would not be exported to the Supplier sheet.
Transport lanes were not appearing on the reference map when comparing results datasets that contained different products.
Opening and Closing Costs were not applied in single-period models. This behavior has been adjusted such that these costs will always be applied when Initial Status Closed is set to 1.
It was possible that Whiteboard Results would disappear from the list where they can be loaded, this version fixes that problem for the future. However, this does not fix Whiteboard Results that have already disappeared. If that happened to you, please contact us so we can fix this manually for you.
SC Navigator 24.3.3
Date March 4, 2024
- Bug Fixes
After conversion to Azure Data Lake Storage, the loading of the scenario overview could be slow, depending on the number of scenarios.
SC Navigator 24.3.2
Date February 29, 2024
- Improvements
We have updated the average distance calculation in Center of Gravity from an arithmetic mean to a weighted average. This new calculation takes into account the relative volume/importance of each location, giving a more accurate representation of the proximity of each CoG to its locations.
We have made some internal changes to the model that reduced the memory footprint of the application.
On page Whiteboard, the Transport Product Data table now also includes an ‘Average Load Size’ column. This data will be included in the template that you can export from the Whiteboard.
- Bug Fixes
A fatal error is now given if an Excel sheet is missing a mandatory column. The improved message clarifies on which sheet the error occurred.
The CoG locations were no longer shown on the map in SC Navigator 24.3.1; additionally, the tabulated latitude and longitude of the CoG locations was not visible.
In situations with constraints on both “Min # Warehouses” and “Minimum Capacity”, the model would open warehouses that did not satisfy the minimum capacity requirement. Warehouses will now only open if the “Minimum Capacity” constraint is satisfied.
The “Minimum Capacity” and “Maximum Capacity” attributes on the “Production Routing” sheet, added in version 24.2.1, were not in the generated template. However, they were used if you added them manually to your Excel file.
When using transportation lanes that have ‘Retrieve Distance’ set, in combination with locations that were added from Center of Gravity, the model would generate an error about missing distance data. Furthermore, it was not possible to retrieve the actual distance as those lanes were not shown on the Distance page. Now, the model will bring up the Error dialog and it will give you the option to navigate to the Distance page where you can retrieve the distance for these lanes.
Capacities defined for {Period} groups were not incorporated in the model, if there were also capacities defined for individual elements in that group.
The attributes ‘Minimum Inventory Cover’ and ‘Maximum Inventory Cover’ were not included in the Excel template.
SC Navigator 24.3.1
Date February 26, 2024
- New Features
The Whiteboard feature has been added: a powerful tool designed to streamline supply chain modeling. This innovative feature allows you to create a diagram of your supply chain network and translate it into an Excel template. The Whiteboard enhances the speed and accuracy of supply chain modeling, while also serving as an introduction to the SC Navigator approach of capturing the behavior and configuration of real-world supply chains in a spreadsheet. More information can be found in the Whiteboard documentation
- Improvements
The Inventory Cover functionality has been improved by introducing “Maximum Inventory Cover”. The attribute “Inventory Cover” has been renamed to “Minimum Inventory Cover”. With these attributes you can set the minimum / maximum number of next periods’ outflow covered in inventory.
On page Results - Transportation, the Transport Results table is added, showing all transport lanes including their capacities.
The node colors on the main map have been updated to improve visibility and to better distinguish between different nodes and resource groups. The old colors are still available via the widget action Customize Nodes on the main map.
- Bug Fixes
The Enforce Base Case Constraints option was not handled correctly when applying this via the scenario functionality. As a side effect, checking or unchecking that option will be faster.
The Trade-Off Analysis did not work correctly. The model would sometimes report the solution incorrectly as infeasible.
The changes made in version 24.2.1 with respect to group count constraints could result in very slow performance in instances with a high number of suppliers, productions and/or warehouses. This new version resolves those slowdowns.
The “Risk” attribute for custom objectives was not populated correctly when generating templates. Values were written to the column of attribute “Refundable with Limit”.
SC Navigator would report models with inventory and {warehouse group} capacity constraint incorrectly as infeasible. This was due to a constraint being enforced for group values, but for one variable (outflow) the flow was calculated but for the other variable (inventory) it was not.
The template was not generated correctly when custom objectives had a “-” in their name.
When a custom objective was renamed, its previous name was still taken into account.
When capacities were only defined at the product level, the tooltips of the charts on the result pages did not show them.
On page Trade-Off Analysis, the Run button could be pressed multiple times, triggering more runs than needed.
On page Center of Gravity, if the option Move to Closest City was selected, the tooltip and the result tables used different names for locations.
When there was a Trade-Off Analysis run in progress and a new Trade-Off Analysis run started with a newly loaded dataset, the previously started runs and the new runs were conflicted.
The Data Validation was numerically more strict than the network constraints.
On the Circular Flow page and the Load Optimization Results dialog, some internal names were visible. These are now properly translated to understandable names.
Forced Flow data validation with active inventory was not working correctly with groups.
SC Navigator 24.2.1
Date February 15, 2024
- New Features
The name of the uploaded Excel file will now be stored together with the dataset. It is shown in dataset overviews. This allows you to see what the source of the data is.
The model has been extended with two attributes “Minimum Capacity” and “Maximum Capacity” on the “Production Routing” sheet. That allows you to specify the capacity for a Bill of Material. (This value is in the same capacity unit as the data on sheet “Production”.)
A new sheet has been added: Bill of Material Groups. This allows you to create groups of Bill of Materials, in the same way that you create Product and Supplier groups. You can use {BOM} groups for the above-mentioned Minimum Capacity and Maximum Capacity. These capacities are also shown in the Results - Production page, as well as in the Excel and Database/Parquet results.
The Minimum and Maximum # of Open Suppliers/Productions/Warehouses attributes have been added to the Supplier, Production, and Warehouse sheets in the template. These allow count constraints to be added for curly bracket location, supplier, production and warehouse groups. More information on count constraints can be found in the documentation: Count and Ratio Constraints.
- Improvements
On page Results - Warehouse, when comparing scenarios, the “Throughput, Inventory” chart groups results by dataset.
After feedback from various users, we have adjusted the behavior of the model when using a Bill of Material that is specified over multiple production facilities in the “Production Routing” sheet. In previous versions, such a bill of material was required to use all facilities. The current model can pick one or more, depending on how much production capacity is needed. If desired, the old behavior can be achieved, by creating multiple Bill of Materials together with intermediate products.
On page Results - KPI Overview, and on the KPI Summary page, costs for Suppliers/Productions/Warehouses have been split into three buckets - Fixed Cost, Variable Cost, and Open/Close Cost.
On the KPI Summary page, the Service Widget now also contains the Cost Per UOM and the (number of) Open Suppliers/Productions/Warehouses.
The capacity on the server that is used to do all the optimization requests is shared by all users that use the same cloud. Previously, all optimization requests from all users were handled with the same priority. This means that a normal optimization request that was started by one user, had the same priority as Trade-Off Analysis or Risk Analysis requests that were started by another user. So, if you started a normal request after someone else started an Analysis request, it could take a long time before your request would be processed. Now, normal optimization runs have priority over runs from Trade-Off Analysis or Risk Analysis.
On page Center of Gravity, the transportation speed can be changed now. The default value is the average speed of all transportation types in the dataset.
In the dialog Add CoGs to the set of Warehouses, the values for Warehouse Group for CoGs and Location Group for CoGs are now initialized with the CoG Location Group/CoG Warehouse Group value provided in the template.
We have removed the “Solution found” dialog message at the end of a Solve Max Drive Time run, to prevent an unnecessary click.
By default, Suppliers are no longer included in the CoG calculations as many users ran into the warning Warning infinite capacity treated as zero. If you want to include suppliers, please select them again on page CoG Settings.
You can now edit the Center of Gravity Wiggle Factor parameter. The initial value is set to the average of the Transportation Wiggle factor in input data.
The tooltip for the CoG Weight Factor now includes a brief explanation of what this parameter controls.
When exporting CoG locations, the CoG Primary/Secondary Transport Cost values will be used to populate the ‘Cost Per Distance’ for primary or secondary lanes connecting the exported CoG locations. This ensures consistency between the parameters used in the Center of Gravity analysis and the exported data to be used in subsequent network optimization workflows.
SC Navigator could report models with inventory and {warehouse group} capacity constraints incorrectly as infeasible.
- Bug Fixes
In some cases, saving the results datasets could be much slower in SC Navigator version 24.1.1, compared to the previous version.
The Weighted Average Lead Time on the KPI Summary dialog was using the Maximum lead time, instead of the actual lead time.
On page Results, the coloring in the Reference Result map was not correct. It used the same coloring as the Active Result map, while it should color based on the data of the Reference Result dataset.
The calculation of Rate Card cost was not correct when lanes were defined with curly brackets. In that case, some costs were duplicated.
The data validation executed after Add CoGs to the set of Warehouses could give incorrect data validation errors and warnings.
The Trade-Off Analysis did not work correctly when having more than 10 runs and some of the runs would be marked as infeasible incorrectly.
The model could incorrectly generate this warning when loading a dataset: There exists a warehouse that has ‘Inventory Cover’, but no ‘Available (Inventory)’ for next period.
SC Navigator 24.1.1
Date January 16, 2024
- New Features
Risk Analysis simulates closing each location, one at a time, and assesses the corresponding impact. This will help you in finding the vulnerabilities of your supply chain. More information about the Risk Analysis can be found in the documentation: Risk Analysis.
With Trade-Off Analysis you can do multiple solves, each with a different setup, and find the best trade-off between your KPIs. More information about the Trade-Off Analysis can be found in the documentation: Trade-Off Analysis.
- Improvements
Previously, some pages displayed raw coding names instead of proper text. These have now been replaced with appropriate texts across all pages.
The pages “Geocodes” and “Distance” are now also available when the data is loaded from a dataset. In that case, the data on these pages is read-only.
The icons for the primary page actions on page “Geocodes” and “Distance”, have been replaced by icons that match the action, instead of the generic AIMMS logo.
Links to the latest e-learning material have been added to the template.
Solving time for datasets with Single Sourcing data is decreased in case of both active and relaxed optimization options.
The SC Navigator version numbering has changed. From now on, the first number will refer to the year in which the version was released. The second number still increases with every feature release. The third number increases for bug fix releases.
- Bug Fixes
The data validation warning that appeared when a minimum number of Suppliers/Productions/Warehouses/Locations was provided without a maximum, is removed.
When a results scenario was saved right after a Full Solution Export, the scenario did not appear in the list of results scenarios.
SC Navigator 4.05.04
Date December 19, 2023
- Improvements
On page Results - Customer, in the bottom right map, when a customer node is clicked, the drive time interval bar that corresponds to that customer’s drive time will become highlighted in the drive time distribution chart on the left.
A new source of System Cost has been introduced for multi-period models with inventory. The source is periods in which there is inventory, but no outflow. The Cost To Serve page also contains a new table with the source of this cost. This source and the table are explained in section System Cost Breakdown Table of the documentation.
In earlier releases it was possible to define minimum capacity or base case volume for lanes from a location to the same location. Now, this type of input data will result in a data validation error.
- Bug Fixes
The creation date of results datasets were truncated too much, in the long run leading to the complete removal of the date, when using Azure Data Lake Storage.
The application name of each results dataset was Network Design instead of SC Navigator, when using Azure Data Lake Storage.
On page Results - KPI Overview, in table Total Revenue and Total Cost the profit values were not correct in specific cases.
SC Navigator 4.05.03
Date December 12, 2023
- Improvements
For inventory-enabled datasets, the Results - Warehouse page and KPI Overview page now display separate Inbound and Outbound volumes, since these values may differ for warehouses that hold inventory.
If the longitude and latitude of a location was changed, SC Navigator would still use the previous retrieved distances and durations for lanes that were marked with Retrieve Distance. This new version stores the longitude and latitude of the origin and destination, so that this can be used going forward to determine if the previous retrieved distances are correct. (Only when using Azure Data Lake storage.) If the longitude and latitude is not stored (all distances retrieved before this version), the model will look at the date for which the longitude and latitude and distances were retrieved, and if the longitude and latitude of a location was retrieved after the day for which the distance was retrieved, SC Navigator will ask you to retrieve the distances again.
In previous releases extra lanes (from the production location to the same production location) were needed to make it possible to use multiple consecutive steps of BOM production. From now on these extra lanes are not needed. Multiple consecutive steps of BOM production is possible without any further setup.
- Bug Fixes
On page Results on the View Options side panel and on page Center of Gravity on the Node Filter side panel, the icons for node types had disappeared.
The Step in Use attribute for Warehouse Product could get empty when solution files were exported.
Earlier the Full Solution Export didn’t contain the Production BOM sheet data. Now this is included as well.
On page Results - Transport in table Secondary Transport, unnecessary rows appeared and made the content too large to fit in the table. The unnecessary rows no longer show up now.
SC Navigator 4.05.02
Date December 4, 2023
- Improvements
The data validation for disproportionately large maximum capacity data has been improved. The threshold that may trigger this warning is increased.
- Bug Fixes
In the rare situation that the model decided that a warehouse location was open for inventory, but the inventory level was zero, the model could present the user with an incorrect message: “A problem occurred during the optimization. Please contact support.”. This issue is fixed now, so if you would get this message, please contact support.
The data validation for Inventory Cover was not correct for the last period.
SC Navigator 4.05.01
Date November 30, 2023
- New Features
From this version on, data can be stored in Parquet files in Azure Data Lake Storage. Using Parquet files allows for easier integration with other systems in your organization. Furthermore, reading and writing datasets can be faster, especially for larger datasets. We will contact you to plan when we will setup Data Lake Storage and convert your existing database to Parquet files.
- Improvements
Data validation has been added for the case when the Maximum # of Source Locations data for customers is provided on the Product Location sheet. Please make sure to provide the Maximum # of Source Locations data for customers on the Customer Product Data sheet instead.
The generated summary for scenarios has been improved to provide a clearer representation of the contents within each scenario.
On page Results - Transport, the Rate Card Band results are now visible.
On page Results - End To End, filters now operate independently from the filters on other pages, providing increased flexibility to alter the view. Additionally, a filtered icon indicator has been added for enhanced visibility.
- Bug Fixes
In the Batch Run functionality, an error could occur when the solution was being saved to the database and the auto-generated scenario name was excessively long. As a result, the batch run process came to a halt because the long name could not be stored in the database. Now the app is able to automatically truncate the name into a shorter text, and include the original name as description.
When comparing Results datasets, the KPI Summary dialog now shows the Results datasets in the columns instead of the rows in a table.
On page Control Panel, the Model Control table now displays the section separation lines well when comparing multiple (newly saved) Results datasets.
On page Data - Transport, in the Transportation Data table the Force Open and Force Close columns are now always visible.
On page Results - Customer, the unserved demand is excluded from the lead time violation and the drive time distribution. In this case the drive time is not shown (zero).
On page Results - Customer, if the demand is transported to a customer with zero distance, the drive time was incorrectly -inf. Now in this case the drive time is not shown (meaning: it is zero).
When using side panel filters, the count of the Select/Deselect buttons were inaccurate and the clicking on the Deselect button would give an error message.
On page Results, the tooltip for nodes on the map now shows the location description if the Use Description Location attribute is set.
On page Data - Manage Data, when deleting one or more items, the text in the confirmation dialog is more accurate.
On page Results - Production, clicking on a production in the bottom left chart, did not update the other charts based on this selection.
SC Navigator 4.04.02
Date November 13, 2023
- New Features
Two template attributes have been added to the Location Product sheet: Maximum/Minimum # of Open Locations. These allow count constraints to be added for curly bracket location and product combinations. This means that the maximum/minimum number of locations (within a given location group) at which a product (individually or within a product group) is present can be enforced.
- Improvements
On page Data - Manage Data, the Results table has a new column: Results Type. It shows whether the result is e.g. an SC Navigator result or a CoG result (only for new saved results).
On page Results - End to End, the filters are updated. Groups and location views have been introduced, and they share the same design and functionality as filters on other result pages. Please note that these filters continue to operate independently from other filters.
For all Map widgets, Customer nodes will be hidden by default if a large number of customers are present. A toggle has been added to the filter side panels to control the visibility of customer nodes on each map.
- Bug Fixes
On page Scenario - Control Panel, overwriting with zero did not work properly.
On page Data - Manage Data, the Results table previously only included the most recent result datasets. Now it displays all stored result datasets.
On page Center of Gravity, the Node Filter side panel now also shows the colored icons matching the node types on the map.
On page Results, when the View option filter was used, the ‘filter is applied’ icon appeared on the Filters side panel tab instead of the View options side panel tab.
On page Results, the Transport mode filter did not work for the Active Result map. It only worked for the Reference Result map.
In cases where optimization is halted because of a time limit, there was an issue where the ‘Results’ section did not expand, keeping its subpages hidden. This problem is resolved, and now the pages within the ‘Results’ section will automatically expand in this situation, allowing users to easily access and review the results data.
In some rare instances, an error could occur stating something like: “
CallerNode(1): The depth 1 is outside the range { 1 .. 0 }”. This is now prevented.You could receive an incorrect message “A problem occurred during the optimization” when you used Maximum # of Destination Locations and that location would cover all the demand.
The data validation for transportation lanes incorrectly resulted in an error when there was a curly bracket in the period column. It would require the lane to be ‘Available’ for the period group, while this data validation should only apply to single elements.
On page Center of Gravity - Settings, the Grid Distance is now set to read-only when the Maximum Drive Time is not specified. The reason for this, is that the upper bound of the Grid Distance depends on the Maximum Drive Time. The tooltip of the Grid Distance will explain this.
On all Data pages, when data is loaded from, or saved as a dataset, the Available column is now read-only. This makes sure that rows can no longer disappear from the tables. If you want to exclude any Suppliers/ Warehouses/ Productions/ Transport Lanes from an optimization run, use the ‘Force Close’ attribute.
On page Results - KPI Overview, costs now appear with a minus sign if any revenue is included in the optimization. Consistently, costs and cost type custom objectives will appear with a minus sign in the full solution export if any revenue is included in the optimization. As a result, the sum on the KPI Overview page matches the profit.
In the SC Navigator input template on sheet Custom Objectives, the description of attribute ‘Refundable with Limit’ is corrected. The possible value descriptions didn’t match with their actual value. Consistently the documentation of refundable tax functionality is also updated.
In the Center of Gravity, the distance calculation did not accurately account for the wiggle factor.
The behavior of the Supplier filter has been corrected. Previously, when selecting all individual suppliers, the group supplier was unexpectedly unselected.
SC Navigator 4.04.01
Date October 23, 2023
- New Features
The Center of Gravity App has been integrated into the SC Navigator App. This brings a streamlined process enabling analyzing Centers of Gravity within the same dataset and application.
When there is a circular flow in the solution, a new page “Circular Flows” will show up. This page will help you finding the cause of the circular flow, such that it can be fixed in the input data.
- Improvements
On page Scenario - Control Panel, more attributes can be handled.
On page Results, colors of the node types have been changed to colors used in Network Design, and their icons also have changed for easier identification.
On page Results, the View options side panel now shows the colored icons in the Filter By Node Type widget. This allows you to quickly identify the node type of nodes on the Results map.
On page Data - Manage Data, the Scenarios table now includes an auto-generated scenario summary. This summary provides quick insights into each scenario without additional loading actions. The Save Scenario Dialog and the Load Scenario Dialog show this summary as well. Please note that the summary is only available for new scenarios.
Data validation has been added in case the Average Load Size data is missing for a row with Cost Per Distance / Cost Per Trip / Minimum Cost Per Trip.
- Bug Fixes
The list of Result Datasets that are generated during a batch solve, was not displayed correctly.
The changes made in version 4.03.04 with respect to the E2E volumes could result in very slow performance in some instances. This new version will be faster than before, although it will be slower than before 4.03.04.
The following data validation messages will no longer occur when the Available data is missing for a row with a curly bracket group in it: “WARNING: There are one or more attributes defined for (<combination including a curly bracket group>). However, this <warehouse/supplier> is not available for this product. You can make it available by specifying the ‘Available’ attribute on sheet ‘<Warehouse/Supplier (Product)>’.”
The data validation for Base Case Volumes now shows an error when Base Case Volumes on a last mile lane are different from the sum of demands at the customer location where the lane goes to.
On page Results - Transport, the charts incorrectly displayed a duplicate transportation volume due to the inclusion of both product groups and individual products in the calculation of transportation data.
On page Data - Transport, the Custom Objective input data for transport step was not visible when the data was not (yet) saved to the database.
On page Scenario - Transport, the Relative Change value was not being applied properly.
On page Scenario - Production, the adjustment data related to the Bill of Resource data was not being saved correctly.
On page Data - Warehouse, in the Inventory (Product) Data tables the Force Open and Force Close columns are now always visible.
On dialog page Custom Objective settings, the ‘Include in model objective’ variable can now only have binary values.
SC Navigator 4.03.06
Date September 19, 2023
- Bug Fixes
The data for Base Case Volume was not handled correctly when it was specified for {To location} group. It was handled as a regular group, meaning that the model was using the same value for each to-location in that group. In most cases, this would lead to an infeasible model.
SC Navigator 4.03.05
Date September 15, 2023
- Improvements
On page Results - Warehouse, the minimum of the y2 axis is now set to 0 for the Throughput and Inventory chart.
- Bug Fixes
The backwards compatibility logic did not copy the “use description” settings from the configuration to the dataset.
Switching Business Units could lead to the loss of dataset type information, which can result in Network Scenarios failing to load correctly.
The Rate Card data validation has been updated. There will now just be a warning if a package does not fit in any rate card band and there is another mode of transport available between the locations for the product and period combination. If there is no alternative lane, the validation still gives an error.
The model would return an incorrect fatal error when loading a dataset that had a {product group} capacity specified for a transportation type that uses rate cards.
SC Navigator 4.03.04
Date September 8, 2023
- Improvements
The Excel input template now has a filter set for each attribute and the top row is frozen by default.
- Bug Fixes
On page Results - Warehouse, the opening inventory was incorrectly calculated for group periods.
On page Data - Customer, after adjusting demand or lead time, the demand or lead time was not updated when the data was not saved in a dataset.
In some cases, when a result dataset was loaded, the order of period elements changed. This could cause the model to become infeasible.
The E2E volumes could be incorrect in models when there were multiple Production Facilities in one location.
The dialog to notify you about a new version could incorrectly appear after loading a results dataset.
The data validation for Forced Flow and Base Case warehouse data no longer gives an error when inventory for the product is present at the warehouse with conflicting Force Flow or Base Case Volume.
A model that took more than an hour to optimize would result in an error and no results would be retrieved, even when the timeout limit was set to something higher than 1 hour.
The Minimum and Maximum Capacities for Mode of Transport groups are now functioning properly.
SC Navigator 4.03.03
Date August 25, 2023
- Bug Fixes
Loading a previously saved Results dataset, could trigger an error stating “value ‘’ is outside the range domain set”. This error led to improper loading of the result data.
SC Navigator 4.03.02
Date August 22, 2023
- Improvements
The Manage Data page and the Select Results Dataset dialog now only show results datasets that the user can load. A user can load all self-created datasets and datasets that were shared by other users when pushing the ‘Results Visible for Everyone’ toggle when saving the dataset.
More Data Validations for negative input data have been added.
- Bug Fixes
In some rare instances, when solving the base case model, it was possible to receive a warning “A problem occurred during the optimization”, or the model could be incorrectly noted as infeasible.
In some cases when there was inventory cover specified, the model could be incorrectly noted as infeasible.
When there was inventory cover specified for the last period, an incorrect data validation message occurred, while in that case the model is just feasible as well.
SC Navigator 4.03.01
Date August 10, 2023
- New Features
The application now offers the ability to define roundtrips for transportation. This allows you to define opportunities for backhaul trips with own or 3rd party products. The optimization then takes these backhaul/roundtrips into account. More information about the Roundtrip functionality can be found in the documentation: SC Navigator - Roundtrip Functionality.
- Improvements
The background color for tooltips in map widgets has changed for better readability.
The generated template is now called “Template SC Navigator.xlsx” instead of “Template SC Navigator Input of Default configuration for SC Navigator.xlsx”. You are still free to change it to any name that you want to, but we believe that a shorter default name would be better.
The Control Panel page has been redesigned. Several widgets moved to a different, more logic, position and there are two major changes:
The data from widget Run Time Options is now located at the bottom part of the Model Control widget.
Instead of always showing three Custom Objectives by … widgets, we only show one, but with the ability to control which one to show via a widget action.
The KPI dialog page no longer shows the Custom Objectives table if there are no Custom Objectives in the model.
- Bug Fixes
In some cases, the data validation that checks whether there are multiple rate card drop sizes associated with a transportation lane, could incorrectly result in an error.
When setting all data for an attribute to 0 without first saving the data to a dataset, could result in the original value being used.
On page Results - Warehouse, in the Capacity Violation - All Periods chart (top left), an inactive warehouse could be marked good (green) instead of inactive (gray).
On page Scenarios - Transport, the middle widget (in which you can specify the change for an attribute) becomes invisible when the selected attribute does not include data. This made it impossible to create scenarios for empty attributes.
After a batch run, the map on the main Results page did not show the lanes because the Period Slider was no longer initialized.
For some users, the Product Update dialog page was shown multiple times for the same SC Navigator version. SC Navigator will now show this page only once, the first time a version is opened by a user.
In some rare cases, the data on the ‘Results - Cost To Serve’ page and the ‘Results - End To End’ page could be inconsistent with the rest of the results.
In some cases, the Main map customizations were not initialized and could get lost when a dialog page was opened.
On the Cost to Serve page the table header was not consistent with the value that the column showed. Now it is corrected and the value in the column depends on the selected objective filters.
In some cases it could happen that the included objectives may not have been consistent with the Model objective. Now the appropriate objectives are included.
SC Navigator 4.02.04
Date July 25, 2023
- Improvements
A new button has been added to the Data Issues page to rerun data validation before saving the dataset. The button is only available if the data has not been saved yet. It allows you to trigger the data validation manually after you have modified the data in the browser in an attempt to fix any data issues that you had before.
Previously, data validation ran when new data was loaded, but there was no data validation before the data was saved. Now if the data is modified before saving as a dataset, the data validation will be rerun.
The Excel file created via Download Solution contains two new sheets: BOM Product and Production BOM. BOM Product shows how much of each product is created or consumed for each Bill of Material. Production BOM provides insight on how much of each bill of material is produced at each production facility and its impact on the capacity and cost.
When selecting Maximize Cost on the Control Panel page, it automatically checks all objectives to be included in the objective.
In cases where the model had two equivalent solutions, one with ‘In Use’ true and the other one with ‘In Use’ false, the model did not always pick the expected solution (‘In Use’ being false). This can happen if the Volume is zero, but there is no Fixed Cost, no Minimum Throughput and no Force Open. In that case, the model could decide to either open or close the facility. In the new version, it will set ‘In Use’ to false.
On the Control Panel Scenario page, it is now possible to also use ‘% Change’ and ‘Value Increment’ to create scenario data for the selected attributes: Min and Max Locations/Suppliers/Warehouses/Productions. Previously ‘Value Overwrite’ was the only option.
The performance has been improved for models where ‘Maximum # of Source Locations’ for customers is used.
The performance of the optimization has been been improved, especially for datasets without inventory.
Filters on the main map have been updated for a better user experience.
On the Supplier/Production/Warehouse Results page, Capacity is added to the top right and lower left bar charts and their tooltips.
On the Warehouse Results page, the layout of existing tables has been improved, and a new table ‘Stock Progression’ is added to the bottom of that page.
- Bug Fixes
The data validation for Forced Flow and Base Case Volume has been improved.
The data validation message “FATAL: Attribute ‘Variable cost is for all steps’ is not consistent for all steps in sheet ‘Production’.” did not have details in the bottom table on the Data Issues page.
The data validation message “ERROR: A transportation lane has negative capacities or negative ‘Base Case Volume’.” did not have details in the bottom table on the Data Issues page.
The data validation message “WARNING: A warehouse or production has data, but it is not warehouse available nor production available.” was incorrectly generated for productions or warehouses with curly brackets.
Data validation has been added for the Force Close attribute.
The Force Close attribute was sometimes incorrectly linked to the Force Open attribute.
All filters are now reset after loading a results dataset.
On the Cost To Serve page, in chart Total Revenue and Cost, the tooltip had the incorrect label Revenue, while it should have been Cost.
On the Transport Results page, the bar chart sometimes showed incorrect data.
On the KPI Overview and Cost to Serve pages, sometimes the charts could become empty after loading a results dataset.
On the Location Product sheet the attribute description for ‘Max # of source locations’ and ‘Max # of destination locations’ has been improved.
When creating scenarios, curly bracket groups were treated as regular groups. As a result, the scenario data was applied to individual elements in those groups, instead of applying it to the group as a whole.
The ‘Apply Transport Scenario’ page action caused the model to use incorrect transportation data.
The ‘Load Warehouse Scenario’ page action was not able to retrieve the correct scenario data, resulting in no changes being applied to the Warehouse Scenario.
SC Navigator 4.02.03
Date June 23, 2023
- Improvements
On the Customer Scenario page, when creating scenarios for ‘Minimum Fulfillment Rate’, the ‘Value Increment’ and ‘Value Overwrite’ that were fractions previously, are now percentages. A % sign is displayed such that the user knows what type of value to enter.
The description about attribute ‘Minimum Fulfillment Rate’ in sheet ‘Customer Product Data’ now explicitly states that this value must be expressed as a fraction or as a percentage (in the Excel input template).
On the Customer Data page, the user can now directly change demand and lead time after loading an Excel file. Previously, this was only possible after saving the data as an input dataset.
- Bug Fixes
In some special cases, the infeasibility analysis incorrectly showed a capacity violation while there were no capacities specified.
The attribute ‘Variable cost is for all steps’ has been added to the Inventory sheets.
If there is a product with inventory cover, we validate to make sure that there is inventory available for it.
The data validation process used to take an excessively long time when dealing with datasets that contained a large number of locations and products. This data validation has now been improved.
On the Customer Data page, the Demand Adjustment and Lead Time Adjustment tables could still show data after a new dataset was loaded.
SC Navigator 4.02.02
Date June 9, 2023
- Improvements
On the Cost to Serve page, if you select a location on the map or the filter side panel, both charts and tables are now updated based on the selection that was made.
The attributes Force Open and Force Close are now always visible on data pages after loading input data from an .xlsx file.
On every filter side panels, single elements are now alphabetically ordered.
The documentation is improved and extended. At Template Attributes you can read about the different attributes that you can find in the Excel input template and throughout the SC Navigator app. This will help you understanding what effects the different attributes have and how to use them. Furthermore, some smaller improvements are made to the documentation, like links to guide you to the right topic.
- Bug Fixes
On the Cost to Serve page, the selected node on the map is now highlighted in a different color, such that you can easily identify the node that is selected.
When ‘Variable cost is for all steps’ was set, the ‘Variable Cost’ columns on the result pages were incorrect. The model results and the total cost over all steps were correct, but the costs were incorrectly distributed over the steps.
On the Supplier/Warehouse/Production/Transport Scenario pages, certain group elements were excluded from the scenario creation if they did not have the ‘Available’ attribute specified. With this fix, all group elements, regardless of their availability status, can now be included in scenarios.
When using ‘Variable cost is for all steps’ there was no data validation to check if the ‘Variable cost is for all steps’ attribute is set for each step. Now the attribute must be defined either for each step or for none of them.
SC Navigator 4.02.01
Date May 30, 2023
- New Features
The Force Open and Force Close attributes can now be defined for Inventory and Inventory Product. The conditional constraints for inventory and inventory product now depend on the Force Open attribute for Inventory.
The application now supports groups for Modes of Transport and Suppliers. This means that if you generate a new template you will see two new sheets “Supplier Groups” and “Mode of Transport Groups”, where you can specify the group definition. You can copy them to your existing sheet, if you want to. This allows you to specify data for the complete group, specify data for the group elements, and you can filter on the group elements.
- Improvements
The KPI Summary Dialog has a new improved layout.
On the Data - Transport page, the Source of Distance and the Source of Duration columns are added to the Trip Data table.
On the Results - Transport page, Source of Distance, Duration and Source of Duration are added to the tables whenever there is Distance data available.
On the Results - KPI Overview page, the (weighted average) Duration is added to the Transport tables whenever there is Distance data available.
- Bug Fixes
In some cases, it was not possible to load a scenario from the status bar, because the scenario category was not passed correctly to the loading scenario action. Now it is, so scenarios can be loaded from the status bar.
The optimization model was not using the steps in a correct way. For example, Step 3 was preceded by Step 1 instead of Step 2 so in the template the steps had to be in ascending order. Now the steps are always numerically ordered, such that the model will use them in the right order.
On the Results page Node Filters side panel, all node types were visible in the Filter by Node Type widget, regardless of the data in the loaded dataset. Now only node types related to the dataset are visible.
The color of each node type was very similar. We changed the default color of the node types, such that they are easier to identify on the map.
Reset map to default scale did not work. Now pressing Reset map to default scale restores the default zooming scale.
The maximum size of the dots on the map was too small. The maximum value has changed from 100 to 400 in the Adjusting node size option, such that the nodes can have a bigger size.
When single/multi sourcing is enabled, the optimality gap by default is 0.01. When multi sourcing is relaxed, it will be set to 0.001, while for relaxed single sourcing it remained 0.01. This is now made consistent, so for relaxed single sourcing the default optimality gap is now also 0.001. When the optimality gap was specified in the input Excel data file or when it is set manually on the Control Panel page, that value will be used and the defaults are ignored.
SC Navigator 4.01.04
Date May 11, 2023
- Improvements
The Take or Pay transportation cost can now be combined with regular transportation cost. This gave an error in the previous versions of SC Navigator.
It is still not allowed to combine other transportation costs. However, this now leads to a fatal error, instead of just an error as the application did previously.
- Bug Fixes
The Unit of Distance was not taken into account correctly for distances generated by Location IQ. This means that all those distances were in kilometers, even when the Unit of Distance was set as mile.
In the rare situation that the model decided that a lane was open, but with zero flow, the model could present the user with an incorrect “A problem occurred during the optimization. Please contact support.” message.
SC Navigator 4.01.03
Date May 8, 2023
- Bug Fixes
In some cases, the Results table on Data - Manage Data page was not showing at all, while there was data for that table. In this version, it will show this table, when there is data in it.
The Data validation messages have been reviewed and updated for clarity. If you encounter any unclear messages, please contact us for assistance.
SC Navigator 4.01.01
Date April 20, 2023
SC Navigator 4.0 will replace the AIMMS Network Design App that you have worked with previously. It contains all the functionality that you know from AIMMS Network Design. In addition, it has some new features:
Stock build and stock draw
Max profit / revenue solve
Customer fulfillment decisions
Improved scenario management
Improved multi period reporting
For more details on the differences between Network Design and SC Navigator 4.0, read SC Navigator vs. Network Design
For previous versions, read SC Navigator 2 release notes.
