Template Sheets
In this section you can read about the different sheets in the SC Navigator template. This section summarizes the contents of the sheets in Excel, but does not cover attributes. You can read more about the different types of attributes in Template Attributes. On each sheet the color of the cells indicates the attribute type:
Coral color: Setup attributes, like availability, UOM, etc.
Yellow: Capacity attributes, like Min/Max Capacity, Min/Max Ratio, etc.
Green: Cost attributes, like Fixed Cost, Variable Cost, etc.
Blue: Force Open/Close and miscellaneous attributes.
Lilac: Custom Objectives attributes.
