Inventory Sheets
In SC Navigator you can add Inventory data. In the template there are two separate sheets for inventory data: Inventory and Inventory Product.
Inventory
Availability (Available)
Capacity data (Capacity Attributes)
Variable Cost (Cost Attributes)
Target (Inventory Attributes)
Target Violation Cost (Inventory) (Inventory Attributes)
Opening/Closing data (Open/Close Attributes)
Variable Inventory Holding (Inventory Attributes)
Custom Objectives data (How to use Custom Objectives?)
If you want to define data on this sheet you have to fill in the Warehouse, Location, Step, and Period columns for each supplier you want to use in the model. The warehouse for which you want to enter inventory data should be available on the Warehouse sheet.
Inventory Product
Opening Inventory (Inventory Attributes)
You can define data only for warehouses which have available inventory on Inventory sheet. If you want to define data on this sheet you have to fill in the Product, Warehouse, Location, Step, and Period columns for each warehouse you want to use in the model.
You can read more about the different types of attributes in Inventory Attributes.
Inventory data can be found on the Warehouse Data page, where also the input data may be modified.
The results related to inventory are shown on the Warehouse Results page.
