Transport Navigator Sheets
These sheets cover information related to the Transport Navigator Module. You can read more about the different types of attributes in Transport Navigator Attributes.
TN Settings
Field |
Description |
TN Solve Time |
Time in seconds for the Transport Navigator to find the best solution. |
Reference Date and Time |
Starting date and time for the Transport Navigator optimization. |
Include Week Number in Time Stamps |
Indicates if week numbers should be included in time stamps. |
Reset Duty Time at Warehouse |
Resets the duty time and drive time when the vehicle returns to the warehouse. |
TN String Settings
Field |
Description |
Volume UOM |
Unit of measure for volume. |
Weight UOM |
Unit of measure for weight. |
TN Periods
TN Period Groups
TN Locations
Field |
Description |
Mode of Transport |
The Mode of Transport that is used for routes from the warehouse location. |
Maximum Duty Time |
The maximum duty time (in hours) before a layover is required. |
Maximum Drive Time |
The maximum drive time (in hours) before a layover is required. |
Maximum Drive Time Before Break |
The maximum duration (in hours) a driver is allowed to drive continuously without interruption. Once this time limit is reached, the driver must stop and take a break (Break Time) before continuing. |
Break Time |
The required rest duration (in hours) a driver must take after reaching the ‘Maximum Drive Time Before Break’. The driver cannot resume driving until this break has been fully completed. |
Minimum Layover Duration |
The minimum duration of a layover (in hours). |
Maximum Layover Duration |
The maximum duration of a layover (in hours). |
Cost Per Stop |
The cost per stop made during the route. |
Cost Per Dispatch |
The cost for dispatching a vehicle from the warehouse. |
Cost Per Layover |
The cost per layover. |
Cost Per Hour Late |
The cost per hour of being late after the customer time window, calculated per minute. |
Maximum Distance between Stops |
The maximum distance between two (customer) stops. |
Reloading Time Warehouse |
The reloading time (in minutes) at a warehouse before a vehicle can depart again. |
Maximum Number of Stops per Route |
The maximum number of stops on a route before the vehicle needs to return to the warehouse. |
Maximum Duty Time, Maximum Drive Time, the layover durations, the costs, Reloading Time Warehouse and Maximum Number of Stops per Route can also be set per vehicle on the TN Vehicles sheet. A value there overrides the value on this sheet for that vehicle.
TN Location TN Periods
Field |
Description |
Opening Time |
The warehouse’s opening time at the specified location during the TN Period (in hours from the start of the TN Period). |
Closing Time |
The warehouse’s closing time at the specified location during the TN Period (in hours from the start of the TN Period). |
Minimum Relative Capacity |
The minimum percentage of the total effort that must be handled in this TN Period. |
Maximum Relative Capacity |
The maximum percentage of the total effort that can be handled in this TN Period. |
TN Vehicle Groups
TN Vehicles
Field |
Description |
Reduced Capacity Per Stop |
The amount by which the vehicle’s volume capacity decreases per stop on a multi-stop route. |
Vehicle Capacity Weight |
The weight capacity of the vehicle type, as specified in the weight unit of measure. |
Vehicle Capacity Volume |
The volume capacity of the vehicle type, as specified in the volume unit of measure. |
Vehicle Properties |
Semicolon-separated properties of the vehicle type, e.g. |
Has Sleep Cabin |
Indicates the availability of a sleep cabin in the vehicle type for layovers. |
Route Ends at Last Stop |
Indicates whether the vehicle does not return to the warehouse after its last delivery. |
Pre-Trip Drive Time |
Driving time (in minutes) already spent before reaching the warehouse. |
Pre-Trip Duty Time |
Duty time (in minutes) already spent before reaching the warehouse. |
Post-Trip Drive Time |
Driving time (in minutes) needed after the last stop to return home. |
Post-Trip Duty Time |
Duty time (in minutes) needed after the last stop to return home. |
Cost Per Distance |
The cost per unit of distance (kilometer or mile) for transportation. |
Cost Per TN Period |
The cost per TN Period associated with operating the vehicle. |
Cost Per Vehicle |
The one-time fixed cost for using the vehicle in the planning horizon. |
Cost Per Hour Driving |
The cost per hour of driving time of the vehicle. |
Cost Per Hour Waiting |
The cost per hour of waiting time of the vehicle. |
Grouping Code |
A code used to group customers and assign them to a vehicle with a matching grouping code. |
The following TN Locations attributes can also be set per vehicle on this sheet: Maximum Duty Time, Maximum Drive Time, Minimum Layover Duration, Maximum Layover Duration, Cost Per Stop, Cost Per Dispatch, Cost Per Layover, Cost Per Hour Late, Reloading Time Warehouse and Maximum Number of Stops per Route. A value on this sheet overrides the TN Locations value for that vehicle.
TN Pattern Groups
TN Pattern Period
TN Customer Product
Field |
Description |
Demand |
The demand for each product per customer in the base unit of measure. |
Demand Volume |
The volume of product demand for each customer, specified in the volume unit of measure. |
Demand Weight |
The weight of product demand for each customer, specified in the weight unit of measure. |
Pattern Group |
The pattern group according to which this customer must be served. |
Effort |
The effort required in the warehouse to pick, load, or process the order. |
Service Time |
The time in minutes required for service at the customer’s location, e.g., offloading. |
Time Window Start |
The earliest possible arrival time at the customer’s location, in hours from the TN Period start. |
Time Window End |
The latest possible arrival time at the customer’s location, in hours from the TN Period start. |
Is First Stop |
Indicates if the location must be the first stop on a route (1 for yes, 0 or blank for no). |
Is Last Stop |
Indicates if the location must be the last stop on a route (1 for yes, 0 or blank for no). |
Grouping Code |
A code to group customers for assigning to a vehicle with a matching grouping code. |
Serviced by Warehouse Location |
The warehouse location name that services the demand. |
Required Vehicle Properties |
Semicolon-separated properties a vehicle must all have to serve this customer stop. |
Forbidden Vehicle Properties |
Semicolon-separated properties a vehicle must not have to serve this customer stop. |
TN Fixed Routes
Field |
Description |
Customer Name |
The name of the customer where a vehicle needs to stop on the fixed route. |
Location Name |
The name of the location where a vehicle needs to stop on the fixed route. |
TN Period Name |
The name of the Transport Navigator period during which a stop is made on the fixed route. |
Grouping Code |
Limits the vehicles that the fixed route data validation considers eligible to those with the same Grouping Code; if this column is empty, all vehicles are eligible. The stop itself uses the customer’s grouping code from the TN Customer Product sheet. |
