Supplier Sheets
These sheets cover all information related to suppliers, including their groupings, settings and their product related data.
Supplier Definition
Supplier Groups
Supplier
Availability (Available)
Capacity data (Capacity Attributes)
Cost data (Cost Attributes)
Opening/Closing data (Open/Close Attributes)
Minimum/Maximum # of Open Suppliers (Count Constraint Attributes)
Custom Objectives data (How to use Custom Objectives?)
If you want to define data for suppliers on this sheet you have to fill in the Supplier, Location, Step, and Period columns for each supplier you want to use in the model.
Supplier Product
Supplier Lead Time (End-to-End (E2E) Lead Time Attributes)
Period Offset (Lead Time Offset Attributes)
You can define data only for suppliers which availability was set on Supplier sheet. If you want to define data on this sheet you have to fill in the Product, Supplier, Location, Step, and Period columns for each supplier you want to use in the model.
