Importing data from BigQuery into SC Navigator
This article describes how to import new data from BigQuery into your AIMMS SC Navigator cloud account using your own BigQuery environment.
You can download the example Jupyter notebook here and use the template directly in your BigQuery environment, or use it locally if you have Python installed.
Parquet File Definition SC Navigator
This how-to article assumes you have already created datasets according to the Parquet File Definition of SC Navigator. You can find more information about the Parquet File Definition here: Parquet File Structure.
What to do in SC Navigator
Each AIMMS SC Navigator cloud account is by default equipped with an Azure Data Lake Storage Gen2 (ADLS). For this route we will be utilizing the external access to this storage account to import new data.
The datasets that you upload must be stored in the parquet file format in the import folder of the ADLS.
You will also need to create a SAS-token to get external access to the ADLS. You can find instructions on how to do this on the page SAS Tokens.
Configuration in BigQuery
You can download the full Jupyter notebook example from the link in the first paragraph and replace the ‘TODO’-items in the notebook with your own variables. Below we will describe the code fragments and how they can be used.
In BigQuery you will be using Python packages for the connection to the ADLS. First these need to be installed:
1%pip install azure-storage-file-datalake azure-identity
2%pip install pandas-gbq
First you load the data you would like to upload to SC Navigator. For this example we have all our input data in tables in a dataset. We explicitly define which tables of this dataset we want to upload by using the datasets list. Note that the list in this example is relatively small and you’ll probably want to upload more data to match the necessary parquet-file structure.
1datasets = ['_dataset_info',
2 'bill_of_material',
3 'custom_objective',
4 'customer_definition',
5 'customer_groups',
6 'customer_product',
7 'inventory_product_step']
With the following code we load the data from our tables. We also do some transformations to conform to the Parquet File Definition.
1import numpy as np
2import pandas_gbq
3
4dataframes_for_input = dict()
5for dataset in datasets:
6 # load the data
7 project_id = "<project name>"
8 sql = f"""
9 select * from `<project name>.<dataset name>.{dataset}`
10 """
11 df = pandas_gbq.read_gbq(sql,project_id=project_id)
12 # transform to the Parquet File Definition SC Navigator definition
13 df = df.replace({np.nan: None})
14 if dataset != "_dataset_info":
15 dataset = dataset.replace("_", "-")
16 # store result
17 dataframes_for_input[dataset] = df
Then you’ll need to provide the SAS-token and the URL, both of which are exposed/generated in the previous step when creating the SAS-token:
1# TODO: provide the sas token and the URL of your storage
2account_url_full = "<put here your URL>"
3# remove the folder from the url
4account_url = account_url_full[:-20]
5sas_token = "<put here your sas token>"
6# the file system is fixed, this is the container SC Navigator reads new datasets from
7file_system="sc-navigator-import"
An example of the value expected at account_url_full is https://CloudName.dfs.core.windows.net/sc-navigator-import.
For the sas_token parameter you should only paste the SAS-token itself.
You’ll need to import more required packages:
1import os
2from azure.storage.filedatalake import (
3 DataLakeServiceClient,
4 DataLakeDirectoryClient,
5 FileSystemClient
6)
7from azure.identity import DefaultAzureCredential
And create a DataLakeServiceClient to access the storage:
1# create a DataLakeServiceClient to access the storage
2dsc = DataLakeServiceClient(account_url=account_url, credential=sas_token)
You can now list all folders and files on the storage:
1# list all folders/files on the storage
2file_system_client = dsc.get_file_system_client(file_system=file_system)
3paths = file_system_client.get_paths()
4list_of_files = list()
5for path in paths:
6 if "/" not in path.name and path.name != "info.txt":
7 print(path.name + '\n')
8 list_of_files.append(path.name)
9 else:
10 continue
If this code block gives an error, please check the provided URL and the SAS token (this token needs to be valid and not expired). For further reference we refer to the Microsoft documentation.
Now we create a directory on ADLS to upload the data to:
1# create a new directory to store the datasets
2directory_name = "<directory name>"
3dld_client = file_system_client.create_directory(directory_name)
If you made a mistake or would like to delete data you can do the following:
1client = dsc.get_directory_client(file_system=file_system,directory="<directory name>")
2client.delete_directory()
Before we upload any data we would like to inspect the _dataset_info table. The Dataset field will be used to identify the uploaded data in SC Navigator:
1dataframes_for_input["_dataset_info"]
Now we are ready to upload the prepared datasets:
1# upload the prepared datasets
2client = dld_client
3for k,v in dataframes_for_input.items():
4 file_name = k + ".parquet"
5 file_client = client.create_file(file_name)
6 bytes_data = v.to_parquet()
7 file_client.append_data(data=bytes_data, offset=0, length=len(bytes_data))
8 file_client.flush_data(len(bytes_data))
You could use the following code to see if the upload is successful and inspect the data on ADLS.
1import io
2import pandas as pd
3file_client = client.get_file_client("_dataset_info.parquet")
4data_file = file_client.download_file()
5data_binary = data_file.readall()
6parquet_file = io.BytesIO(data_binary)
7df = pd.read_parquet(parquet_file)
8display(df)
Congratulations! You just uploaded data from BigQuery to SC Navigator. Now open the System Configuration app (or ask your admin to do this) and run the page action Rebuild overview for filesystem … on the File System Management page. If you now open SC Navigator you should see that your dataset is added to the overview.
