Optimization Parameters and Constraints
Time Limit
Sheets on which it appears
Settings
Possible inputs
Any number greater than 0 (in hours)
How it affects the model
The time limit of the optimization run measured in hours. If not specified, the model uses 1 hour.
Optimality Gap
Settings
Possible inputs
Any number between 0 and 100 (in percentage), the smaller the optimality gap, the better the solution.
The optimization engine stops when a solution is found which is within this percentage of the best possible solution. The default is 0.01(%) when using Single Source and 0.001(%) otherwise.
Allow Base Case Volume Mismatch
Settings
Possible inputs
Binary, 0 (empty) or 1
When this attribute is set to ‘1’, the Allow Base Case Volume Mismatch option on the Control Panel will automatically be enabled.
Remove Lanes longer than Maximum Drive Time
Settings
Possible inputs
When this attribute is set to ‘1’, lanes longer than the Maximum Drive Time will be excluded during optimization. These lanes will stay unavailable during Infeasibility Analysis, and while using Relax Maximum Drive Time.
Default Currency per USD Conversion
Settings
Possible inputs
Use this attribute when Retrieve High-level Cost Data is enabled and the default currency is not USD, so transport costs defined in USD can be converted correctly. For more details on Retrieve High-level Cost data, see the Transport Cost page.
Maximum # of Source Locations
Location Product, Customer Product Data
Possible inputs
Positive integers
On Location Product sheet for locations where there is a Warehouse or a Production facility: The maximum number of source location per product and period that can serve a warehouse/production facility. For example if the maximum number of source locations is 10 for a warehouse location, then the inbound volume can only come from 10 different locations, which can be supplier, warehouse or production facility. On Customer Product data sheet for customer locations: The maximum number of source locations per product and period that can serve the Customer. For example if the maximum number of source locations is 10 for a customer location, then the inbound volume can only come from 10 different locations, which can be supplier, warehouse or production facility.
Source Location Weight
Locations
Possible inputs
Non-negative
When the Maximum # of Source Locations constraint is defined, this attribute specifies how a source location contributes to that limit. For each destination location, the model sums the Source Location Weight of all source locations supplying volume in a given product and period. The summed value must not exceed the specified maximum number of source locations. The default value is 1. For example, if the maximum number of source locations is 1 for a location, then it can be supplied either by one source location with weight 1, or by two source locations with weight 0.5 each.
Maximum # of Destination Locations
Location Product
Possible inputs
Positive integers
The maximum number of destination location per product and period that the supplier/warehouse/production facility can serve. For example if the maximum number of destination locations is 10 for a warehouse location, then only 10 different location (Warehouse/Production/Customer) can receive product from that location.
