Transport Attributes
Stepwise costing is only available in the Network Design Advanced Module.
Speed
Sheets on which it appears
Mode of Transport
Possible inputs
Any number greater than 0 (0 means no speed defined)
How it affects the model
The average speed (distance/hour) of the give transportation type. It is used to calculate duration data if it is not given in the template.
Wiggle Factor
Mode of Transport
Possible inputs
Any number greater than 0 (0 means not defined) in percentage
Wiggle factor is used when the model calculates the straight distance between two locations.
Roundtrip
Roundtrip is only available in the Network Design Advanced and in the Sustainability and Risk Modules.
Mode of Transport
Possible inputs
Binary, 0 (empty) or 1
Indicates if the transport mode is used for roundtrip, you can read more about how roundtrip works in Roundtrip Functionality.
Maximum Road Distance To Retrieve
Mode of Transport
Possible inputs
Any positive number in unit of distance
When a lane is using a mode of transport for which maximum road distance to retrieve has been specified and the straight line distance between two points for the lane is greater than the maximum road distance to retrieve, then the ‘Retrieve Distance’ flag will automatically be set to 0 for those lanes, and straight line distances will be used instead.
Retrieve Distance
Transport Cost
Possible inputs
Indicate that the distance and duration needs to be retrieved from Location IQ (if this attribute is 1). If this attribute is active, then the Distance Data page will be visible and the distance can be calculated. Note that the distance and duration by road will be retrieved when this attribute is active. This attribute should be left inactive if road distances and durations are not desired, or the path between two locations cannot be calculated by road.
Average Load Size
Transport Cost
Possible inputs
The average load size that can fit in a Mode of Transport at a lane and a product during a period. The Average Load size is used as a divisor to calculate the lane’s variable cost.
Transport
Mode
From
Location
To
Location
Distance
Cost Per
Distance
Cost Per
Trip
Average
Load Size
Minimum Cost
Per Trip
Cost
Truck
location_1
Location_2
10
0
3
2
0
(10*3)/2=15
Truck
location_1
Location_2
10
0
20
2
0
20/2=10
Truck
location_1
Location_2
10
0
0
2
10
10/2=5
Cost Per UOM
Transport Cost, Rate Cards, Stepwise Transport Cost
Possible inputs
The cost per unit of measurement for a Mode of Transport at a lane and a product during a period. It is independent of the distance, the total value only depends on the volume. It works with the same logic as Variable Cost. It can be defined for each step for a lane on the Stepwise Transportation Cost sheet.
Cost Per Distance
Possible inputs
The cost per unit of distance for a Mode of Transport at a lane and a product during a period. When both Cost Per Distance is defined in the template and Retrieve High-level Cost Data is selected the specified Cost Per Distance value will be used instead of the high-level cost data. For more details on Retrieve High-level Cost data, see the Transport Cost page.
Transport Cost
Possible inputs
For lanes where this attribute is set to 1 and no lane-specific Cost Per Distance data is available, the model uses generalized high-level transport cost data. These values are defined in USD per tonne-km, where one tonne equals 1000 kg. They are automatically converted to the template’s default currency, default/base UOM, and unit of distance. For more details, see the Transport Cost page.
Request Detailed Cost Data
Transport Cost
Possible inputs
For lanes where the attribute is set to 1 and no lane-specific Cost Per Distance data exists, the model generates an Excel file containing the relevant lanes. This Excel is used to request detailed Cost Per Distance data via email. For more details see the Transport Cost page.
Cost Per Trip
Possible inputs
The cost per trip of this Mode of Transport at a lane and a product during a period.
Minimum Cost Per Trip
Possible inputs
The minimum transportation cost of this lane.
Calculate the lane basic cost
The transportation basic cost calculated by the following the volume of the lane * tranportation unit cost. There is two case when calculate the Transportation unit cost, in the first case, there is no Minimum Cost Per Trip defined (first row in the table below) and the second case is when Minimum Cost Per Trip defined. In the second case the transportation unit cost is the maximum of the Minimum Cost Per Trip and Variable+Fixed costs.
Transport
Mode
From
Location
To
Location
Average
Load Size
Cost Per
UOM
Cost Per
Distance
Cost Per
Trip
Minimum Cost
Per Trip
Distance
Transportation
Unit cost
Truck
location_1
Location_2
2
10
4
20
0
15
10+((4*15)/2)+(20/2)=50
Truck
location_1
Location_2
2
10
4
20
60
15
50 (Fixed and Variable) > 30 (Minimum Cost Per Trip (60/2))
Truck
location_1
Location_2
2
10
4
20
120
15
60 (Minimum Cost Per Trip (120/2)) > 50 (Fixed and Variable)
Take Or Pay Volume
This attribute is only available in the Network Design Advanced Module.
Transport Cost
Possible inputs
The volume of a Take or Pay contract. The “Take or Pay” cost is used when a customer/warehouse/production has a type of contract through which the customer/warehouse/production is forced to “take” a certain volume from a supplier/warehouse/production at a given cost or to “pay” the supplier if the agreed volume is not taken. Take or pay unit is calculated as the round up of the ratio of the Volume of the Lane and the Take or Pay Volume.
Take Or Pay Fixed Cost
Transport Cost
Possible inputs
The cost of a Take or Pay contract. It is intended to model Take or Pay contracts, where a fixed price is paid regardless of the exact volume. A typical example is a rail car, where you pay for transporting the car itself, regardless of its load.
Take or Pay works as follows:
Transport
Mode
From
Location
To
Location
Take or Pay
Volume
Take or Pay
Fixed Cost
Volume
of the Lane
Calculated
Units
Calculated
Total Cost
Rail
location_1
Location_2
100,000
9,000
250,000
round up: 250,000/100,000=2.5 (3)
3*9,000=27,000
In contrast, in Stepwise Transport Costing, min and max capacities determine the cost. Cost bands are defined, with each band having a variable cost that is multiplied by the volume within that interval. Read more about Stepwise Transport Cost here: Transportation Stepwise Costing Data Table.
Base Case Lane
Transport Cost
Possible inputs
This transportation lane is active in base case. When you want to use the base case lanes, the Enforce Base Case Constraints on Control Panel option should be selected.
Base Case Volume
Transport Cost
Possible inputs
The volume of this transportation lane in base case. When you want to use the base case lanes, the Enforce Base Case Constraints on Control Panel option should be selected.
Value
This attribute is only available in the Network Design Advanced and Sustainability and Risk Modules.
Transport Cost, Stepwise Transport Cost
Possible inputs
This attribute represents a base value to which the percentage Rate will be applied. It is only used when the Percentage Based option is checked for the respective Custom Objective on the Custom Objective sheet. When enabled, this allows the objective to act as a Tariff, Tax, or Duty (Custom Objectives Sheet).
Rate
Possible inputs
This defines the percentage to be applied to the Value and Volume. It is also only considered when the Percentage Based setting is enabled for the Custom Objective on the Custom Objective sheet (Custom Objectives Sheet).
When the Percentage Based attribute is enabled, the Custom Objective cost is calculated as Volume * Value * Rate + Volume * Cost per UOM.
Transport
Mode
From
Location
To
Location
Volume
Custom
Objective
Rate
Custom
Objective
Value
Custom
Objective
Cost Per UOM
Calculated
Total Cost
Rail
location_1
Location_2
10
0.2
8
15
10*8*0.2+10*15=166
Distance
Transport Trip Data
Possible inputs
The travel distance (miles or km depending on the input) for this lane.
Duration
Transport Trip Data
Possible inputs
The travel duration (in hours) for this lane.
Last Customer Base Cost
Transport Trip Data
Possible inputs
Any number greater than or equal to 0 (0 or empty means not defined)
An additional cost per load for this lane, charged once per route when the lane’s To Location is the last customer visited. It is added on top of all other transport costs, including that stop’s own Cost Per Stop. The From Location should be the warehouse the route departs from, so a lane is only used when its To Location ends a route that starts at its From Location. This attribute is used by Transport Navigator only; Network Design ignores it.
Max Difference
Mode of Transport
Possible inputs
The maximum transported volume difference from the other roundtrip lanes of the transport type. You can read more about how roundtrip works in Roundtrip Functionality.
Maximum Drive Time
Transport Cost
Possible inputs
Any number greater than 0, in hours (0 or empty means not defined)
Sets the maximum allowed drive time for a lane. If the lane’s transport duration is greater than this value, the lane cannot be used. If the value is 0 or empty, no maximum drive time restriction is applied to the lane.
