SC NAVIGATOR DOCUMENTATION
Getting Started
Introduction to SC Navigator
Data Separation
SC Navigator
Input Template
Template Sheets
Notes, Settings and String Settings Sheets
Periods Sheets
Product Related Sheets
Location Related Sheets
Supplier Sheets
Production Sheets
Warehouse Sheets
Inventory Sheets
Transport Sheets
Customer Sheets
Custom Objectives Sheet
Transport Navigator Sheets
Template Attributes
Optimization Parameters and Constraints
Product Attributes
Location Attributes
Available
Capacity Attributes
Cost Attributes
Open/Close Attributes
Count Constraint Attributes
Ratio Constraint Attributes
BOM and Production Routing Attributes
Inventory Attributes
Transport Attributes
Rate Card Attributes
Load Consolidation Attributes
Lead Time Offset Attributes
Customer Attributes
End-to-End (E2E) Lead Time Attributes
Custom Objectives Attributes
Transport Navigator Attributes
Group Elements in the Data
Count and Ratio Constraints
How to Use the Application
User Roles and Modules
Common Screen Areas
Workflow
Status Bar
Period Selector
Filtering in SC Navigator
Page Actions and Widget Actions
Data Editing
Scenario Navigator Overview
Structure Overview
Scenario Pages Layout
Transport Navigator Module
Getting Started with Transport Navigator
Transport Navigator Technical Details
Transport Cost
SENSAI Pro: AI Assistant
Work with Your Data
Optimize and Analyze
Tips and Limitations
SENSAI Data Ready
SAP-IBP Connector
Raw Data
AIMMS AI Systems - Terms of Use
SC Navigator Application
Whiteboard
Data
Load Data Dialog
Supplier Data
Production Data
Warehouse Data
Transport Data
Customer Data
Other Data
Geocodes Data
Distance Data
Manage Data
Data Issues
Infeasibility Analysis
Circular Flow
Control Panel
Results
Supplier Results
Production Results
Warehouse Results
Transport Results
Customer Results
KPI Overview
Cost To Serve Results
End To End Results
E2E Lead Time
Save and Compare Results
Compare Results
SC Navigator Specific Icons
Center of Gravity
Determine Centers of Gravity
CoG Settings
CoG Run Details
Add CoGs to set of Warehouses
CoG Trade-Off
Risk Analysis
Trade-Off Analysis
Scenario Navigator
Supplier Scenario
Production Scenario
Warehouse Scenario
Transport Scenario
Customer Scenario
Control Panel Scenario
Network Scenario
Transport Navigator
Data
Control Panel
Results
SENSAI Data Ready
SAP-IBP Setup
Sheet Type
Attribute Visual
Attribute Table
Group Visual
Group Table
Filter Element
System Configuration
Data User Group
SAS Tokens
File System Management
Case Management
Data Navigator
Configuration Summary
Generate Template
Import Dataset
GIS Location Data
GIS Distance Data
Data Issues
Data Review
Data Management
Business Unit Management
Data Wizard
Common Data
Settings
Glossary of Terms
Inventory Planning
Phase 1 - Start
Start
Data Validation
Review Master Data
Phase 2 - Create Scenario
Create Scenario
Resource Product Data
Scenario Results
Re-balancing
Phase 3 - Compare Scenarios
Compare Scenarios
Best Practices
How to customize your Login page?
Roundtrip Functionality
How to Approach Inventory Strategy Decisions
How to Use Locations
How to Use and Define Groups
Which Sheets are Essential
What is the Simplest Model
How to Transfer SC Navigator Output to Inventory App
How to Get the Most Out of SENSAI Pro
Data Integration
Accessing Azure Data Lake Storage
Exchange Data with SC Navigator
Exporting data from SC Navigator into Databricks
Importing data from Databricks into SC Navigator
Exporting data from SC Navigator into Snowflake
Importing data from Snowflake into SC Navigator
Exporting data from SC Navigator into Google BigQuery
Importing data from BigQuery into SC Navigator
Importing data from Alteryx into SC Navigator
Power BI
SC Navigator ETL Module
Release Notes
AIMMS SC Navigator Docs
SC Navigator documentation
SC Navigator
SENSAI Data Ready
SENSAI Data Ready
SAP-IBP Setup
Sheet Type
Attribute Visual
Attribute Table
Group Visual
Group Table
Filter Element
Last updated: Aug 08, 2026
