Product Attributes
These attributes appear on the Product Related Sheets.
IsSKU
- Sheets on which it appears
- Possible inputs
Binary, 0 (empty) or 1
- How it affects the model
If there is a demand for the product, you must enter a 1 in the IsSKU column, otherwise the application will not treat it as a product.
IsUnion
- Possible inputs
In the InUnion column we identify the product groups that are created by taking the union of two or more other products or product groups.
IsIntersection
- Possible inputs
In the IsIntersection column we identify the product groups that are created by taking the intersection of two or more other product groups.
SubProduct
- Possible inputs
An existing product or product group
In the SubProduct column can be used to specify element of a product group.
UOM
- Possible inputs
String
In the UOM column you can specify the unit with which a product is measured. The default/base UOM is used in all sheets that do not contain a UOM column.
UOM Equivalent
- Possible inputs
Any number greater than 0
In the UOM Equivalent column, you can specify how many base units will fit into the new unit.
If the base unit is kg.
Product
UOM
UOM Equivalent
Product 1
tons
1000
If the base unit is tons.
Product
UOM
UOM Equivalent
Product 1
kg
0.001
