Rate Card Attributes
Rate Card is only available in the Network Design Advanced Module.
Rate Card Drop Size
- Sheets on which it appears
- Possible inputs
Any number greater than 0
- How it affects the model
Rate Cards can be specified for Supplier/Warehouse/Production on Location Product sheet, for Customer on Customer Product Data sheet and for lanes on Transport Cost sheet. Drop Size is the size of the packages that are carried with the Supplier/Production/Warehouse/Lane/Customer Rate Card transport mode, this data is used for decide which rate card band should be used.
Drop Size Lower
- Possible inputs
Drop Size Lower is the lower bound of the drop size for the given Rate Card band in the Rate Card UOM.
Drop Size Upper
- Possible inputs
Any number greater than or equal to 0 (0 means unlimited)
Drop Size Upper is the upper bound of the drop size for the given Rate Card band in the Rate Card UOM.
Distance Lower
- Possible inputs
Distance Lower is the lower bound of the distance-based rate for the given Rate Card band in the distance UOM.
Distance Upper
- Possible inputs
Distance Upper is the upper bound of the distance-based rate for the given Rate Card band in the distance UOM.
Rate Card From
- Possible inputs
A location or location group defined on the Locations or Location Groups sheet
Rate Card From is the initial location of the zone for the given Rate Card band. Zone-based Rate Card bands require both a Rate Card From and Rate Card To location or location group.
Rate Card To
- Possible inputs
Rate Card To is the destination location of the zone for the given Rate Card band. Zone-based Rate Card bands require both a Rate Card From and Rate Card To location or location group.
